19th May 2019, 7:36 pm | #1 |
Sony TC250A
This machine has been on my "round tuit" pile for 5 years and I don't know where to start with it. Playing back a known good tape, one channel is off and the other is lower than it should be. The heads look in good shape and they aren't open circuit. The circuit board looks like something from an early 70s market stall radio and would be very difficult to work on in situ. On the positive side, the instruction book contains a circuit diagram and there are no ICs. Each audio channel uses four transistors, with the power supply and bias oscillator on a separate panel. I was going to change the electrolytics on the audio panel and hope for the best. This tape recorder is probably not "hi fi" quality but it would be nice to get it working again. Does anyone know how old these machines are or have experience of repairing them?
Regards Martin Last edited by martin.m; 19th May 2019 at 8:00 pm. Reason: More information |
19th May 2019, 8:31 pm | #2 |
Re: Sony TC250A
First things first: clean the rec/pb slide contacts, track selectors, output pot etc etc. with servisol. Move back and forth 20'30 times. Then clean again.
I have done a few of these era sonys and generally the electronics is reliable. The mechanics tend to need serious and time consuming degunking! Check condition of idler tyres and pinch roller, if that is shot it will likely cost more than the unit is worth to repair.
Regards, Ben. |
19th May 2019, 8:33 pm | #3 |
Re: Sony TC250A
The 250A is about 1968. Decent enough sound when it's working. Mac Hellyer covered this machine in Tape Recorder 1969/70. These are on the American Radio History website.
19th May 2019, 8:34 pm | #4 |
Re: Sony TC250A
I used to service these back in the 1970's, they go back further than that, mid 1960's.
Lawrence. |
22nd May 2019, 9:58 pm | #5 |
Re: Sony TC250A
Thank you for your replies. I found a Sony advert for the TC250A dated 1966. The deck appears to be in excellent working order mechanically with no visible head wear. I will definitely have a go at fixing this machine, when I get the time of course.
Regards Martin Last edited by martin.m; 22nd May 2019 at 9:59 pm. Reason: typo |
