1st Oct 2004, 2:24 pm | #1 |
Log or Lin Potentiometers?
Hi
I have a Bush PB53 and I need to buy a 500K pot for the volume and a 25K for the tone control. Can somebody please tell me which one needs to be log and which one is lin Thanks David Last edited by Paul Stenning; 26th Dec 2004 at 8:28 pm. Reason: Fix link or code for vBulletin |
1st Oct 2004, 2:35 pm | #2 |
Re: Log or Lin Potentiometers?
David,
You need a log pot for the volume and a lin one for the tone. Best wishes, John B. |
1st Oct 2004, 6:50 pm | #3 |
Yes log pots for volume. I have fitted the wrong type in the past and Have not found the difference to be such a problem.
Every Silver Lining Has Its Cloud https://youtube.com/channel/UCvBpiuUUnErJlNBm6DWb3Ww |
1st Oct 2004, 7:10 pm | #4 |
I think it's to do with the ear having a logarithmic response to sound levels. If you use a linear pot for volume most of the useful range of volume is squashed into the first few degrees of rotation. Using a log pot spreads it out a bit.
1st Oct 2004, 7:13 pm | #5 |
I have a tin full of used pots and none seem to say whether they are log or lin. How can I check what they are with a multimeter?
http://www.youtube.com/ My Nixie Clocks |
1st Oct 2004, 7:24 pm | #6 |
Log pots normally have LOG printed after the value (Lin pots are sometimes marked, but not always).
Measuring with an analogue meter may be misleading, as they have a non-linear scale. I would think that setting the wiper to the mechanical half way point & measuring to either end would give the game away. Last edited by Paul Stenning; 26th Dec 2004 at 8:29 pm. Reason: Fix link or code for vBulletin |
1st Oct 2004, 7:29 pm | #7 |
Carefully set the potentiometer to its midposition. Now measure the resistance from each end of the track to the slider. If the readings are APPROXIMATELY the same the pot is linear. If they differ widely the pot is log.
A more sophisticated method is to fix a temporary pointer and a scale calibrated in degrees to the pot. Connect the meter between the slider and one end of the track. Plot a graph of degrees of rotation against resistance. If the graph is a single straight line the pot is linear. If the plot is two lines of differing slopes the pot is log. The two linear portions are a good approximation to a true log track. Graham. Last edited by Paul Stenning; 26th Dec 2004 at 8:30 pm. Reason: Fix link or code for vBulletin |
