21st Mar 2006, 9:04 am | #61 |
Re: PC as a standard convertor
Hi Jeffrey,
thanks for your schematic. I soved the problem with the fast rising edges of the sync by using a HCF40..BE driever. The problem is you add the signals and the noise of the black level signal is added to the sync tips. Maybe you noticed the spike in Kat's oscilloscope screen shot. This will be added to the sync edge and it will destroy it. In Kat's and my design the sync is independent from noise at the black level. The DC level of the input RGB is unknown, thus the DC level of the sync tips at the output is unknown. In the modulator you need an additional DC restorer and biasing circuit. Kind regards Darius |
21st Mar 2006, 9:20 am | #62 | |
The RGB signals from a graphics card should not have any significant noise. If there are large spikes in the blanking interval then some kind of reblanking will be needed. |
21st Mar 2006, 9:45 am | #63 | |
in the MK II and MKIII converter/modulator every input signal gets a new clean sync and the discribed stages are always in use. Kind regards Darius |
21st Mar 2006, 7:02 pm | #64 | |
Jeffrey, I think I'll get hold of a video opamp or two and have a play. If all goes well, there's probably good cause for getting boards made up for this as something that could be sold complete or as a kit. With my 'production engineer' hat on I regard reducing the number of components as a Good Thing (tm) as construction is simplified and there's less to go wrong etc... It looks like a circuit with a video opamp would offer better performance and simplified construction. I'd guess with the high bandwidth of these wee beasties I'd need to pay careful attention to grounds, supply decoupling, etc - similar to the sort of issues involved in RF and high-speed digital logic design with which I'm more familiar. Incidentally, I modified the output stage of my rough and ready mess with the wandering black-level; set the X modeline back to 625-line and got a reasonable stable monochrome picture on my 25" Mitsubishi "modern" (slightly dim and a little lacking in HF response, but I can probably tweak that). So it'll do for now until I make a 'Mark II' with a video opamp Regards, Kat |
2nd May 2006, 10:55 pm | #65 |
Kat,
your link to your original combiner diagram is broken - do you have a copy of the diagram anywhere else? Secondly, when playing with the X modeline, did you just put the 405 version in, and remove the others, or at least comment them out? Finally, does the sync come out of the card as a combined signal, or as seperate H and V signals? (the VGA data suggested either was possible). I do at least understand how you arrived at the numbers for the Modeline - an interesting little set of calculations! Many thanks Jim. |
3rd May 2006, 2:32 am | #66 | ||||
Hi Jim,
I'll tidy the file up and comment it a bit better then let you have a copy. Quote:
Regards, Kat |
21st May 2006, 7:10 pm | #67 |
Does anyone know if I could use a twin processor unit for this purpose - there are some fairly well specd models on Ebay at present, and at a reasonable price, located a few miles from me - any ideas?
Cheers Sean Itching to get some progress on this idea......
21st May 2006, 7:50 pm | #68 |
Hi Sean,
MythTV itself doesn't take advantage of SMP systems; though it would run the backend and frontend on different processors, gaining some advantage as Linux will run on SMP systems and spread the load out accordingly. Regards, Kat. |
21st May 2006, 7:52 pm | #69 | |
What I found was: *) The MythTV documentation doesn't mention SMP (Symmetric MultiProcessor) with even a single word when it comes to hardware selection. In my experience this means that the program will not utilize two processors at once, if present. So if a single, slow CPU cannot encode/decode as fast as one would like, two of them will not be of any help. *) Some people on the MythTV reported driver problems when running SMP. Ie. the drivers were not thread safe. Not good. So unless you need to run two CPU intensive programs at once while running MythTV, SMP probably won't help much. Additionally my experience with using SMP machines as workstations and number crunchers are that with older hardware you usually run out of other resources before the CPU power is exhausted. Ie. harddisk, memory or DMA speed is insufficient to fully saturate two CPUs. The exception is very CPU bound applications like raytracing, where you often can run two tracing instances at once for close to a 100% speed advantage. SMP may help when you need to run two dissimilar programs at once. Like if something happens in the background while MythTV is playing, a second CPU might help prevent 'stuttering'. Notice emphasis on 'might'. When the program of interest really is limited by the CPU, a single slightly faster CPU is often way ahead of two relatively similar processors at half speed or so. This is due to all the other enhancements, which accompagnies the faster CPU/motherboard. As an example of this, then a single 1GHz P-III is so much faster than 2x 400MHz P-IIs that it isn't even funny. The P-III has a larger cache, faster RAM interface and other architectural enhancements, so it is way faster than twice the combined CPU horsepower of the P-IIs. Another case I have personally experienced was a single 1.3GHz P-III 'Tualatin', which obliterated a pair of 550MHz P-III Xeons! The latter pair was housed in a very expensive piece of server hardware (assembled by yours truly), yet give it a few years and a cheap beige box and a motherboard from Asus made toast of the Xeons... What types of CPUs are you looking at for SMP? Best regards Frank N. |
21st May 2006, 8:06 pm | #70 |
Ah, right, well, the unit I was looking at runs dual 800Mhz processors, and has 512mb of ram - so on paper it would appear to be ok for Myth with just one of the processors.
However, if the consensus is that this might cause issues, then I will accept the hit on postage, and source a single CPU machine (just being tight fisted really!) Daft really, I'm more than happy to lash out large chunks of cash for test gear, but wince when spending money on PCs! Cheers Sean
21st May 2006, 8:20 pm | #71 | |||
21st May 2006, 8:26 pm | #72 |
Hi Sean,
I found a single 800MHz Duron was a bit marginal decoding off-air digital telly; as the frontend would run entirely on one processor you'd probably have the same problems with dual 800MHz processors. I'm running a single-processor 2GHz Athlon XP box now (that was the black machine at NVCF) and that's definitely ok; it should have enough thrutch to handle dual DVB-T cards; possibly an analogue tuner card as well. A rough guess is that a single 1.3GHz processor should be just enough to handle a single analogue 'framegrabber' TV card; 'framegrabber' cards need more thrutch as the images are encoded and dumped to disk by the backend then read from disk and decoded by the frontend. Digital telly takes a bit less crunch as it's already an mpeg stream so the encoding stage is skipped; but then you have no choice but to decode full-resolution mpeg2 streams as that's what you get. Processor requirements are a bit tricky to nail down as it does depend on your source of video/off-air signal, how many tuner cards you intend to use, what type of cards you use, etc, etc... Regards, Kat. |
21st May 2006, 8:56 pm | #73 |
Hi Kat,
Ok, Sorry if I seem a bit thick on this, but computers to me are a sort of spawn of the devil! I take your point on proc speed - perhaps I ought to downgrade the system I use in the shack, and use that PC for this project. I am curently unsure if I will ever use the system for real time off air decoding - SWMBO does not appreciate the "horrible wooden box" in the dining room! I am currently bidding on a Nvidia ge force 4 video card, and I am looking into a DVB card - much to my amazement PCworld stock the one you mention! So, perhaps the shack logging PC gets the chop - it is a 1.7G proc with about a gig of ram, so I guess this is really a no brainer! Cheers Sean
21st May 2006, 9:40 pm | #74 |
Administrator
If the shack PC isn't doing much, maybe that dual 800MHz on eBay could go in there instead? It'd be happy with Windows 98 or 2000 but might be a bit sluggish with XP.
21st May 2006, 10:07 pm | #75 | |||
Jim. |
21st May 2006, 11:31 pm | #76 | |||
Regards, Kat |
29th May 2006, 8:37 pm | #77 |
"The Fools" have been at work again, and have some very interesting news... Jim Beacon discovered that the later nVidia driver we're both now using for our cards permits pixel clocks below 12MHz. I've worked out a new modeline for 405-line using a pixel clock of 6.48MHz, which gives me even closer 405-line timings (line and frame rate are exactly 10.125kHz and 50Hz respectively) and has a rather more respectable 536 x 378 resolution. One upshot of this is the MythTV user interface is a lot more readable as the text isn't squashed; the user interface settings still need a bit of a tweak, but it's a vast improvement. Details of this will be added to the website in due course. Regards, Kat |
29th May 2006, 9:37 pm | #78 |
It;s amazing what "The Fools" can do. Has anyone done a dual head 405 and VGA yet?
That Pye monitor looks like it's doing a good job too. |
29th May 2006, 10:42 pm | #79 | |
Jim. |
30th May 2006, 8:32 am | #80 |
I've got Matrox G550 and Parhelia cards (both dual head) around as part of the work I do for one of my clients. I know that my colleague who does the software runs them in non-standard modes though still with fairly high dot clock speeds. The G550 in particular has always seemed very tolerant of any abuse we've hurled at it. In particular we have meddled with the master 27MHz clock and the G550 never complains. The Parhelia on the other hand is a touchy little devil and will crash the PC at the slightest provocation. The Parhelia is an expensive card so it's not really suited to the FothTV project unless you have one lurking in the junk box. At least FothTV won't involve mucking around with the hardware on the graphics card.
