Old 17th Apr 2019, 6:20 pm   #1
stuart_morgan_64
Default 2SK133 & 2SJ48 Mosfets
Not sure if this should be in hifi. I have a couple of Maplin MOSFET amp boards. Is there a equivalents for these devices. Many thanks
stuart_morgan_64 is offline
Old 17th Apr 2019, 6:28 pm   #2
Mooly
Default Re: 2SK133 & 2SJ48 Mosfets
Yes there is. Have a look at these from Exicon.
http://www.exicon.info/products.php
You want the single die 8amp devices to keep originality although there are double die (16 amp) devices available. The double die parts would have twice the gate capacitance, however I wouldn't anticipate any issue if you did use those.
The two device numbers are ECF10N20 and ECF10P20
Mooly is offline
Old 17th Apr 2019, 6:38 pm   #3
stuart_morgan_64
Thank you for your quick response
Old 17th Apr 2019, 6:45 pm   #4
Mooly
You're welcome.
The original Maplin design which itself is based on the original Hitachi lateral FET application notes is a terrific performer.
Mooly is offline
Old 17th Apr 2019, 9:12 pm   #5
Radio Wrangler
Radio Wrangler's Avatar
That Hitachi application note amp turned up all over the place under various names and is, as said a good performer.
THe most elaborated published design using these transistors was probably the David Hafler DH200 which is quite different to the maplin amp.
Radio Wrangler is offline
Old 27th Apr 2019, 10:52 pm   #6
whiskas
whiskas's Avatar
Hi Stuart,
I believe I have some of the original Hitachi 2SJ48 and K133 here somewhere.
Are you going to build the amp?
...where on earth did that spring/screw go??
whiskas is offline
Old 28th Apr 2019, 1:59 am   #7
Restoration73
Restoration73's Avatar
You will get the same performance with the later TOP-3 flat pack devices that will fit the
board using a single screw and nut ; 2SK413 and 2SJ118, also Hitachi devices
Restoration73 is offline
Old 30th Apr 2019, 4:20 pm   #8
stuart_morgan_64
Hya, think I have messed up on replies, phone just too small now, especially on this site. Yes I plan to make two of the amplifiers up, have most things if not all except devices. Thanks also for other suggestions too.
Old 30th Apr 2019, 5:45 pm   #9
Norman Raeburn
Hi Stuart, How about these, they were working when removed from something I scrapped a few years ago. Norman
Norman Raeburn is offline
Old 30th Apr 2019, 6:44 pm   #10
Mooly
Here is a simulation of the amp for those that might use LTspice. The file will run on either LTIV or LTXVII. What is actually surprising is that someone reckoned the amp was unity gain stable and believe it or not the sim shows that to be basically true.
Name:	Annotation 2019-04-30 184139.jpg
ID:	182174   Click image for larger version
Name:	Annotation 2019-04-30 184121.jpg
Mooly is offline
Old 4th May 2019, 4:14 am   #11
stuart_morgan_64
Hya. Thanks. Could you pm me, let .me know what you want for them. Thanks.
Old 5th May 2019, 9:03 pm   #12
stuart_morgan_64
Thank you for all the comments. Now sorted. Thanks Norman.
