Old 25th Apr 2018, 2:58 pm   #1
mark2collection
mark2collection's Avatar
Default Philco 333 'Haunted Radio' Battery to Mains Restoration
Named ‘The Haunted Radio’ in our house, after my daughter came home from school & saw the set sitting on the patio table, with its ragged speaker cloth gently fluttering in the open-air breeze. The set had an almost sombre ‘expression’, if inanimate objects have such things. She wasn’t so keen on this radio to begin with, ‘looks eerie’ …
It certainly had a spooky look to it, the classic lines of its heyday fading, with a ripped speaker cone, damaged beyond repair speaker cloth & battery obsolescence … what to do with such a wireless … why, turn it into a fully working set, surely(!)
It was clear from the off someone had reworked parts of the circuit previous to my custodianship. Now, this could be a good sign & an indication that the set was up until fairly recent times, a worker … or, it could be someones’ gone in there & ruined an otherwise viable project! Thankfully, it was not the latter …
As is my way with such things, I checked for filament continuity on the 3 valves, checked the loudspeaker & transformer for continuity, plus the various coils, looking for all the usual signs of attempted repair, bits missing or broken. Mercifully, the set was remarkably complete & largely original. The previous repairer has left the original bakelite ‘blocks’ in place, having moved the original wires from said blocks & suspending replacement parts from the now ‘free’ wires.
The battery connections were a real mixed bag, one can only surmise as to how the previous owner(s) powered the set, my intention was to run the set from the mains & you’re about to see how it went.
Having checked coils/transformers/switches previously, the next task was to strip the cabinet of its hardware. Chassis safely to one side for now, along with the loudspeaker & baffle board.
The cabinet plus the 3 knobs, save for a few light scratches, came up really well with little to no effort. The original Perspex dial cover was beyond redemption; however, it came out along with its retaining pins, with no drama. The original dial cover was placed over the top of new Perspex; this was then marked up, cut, drilled, deburred & reinstalled using the original retaining pins.
Attention was then paid to replacing the original speaker cloth. The remains of the old cloth put up a bit of a fight; the old glue was certainly tuff stuff. Once the baffle board had been cleared of the old speaker cloth & glue remains, the new material was soon pressed (stretched more like) into action, having previously applied the glue.
Whilst this was curing, I centralised the loudspeaker cone with suitable spacers, then repaired the damaged loudspeaker cone with coffee percolator conical filters & water based glue. Trimming these coffee filters to an approximate shape, the water based glue allowed for shaping, & adhesion! Happy with my efforts thus far, once the loudspeaker glue had cured, I removed the speaker magnet, removed all visible remains of debris from the inner part of the voice coil & central magnet ‘stem’, then reassembled the loudspeaker, centralising as I went … with the dial cover in place, the baffle & loudspeaker were reinstalled into the cabinet. The cosmetics were coming along nicely.
Attention was then paid to the electronics, making a terribly crude power supply for the 120 volt, 67.5 volt & 2 volt supplies, just to prove the chassis was largely ok, & it was, sort of. The ‘new’ parts fitted by a previous repairer, were out of spec, with a couple of the caps acting as high value resistors. The original bakelite blocks were removed, filleted & re-stuffed with modern parts, then reinstalled back to how they were in the 1930’s. The other modern capacitors I fitted were bright yellow & stood out a little, so I printed some labels with ‘Philco’ & the part value/part number under the brand name, adding a brown background to try & make the new parts blend in. The labels were then glued onto the bright yellow capacitors. Had the original capacitors been in situ, these would have been re-stuffed too. One or two resistors were wildly out of spec, & were replaced accordingly.
Since the set was to be powered from the mains, I wanted to revise the power switching arrangement. Originally the power switch controlled the heater supply, nothing wrong with that, but I wanted the switch to control the mains, so the original wiring was left in place, the original switch having a discrete link placed across it. The new switch was fitted to the volume control via my homemade bracket, & having fitted a collar to the volume control shaft with a slightly longer retaining grub screw, which operates the lever. The new switch has a clear plastic cover along with heatshrink sleeving on the wires (belt & braces).
The dial now has a backlight. Having scrapped a printer/scanner, inside the lid of the scanner was an A4 sized piece of white sheet, which is the right width for a Philco 333 dial. This white sheet was fashioned into a dial ‘lightbox’ & furnished with LEDs. This gives pretty even spread of light across the dial, amazing given the directness of light from LED’s.
The main power supply took some work & a lot of thought to make it fit into the space the batteries once occupied. The metalwork for the new power supply being leftovers from my Bush DAB90A project, most of the electronic parts were from previous orders. You know, you only want one part but they come in a bag of 5 … & the transformer salvaged from a previous project. The power supply sits on runners, along with the original chassis, the original screw passing through the new runners holding everything in place.
The whole set is protected by three fuses & three triac-fired crowbars. The heater supply is regulated with a trip point tolerance of +0.3 volts. Even at this trip point, by the time the valves see it, the supply at the valve base is 2.1 volts. The other supplies have a +10 volts trip point, the triacs on the 67.5 volt & 120 volt HT rail pulling in a 30K 50W resistor strapped across the main HT, which draws more current than the fuses can supply, thereby, protecting my set. I’ve removed (but retained) the battery connections & fitted a 6-way, keyed, Molex connector.
A back cover has been made for the set; it’s nothing more that thin marine-ply. I’m in two minds as to whether I should vent it, just like the Philco 444, but in all honesty, my power supply runs tepid, & the valves themselves barley get warm.
How does the set perform? Once you get to grips with a TRF, it’s a joy to listen to. Last night on LW it pulled in Radio 4 plus a couple of foreign stations, & on MW we had Smooth, possibly Absolute (?), 5-Live & a number of foreign stations. No alignment has been adjusted, seems a very happy radio so this side of things has been left well alone.
Sound quality was a real surprise, so long as the reaction control is set right, you have a wonderful mix of warmth & clarity, with the ability to chop out unwanted noise.
I’ve done my best to keep this repair as sympathetic as possible, all my modifications are completely reversible, should it be desirable to do so in the future.
Has taken a while to orchestrate this project, but I think it went ok …
Mark
Name:	01 Cabinet As Found.jpg
ID:	161775   Click image for larger version
Name:	02 Under Chassis As Found.jpg
ID:	161776   Click image for larger version
Name:	03 Under Chassis Close-Up.jpg
ID:	161777   Click image for larger version
Name:	04 Capacitor Re-Stuffing.jpg
ID:	161778   Click image for larger version
Name:	05 Loudspeaker As Found.jpg
mark2collection is offline
Old 25th Apr 2018, 2:59 pm   #2
mark2collection
Default Re: Philco 333 'Haunted Radio' Battery to Mains Restoration
After photo's ...
Mark
Name:	01 Cosmetics Done.jpg
ID:	161780   Click image for larger version
Name:	02 Loudspeaker Repaired.jpg
ID:	161781   Click image for larger version
Name:	03 Under Chassis After.jpg
ID:	161782   Click image for larger version
Name:	04 New Power Switch.jpg
ID:	161783   Click image for larger version
Name:	05 Back Cover Removed.jpg
Old 25th Apr 2018, 5:06 pm   #3
vinrads
A very enjoyable read Mark well done withe the restoration, your power supply puts mine to shame, I like these old TRF sets as you say you have to know how the drive them, with a good signal they perform very well. Mick.
vinrads is offline
Old 25th Apr 2018, 8:48 pm   #4
sortedradio
sortedradio's Avatar
An excellent job. I particularly like the implementation of the switch on the volume control shaft, and the ingenious use of coffee filters to repair the speaker! It looks a really nice set now.
Martin
BVWS member
GQRP Club
sortedradio is offline
Old 25th Apr 2018, 11:03 pm   #5
Tractionist
Very very nice work - well done!
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 26th Apr 2018, 10:23 am   #6
Nickthedentist
Nickthedentist's Avatar
Yes, absolutely first rate work. I like it a lot!
Nickthedentist is offline
Old 27th Apr 2018, 3:09 am   #7
marconi_pete
marconi_pete's Avatar
An absolutely brilliant job. I like the idea of the switch on the volume control shaft, Think thats a very clever idea. Nicely built power supply and housing too.
Thanks,
Peter
marconi_pete is offline
Old 27th Apr 2018, 9:31 am   #8
newlite4
newlite4's Avatar
Lovely job Mark, the main chassis is just too cute - it almost looks lost within the case!
Neil
preserving the recent past, for the distant future.
newlite4 is offline
Old 27th Apr 2018, 1:48 pm   #9
Lloyd 1985
Lloyd 1985's Avatar
That’s a very neat solution to convert it from battery to mains, looks great! Very enjoyable write up too, and the finished set looks lovely. I really must make a start on my 444 when I’ve finished the Ekco RS3.
Regards
Lloyd
Lloyd 1985 is offline
Old 27th Apr 2018, 5:12 pm   #10
usradcoll1
A very impressive description of the power supply design.
Is it possible to furnish a schematic of the power supply? Hand drawn is fine. Thanks and best regards!
Dave.
usradcoll1 is offline
Old 30th Apr 2018, 12:24 am   #11
Phil G4SPZ
Phil G4SPZ's Avatar
Nice work, and an interesting write-up, too. The set looks slightly less haunted now!
Phil
Phil G4SPZ is offline
Old 30th Apr 2018, 2:02 pm   #12
The Philpott
The Philpott's Avatar
..I can't see anyone wanting to reverse your modifications at any time in the future..!
Mark, what polish was used on the case?
Dave
The Philpott is offline
Old 1st May 2018, 10:29 pm   #13
mark2collection
Guys,
Thank you for your kind words, this set has come out better than expected, especially given I made the power supply (I'm not a designer by any stretch) & the parts I used were 'what I had' ... in the coming days I hope to draw a schematic for the power supply, but life is seemingly getting in the way of such things at present ... but hopefully by the weekend, we'll have a drawing uploaded.
Regarding the polish for the cabinet, I used Meguairs Ultimate Compound for the initial 'buff-up' (The cabinet wasn't especially grubby, just flat-looking) and a couple of goes with Mr Sheen using a microfiber cloth throughout.
Mark
Old 3rd May 2018, 6:52 pm   #14
line sync
A really good job done mark.
Like others have said I like the idea of using coffee filter cone`s for the speaker repair , I`ll remember that one.
It`s nice to see the set kept as a battery model instead of finding a mains chassis.
Robin
line sync is offline
Old 30th Jan 2019, 12:24 pm   #15
mark2collection
Apologies for the delay Dave (usradcoll1) in uploading the requested PSU schematic.
Shortly after repairing the Philco 333, my Father unexpectedly passed away and have since been otherwise occupied.
Schematic was drawn on Sunday 27th January, 2019, from my 'jotted' notes at the time of repair.
The PSU was made from 'bits I had', I am no designer either so the layout will likely be not ideal, but it works
Am open to suggestions/improvements on the design. Fuse values are 250mA for mains, 100mA for HT, and 250mA for heaters. I've tested the PSU to destruction too (deliberately!) to ensure my valves will not be harmed in the event of a mishap.
The set was used over the Christmas period & a few times since, Jack Hylton sounding very good through the set.
Mark
Slowly turning the 'to-do', into 'ta-dah'
