Old 9th Apr 2019, 7:16 pm   #61
GrimJosef
Default Re: Maths help....Again...exp?
My Windows10 calculator looks like the attached pic. What you have to do is to open the menu A and select Scientific from the drop-down. Then click on the arrow B until you get the screen in my pic. Then enter the number you want, say 0.03334, and click the e^x button, C, which will get you exp(0.03334). If you want exp(-0.03334) then you can use the plus/minus key, D, when you enter the number.
Cheers,
GJ
Name:	MS Calculator.jpg
http://www.ampregen.com
GrimJosef is offline
Old 9th Apr 2019, 7:43 pm   #62
ms660
ms660's Avatar
Brill, many thanks, had the scientific already but didn't know there were more keys, thought it was just exp not ex as well, anyways just done that exercise for 0.03334 and it returns the correct answer, eureka!
Next, a step by step instruction for the procedure to do the calc using the original formula, can you help with that?
Original formula...Vr=(Vp-0.7)(1-exp(-T/CR)) I can do Vp-0.7 no problem, I can also do T/CR no problem, the answer should be 0.47 volts or thereabout using that formula with the following inputs...Vp=15 volts...T=0.01667 secs...R=5,000 ohms...C=100uF
Lawrence.
ms660 is offline
Old 9th Apr 2019, 9:01 pm   #63
Skywave
Arrow Re: Maths help....Again...exp?
I use MS Excel for all sorts of formulae that arise in electronics. This attachment might help . . . .
Al.
Skywave is offline
Old 9th Apr 2019, 11:10 pm   #64
ms660
ms660's Avatar
I think I've figured it out now using the Windows 10 scientific calc now that I've found the ex function and I find it faster using the formula derived by GJ from my original alternative method, is that coincidence or is there a faster way using the original formula?
Lawrence.
ms660 is offline
