Old 12th Mar 2019, 6:57 am   #1
mike1 ryan1
mike1 ryan1's Avatar
Default HUNTS CRB Analyser.
Hi, can anyone provide me with component values for a hunts capacitor and resistor bridge tester. I have one that I bought some time ago that was in a bit of a mess inside. Somebody had made some modifications and butchered it a bit. I got a wiring diagram but there was no values with it. It works of a fashion but is not right. It would be handy to have it to test out a 20s or 30s radio I have and so I would like to get it working properly.
Thanks,
Mike
mike1 ryan1 is offline
Old 12th Mar 2019, 8:46 am   #2
Andrewausfa
Andrewausfa's Avatar
Default Re: HUNTS CRB Analyser.
Hi Mike,
Ron Bryan put together an updated circuit diagram here.
https://www.vintage-radio.net/forum/...d.php?t=141358
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 12th Mar 2019, 3:51 pm   #3
mike1 ryan1
That's fantastic thank you very much for that. That was so much easier than I thought it would be.
Thanks,
Mike
Old 12th Mar 2019, 5:15 pm   #4
Andrewausfa
Mike,
Not sure of your experience but just keep an eye on the rectifier, the stick looking thing or J25 on Ron's diagram. Has the possibility of letting the magic smoke out.
Andrew
BVWS Member
Old 13th Mar 2019, 3:04 am   #5
mike1 ryan1
I've replaced it with a diode the last time I had a go at it. There was a circuit diagram on the internet at the time but incorrect values on it amongst other mistakes. I gave up in the end I must admit. I was really pleased to find it so easy to get the details this time. Thank you though for the advice.
Mike
Old 14th Mar 2019, 9:20 am   #6
mike1 ryan1
Appreciate the advice though thanks
Mike
Old 14th Mar 2019, 3:33 pm   #7
TowerRadio
Because of its age you should treat ALL the caps with suspicion,especially the one that feeds the grid on the indicator.Les.
TowerRadio is offline
Old 23rd Mar 2019, 10:33 pm   #8
mike1 ryan1
Just a question about replacing the rectifier with a diode, does it need a resistor in series with it to replicate the rectifier resistance?
Old 23rd Mar 2019, 10:48 pm   #9
avocollector
Normally yes - the diode would normally give you a higher rectified voltage than the copper oxide/selenium rectifier - there is quite a bit of discussion on this on you tube (replacing copper/selenium rectifier) but I cannot find again the really good posting on this which I saw before and was a) simple b) showed you easily how to determine the new series resistor value. if I come across it again I'll post.
avocollector is offline
Old 23rd Mar 2019, 11:43 pm   #10
mike1 ryan1
Also is the target, pin 4, the small 'grid under the anode and the grid, pin 5, directly above the cathode. I only ask because this is how I wired mine and it doesn't work at all, no fluorescent glow from the valve at all.
Old 24th Mar 2019, 12:54 am   #11
Alistair D
Alistair D's Avatar
The official schematic for the CRB shows the rectifier with its cathode connected to earth. This the wrong way round. The updated schematic posted by Ron Bryan shows the anode connected to earth. This is the correct orientation.
Worth checking which way round yours is.
Al
Alistair D is offline
Old 24th Mar 2019, 3:21 pm   #12
mike1 ryan1
Well I've checked and rechecked all the wiring and components, which have all been replaced and totally rewired, and tried another y63 but still won't flouresce. It comes on briefly as it warms up then goes off, as if it's when a capacitor charges up. One question is about the 1uf capacitor between the 190v winding and earth, should this be an electrolytic type? I replaced it with a non polarised type poly one as that was what was in it. When I got it someone had already tried to get it working and wired a few things up wrong. I can't find anything else that could be wrong.
Mike
Old 26th Mar 2019, 11:21 am   #13
mike1 ryan1
I've been looking at some images on Google of the insides of these and there does seem to be a large electrolytic capacitor which I assume is the 1uf one. I've ordered one and will try it and see.
Old 26th Mar 2019, 11:50 am   #14
ronbryan
If a known good eye tube is not working, could you try measuring the voltages on the valve base with respect to chassis and post them here? You say that all the components have been checked, but does the rear wafer of the function switch supply HT to the Y63 anode and target when swiched to the appropriate measurement mode? It is also just possible that either the 1M target and 4M7 grid leak resistors go open when voltage is applied.
Swappping a HT smoothing film capacitor with an electrolytic of the same value will make no difference.
Ron
ronbryan is offline
Old 26th Mar 2019, 11:54 am   #15
davebms
Hello all.
I have a Hunts apart (work in progress) the 1uF capacitor I think is for HT smoothing, it was originally taped to the selenium stick, inside is a 2uF which connects to the power factor resistor. In my tester it's a Hunts 8801 whn in parallel with a .01/.01/.02. There is an old post on here that said that was done to get exactly 2uF, mine nearly works but is WAY off calibration!!
Dave.
davebms is offline
Old 29th Mar 2019, 9:13 pm   #16
mike1 ryan1
Apologies for the delay I've been working. Here are the voltages as they appear on the back of the valve base. Hope someone can shed some light on my problem.
Thanks, Mike
Old 29th Mar 2019, 11:44 pm   #17
ronbryan
Can you add the voltages that should have accompanied your posting #16, Mike.
Ron
ronbryan is offline
Old 30th Mar 2019, 9:28 am   #18
mike1 ryan1
Oops forgot to attach the file.
Old 30th Mar 2019, 9:43 am   #19
mike1 ryan1
The switch position was 'S'. Is this high because of the diode being used in place of the rectifier?
Old 30th Mar 2019, 12:06 pm   #20
mike1 ryan1
Sorry this was in the 'R' position. I have since used a variable resistor to bring the voltage to 167 and it didn't make any difference
