1st Feb 2019, 6:53 pm | #1 |
TalkSport echoes.
Some people complain here about sibilance on radio-4 longwave, but why has nobody mentioned the horrible echoes on TalkSport 693/909KHz?
I live where the coverage-areas of two transmitters overlap. The problem is not carrier-desynchronisation-fading between transmitters (I know what that sounds like from my days with wide-area-coverage AM VHF police/fire/civil-defence rnetworks atound 100MHz) - rather it sounds much more like one transmitter's audio feed has a delay of 100 milliseconds or more compared with the other. The echo makes TalkSport all-but-unlistenable-to. What's the best path through which to report this? |
1st Feb 2019, 7:02 pm | #2 |
Re: TalkSport echoes.
Been reported may times before and in short they just don't care about their AM output now they are on DAB, Freeview and Online.
If smoking is so bad for you, how come it cures kippers? |
1st Feb 2019, 7:10 pm | #3 |
Which is a shame: for me the only really-listenable daytime content on MW/LW is TalkSport.
Hmmmm... in the 1970s I used to participate in top-band 'foxhunts' - I've still got the radio [four OC170s, a TAD100 IC and a single NKT404 as the audio-output stage] somewhere in the attic; I wonder if it still works and could be resurrected to let me null-out one transmitter? |
1st Feb 2019, 7:17 pm | #4 |
Five Live is on 909/693, the echo is because of simultaneous transmission from far apart transmitters getting various feed methods.
1st Feb 2019, 7:37 pm | #5 |
Yes, if you live in an overlapping area all you can do is null out one of the transmitters. 1053/1089 was always an awful transmitter network even when R1 used it, and there's no attempt to keep the transmitters synchronised now.
909/693 R5 is a bit better but still pretty grim in places. |
1st Feb 2019, 7:43 pm | #6 |
The problem's not transmitter desynchronisation, it's the audio-delay between the transmitters that makes it sound like the program is being delivered from inside a tube-station.
I'm going to do some playing-around with directional antennas and a version of the "Jones" phasing-scheme (more usually seen used in WWII aircraft to reduce interference from spark-ignition engines) to see what's possible. |
1st Feb 2019, 7:46 pm | #7 |
Yes, it also happens on Virgin - and you can hear different adds in the commercial breaks!
In the good old days the BBC ensured that not only were synced networks' carrier frequencies within 0.05 Hz, but that the modulation was exactly in sync too. (I remember this from my days at BBC Crowsley Park, but maybe some transmitter engineers could add some more.) |
1st Feb 2019, 7:46 pm | #8 |
Because transmitter synchronisation has been abandoned they don't see any need to synchronise the audio feeds either. I think the TalkSport feeds come from satellite.
1st Feb 2019, 8:06 pm | #9 |
Some times, just for fun, I put 2 identical radios about 6 foot apart and tune into Radio 5, one tuned to 909 and the other to 693 and it produces a great 'empty hall' effect.
I'm not sure but I'm receiving from Sandy Heath & Oxford ?
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
2nd Feb 2019, 1:17 am | #10 |
Camtechman you will be receiving 909khz from the Brookmans park transmitter and maybe 693 from Postwick near Norwich.
2nd Feb 2019, 11:58 am | #11 |
693 will be from Droitwich. There are no MW transmitters at Oxford apart from a tiny relay for Absolute.
2nd Feb 2019, 12:27 pm | #12 |
Many thanks.
11th Feb 2019, 9:45 pm | #13 | ||
I don't think this has ever occured, but there is a first time for eveything! Quote:
Some time ago, the 1089kHz channel used to have a pronounced beat of around 1Hz at night for a length period. This is no longer apparent, - the offending transmitter (possibly was Westerglen) must have been put precisely back on 1089 (using GPS reference??), now if only the echoing (still happening on both 1053 and 1089) could be sorted out! Last edited by colourking; 11th Feb 2019 at 9:53 pm. |
11th Feb 2019, 10:42 pm | #14 |
The distribution of Talksport is IP based at a fairly low bitrate, so there are varying delays at each site dependent on the routing. It is not something that can be fixed unfortunately. Rotating you radio to null out interference is the only realistic option to cure it sadly.
16th Feb 2019, 8:31 am | #15 | |
It's obviously just not worth anyone's bother these days. |
4th Mar 2019, 4:32 pm | #16 | |
Echoing in the middle of the day now audible where I am on 1089, which hadn't been the case recently!, so its an echo between Redruth and Washford where I am as I have a mixture of signals from both on 1089 |
4th Mar 2019, 7:26 pm | #17 |
I remember when that frequency was Talk Radio UK, the good old days
4th Mar 2019, 7:37 pm | #18 |
And before that Radio One!
29th Mar 2019, 10:39 am | #19 | |
Talksport do not do that anymore as far as I can tell. But they do still have separate traffic/travel news for some areas, I can sometimes easily hear the separate traffic/travel for Scotland on 1089 helped by rotating the radio early in these mornings with Skywaves still present. (listeners possibly hearing another travel news in the background is only a minor issue compared to the constant echoing issues that were occuring!) Last edited by colourking; 29th Mar 2019 at 11:01 am. |
29th Mar 2019, 12:27 pm | #20 | |
We can only assume that they just don't think it's important enough to spend any money on. Chris
