Old 20th May 2019, 10:29 am   #1
SteveCG
Default Metrotest 16D Insulation & Continuity tester
This car-boot acquisition came without any instructions (and a couple of corroded and decayed battery contacts as well!). I reckon it dates from the 1990s - yellow case, lcd display and needs 6, AA size, 1.5 Volt batteries to work.
I tried a web search for instructions but to no avail. Can anybody help with operating info please?
SteveCG is offline
Old 20th May 2019, 11:35 am   #2
Andrewausfa
Andrewausfa's Avatar
Default Re: Metrotest 16D Insulation & Continuity tester
Hi Steve,
Probably is 1990s, Metrotest were located in Durham and got taken over by Martindale (they also have Metrohm, Edgecombe and Drummond) who may have some info on it or at least on a re-badged design under the Martindale name.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 21st May 2019, 12:24 pm   #3
SteveCG
Thank you Andrew for the info. I contacted Martindale who kindly sent me an instructions .pdf of their model Metrohm 16D which they tell me is the same rebranded tester.
Mods: you can close this thread if you wish.
SteveCG is offline
