Old 18th May 2008, 10:02 pm   #1
Leon Crampin
Default Removing BBC R1..R4 diamond markers.
Many radios appear with these markers stuck to the tuning scale and they can be extremely difficult to remove.
Having just acquired a Bush VHF64 for restoration which is festooned with these stickers, does anyone have a good way of softening these things to permit easy removal?
Leon.
Leon Crampin is online now
Old 18th May 2008, 10:28 pm   #2
igranic
igranic's Avatar
Default Re: Removing BBC R1..R4 diamond markers.
Leon
I find that aerosol label remover works well, but if the adhesive has become stubborn through heat or UV exposure then patience, repeated applications, and 'teasing' with a plastic trimming tool may be required.
If the scale is glass, then a typists correction blade or scalpel can be used to scrape the stickers off (obviously, this technique should not be used on perspex or polycarbonate tuning scales). Any remaining glue can usually be shifted with label remover or white spirit applied with a cloth.
HTH
Edward
igranic is offline
Old 18th May 2008, 10:36 pm   #3
batterymaker1
batterymaker1's Avatar
Automotive hand cleaner--the white cream type, not with pumice--is famous for removing adhesive stickers and tape.
Just playing with high voltage....
batterymaker1 is offline
Old 18th May 2008, 10:47 pm   #4
paulsherwin
paulsherwin's Avatar
Plain old white spirit will do it, but it takes patience and repeated applications as the liquid needs to seep in from the edges. It will help if you can get some of the plastic off with a fingernail.
Paul
paulsherwin is online now
Old 18th May 2008, 11:38 pm   #5
Steve_P
Steve_P's Avatar
Well I go and get a lolly from the local shop, eat the lolly and then use White Spirit and the lollystick. This is one way of shifting them with something that won't harm the glass.
And I do like those Chocolate ones...
Cheers,
Steve P.
Steve_P is offline
Old 19th May 2008, 10:32 am   #6
ben
ben's Avatar
heat the area with a hairdryer (carefully). the heat loosens up the adhesive of labels. works like a charm. On older/ encrusted things this may not work too well though.
ben is offline
Old 19th May 2008, 10:45 am   #7
wireless_paul
wireless_paul's Avatar
Location: World Heritage Village of Saltaire, Shipley, West Riding of Yorkshire.
I have in the past removed these labels, but being more involved in selling vintage items these days, I do believe if these labels are neatly attached and are still readable, they should not be removed. They are after all part of the history of that radio.
Paul
wireless_paul is offline
Old 19th May 2008, 11:37 am   #8
Tom_I
Tom_I's Avatar
I generally use isopropanol (or aerosol switch cleaner), let it soak for a while, then use a fingernail. Same principle as Steve's lolly stick, but slightly more hands-on.
It works (eventually), but it's a bit of a pain.
Tom_I is offline
Old 19th May 2008, 4:35 pm   #9
Leon Crampin
Thanks everybody, I'll try your suggestions. As it's a glass scale, I can always finish up with paint stripper - these particular labels seem extremely stubborn.
The way this lot have been stuck onto an otherwise reasonable looking VHF 64 doesn't enhance its appearance at all! (The same owner sanctioned the drilling of a hole in the side of the cabinet to fit a mains toggle switch rather than repairing the original Plessey item fitted to the push-button bank - I've now fixed this).
The things people do to radios...
Leon.
Old 19th May 2008, 7:58 pm   #10
Nickthedentist
Nickthedentist's Avatar
Originally Posted by Leon Crampin View Post
As it's a glass scale...
You're laughing then!
I would take out the glass, put it on a dead-flat surface with a cloth underneath to protect the screenprinting, then use a paint scraper - the sort that's fitted with a Stanley-knife blade.
Once the plastic's gone, use WD40 to remove the glue, then some IPA to remove the oily residue.
Nick.
Nickthedentist is online now
Old 20th May 2008, 11:38 pm   #11
Leon Crampin
A final update. The stickers are now all off without any other damage.
I tried all sorts of solvents and none had any significant effect - the glue is rock-hard. Luckily it's a glass scale so scratching is not a major problem. As the scale was out of the set anyway I positioned it horizontally and put one drop of thin machine oil on each "diamond" and let it soak overnight. I then scraped off each sticker with a Stanley knife blade held at a shallow angle. The oil makes the job easier and probably lessens the chances of any scratching - there was none when I had finished.
Thanks for all contributions.
Leon.
Old 22nd May 2008, 8:38 pm   #12
camtechman
camtechman's Avatar
Still got those stickers on my little homebrew "Golden Virginia" radio that I built some years back (when I used to roll my own):
Name:	Golden Virginia Radio.JPG
ID:	17369   Click image for larger version
Name:	Golden Virginia Radio Inside.JPG
camtechman is offline
