18th Apr 2019, 11:20 am | #1 |
Bush SRP31D Restoration Questions
Hello!
I have recently acquired a Bush SRP31D portable, fitted with a BSR Monarch UA16 autochanger. I'm totally new to this kind of set, typically I lean more towards the solid-state hifi end of things, and this isn't particularly either of these with the expection of the rectifier! I'm looking to get this portable ship-shape. Hopefully my background in electronic engineering will help me along the way, although I'm a newcomer to valve amplifiers so I'm somewhat out of my transistorised comfort zone! All in all, it's in pretty good shape - the autochanger works fine (although the automatic record size selector is in need of a good degreasing), the amplifier works and the tone controls both noticeably affect the tone, however there are a few points I'm not so sure on:
I suspect I'll be ok with overhauling the autochanger as I know my way around the later BSRs (thanks to a misspent and not particularly long-ago youth spent playing about with late-70s disco consoles), but I would really appreciate any input on the above points. Thanks in advance, Henry |
18th Apr 2019, 12:23 pm | #2 |
Re: Bush SRP31D Restoration Questions
You might find this useful- at any rate there's a circuit there that isn't available "up top".
https://www.youtube.com/watch?v=3GZE_wnM3mI If you think of a pentode as a JFET with an extra gate that simply has to be connected to HT and decoupled you can relate to them in a semiconductor fashion. A triode doesn't have the extra gate and has (sort of) a resistor between source and drain, though the analogy falls down if things are biassed to cutoff. Another way is to think of the pentode as a voltage controlled current source and the triode as ditto with a parallel resistor. The heater is simply there to make the valve actually work by heating the cathode until it can emit electrons. The ECL86s are getting somewhat expensive now, so hopefully yours are OK. If they're paper dielectric types, replacing both output valve grid coupling capacitors is a must otherwise just check that voltages round the circuit make sense. The common cathode bias resistor and bypass capacitor need to be in good condition too.
....__________ ....|____||__|__\_____ .=.| _---\__|__|_---_|. .........O..Chris....O Last edited by Herald1360; 18th Apr 2019 at 12:31 pm. |
19th Apr 2019, 3:35 pm | #3 |
I would not rush to revert to the original Sonotone 8TA. Whilst these were good cartridges in their day, the (newer and lower compliance) Acos GP96/1 should serve you well.
You are unlikely to hear any difference. You might also find the that the record player sounds sweeter with that old hissy electrostatic speaker disconnected. The limiting factor in these quite high powered players, is that very small 6" x 4" Celestion main speaaker.
Edward. |
20th Apr 2019, 6:44 pm | #4 |
I have a spare Grundig electrostatic speaker from a Bush record player I stripped, it is untested but you are welcome to it FOC. Drop me a PM with your address if you want it and I will post it.
Peter |
20th Apr 2019, 10:11 pm | #5 |
I totally disagree with Edward. I repaired the tweeters in both my SRP31's both C and D versions and also in the separate amplifiers used for stereo. They sound much better with the tweeter than without it. I used pieces of a mylar happy birthday banner I had lying around to repair them
Steve |
23rd Apr 2019, 1:21 pm | #6 | |||
Herald1360, thank you for the analogy! Is there a way of testing valves without a dedicated valve tester, or should I work off the assumption that they're ok if they work? I'll have a poke around the chassis and check the caps and resistors when I'm home.
I am on the lookout for the matching AU31D amplifier unit, I have already posted a wanted ad in the classifieds. |
23rd Apr 2019, 8:31 pm | #7 |
Some would say that the best test for a valve is whether it works OK in the circuit designed for it.....
A simple check of electrode voltages against any service data will show up any serious problems and unless the cathode current sits excessively high or low there's unlikely to be much to worry about.
23rd Apr 2019, 9:17 pm | #8 |
Although it slightly annoys me when I read the comment that a particular component is a "change on sight", there's one exception in this model of record player, and that is the rectifier. A lot of them that you come across will have already had this component replaced with a single diode and series 'watty wirewound' power resistor. Some will have just had a diode only fitted, which is bad news as regards the valves, as they'll be thrashed to death, so always fit a resistor before or after the diode.
There's no point in taking voltage readings from around the valve bases until you've checked the HT voltage at the rectifier on these players, as if it's the original rectifier, it'll be virtually non-existent at below 40 volts in most cases. The record player will still work in this state but will sound terrible with no bass. There's virtually no capacitors to change in this model, as the grid coupling capacitors are either Mullard mustard or disc ceramic types in this player and unlikely to be faulty. Cathode decoupling capacitors could be replaced, but I've yet to find a faulty one in this type of player. Good clear photos of both over and under the chassis from end to end will tell forum members what the state of play is with your player. A forum search will tell you all you need to know regarding replacing that half wave rectifier if it still has the original one fitted. |
25th Apr 2019, 4:31 pm | #9 |
Following advice on here, and picking up on Techman's point, here's a simple way to address the rectifier: https://www.vintage-radio.net/forum/...d.php?t=153857
I've now done this procedure on three separate SRP31Ds and it evened up the sound between all three of them without any need to change other components. Regarding the cartridge, I had the Acos - which I believe is highly rated around here - in a Hacker Gondolier I acquired, but it wasn't performing up to scratch in dynamic range (I tested it by A/B testing running a line from one of the SRPs fitted with a Sonotone). In the end I replaced the Acos in the Hacker with a BSR12M. Separately, the Sonotone on one of the SRPs had badly corroded/broken contacts, and that was replaced with a BSR SC11M. Simply a case of what cartridge I could find at the right price! |
8th May 2019, 12:14 pm | #10 | ||
Apologies for taking so long to reply! I've been drowning in work unfortunately. Anyhow, I've now whipped out the chassis and taken a few photos of the chassis, underside and topside. I've noticed that the driver has a small hole in the paper near the edge - could this be a potential cause for the poor performance at medium to high volume?
Link to chassis photos Quote:
Henry Last edited by Station X; 9th May 2019 at 9:40 am. Reason: Link fixed. |
8th May 2019, 5:26 pm | #11 |
I would not have thought that the small hole in the Celestion 6" x 4" unit would cause a problem. Easily patched with tissue paper/Copydex. However, this is a very small unit to handle the potential power of the amplifier and you may just be overloading it.
Edward. |
9th May 2019, 6:43 am | #12 |
That link only shows a loudspeaker, is it me?
Regards, Ken. BVWS member |
9th May 2019, 8:58 am | #13 |
I can only see a picture of a speaker via that link, too. Do you have to sign up to that site and be logged in to see other photos? If that's the case, why not post them on the forum via the 'Go Advanced' button below the reply box?
9th May 2019, 9:41 am | #14 |
I've fixed the link in post #10.
