Old 24th Apr 2019, 9:04 am   #41
John10b
Default Re: Bush DAC90A only receives 2 stations
The shunt across the dial lamps is 250 ohm 6 watt, according to my Bush service sheet.
John
John10b is offline
Old 24th Apr 2019, 12:35 pm   #42
mike1 ryan1
mike1 ryan1's Avatar
It was later changed to a 75ohm and the current limiting resistor to v5 was also changed. I think one service data sheet shows 250ohm and one shows 75ohm.
mike1 ryan1 is offline
Old 24th Apr 2019, 3:35 pm   #43
John10b
Hi I think you are correct, on my Bush service sheet is it shown as 250 ohm and a picture of another one shows 75 ohm. So you need to double check your chassis values. As a matter of interest are you using the Trader service sheet, if so what is the reference number please.
I’m sure members who specialise in Bush DAC90A can confirm.
John
John10b is offline
Old 24th Apr 2019, 3:44 pm   #44
ms660
ms660's Avatar
Trader sheet....scale lamp shunt...R18....75 ohms.
The story goes that the value was changed from 250 ohms to 75 ohms to give the scale lamps a better chance in a hot switch on scenario.
In Post#5 here:
https://www.vintage-radio.net/forum/...ad.php?t=97482
Lawrence.
ms660 is offline
Old 24th Apr 2019, 5:24 pm   #45
John10b
Thank you Lawrence for the info and the link, I’ll put a note on my service sheet.
John
John10b is offline
