Old 14th Jan 2012, 7:32 pm   #1
g7mzh Laurence
Default How to straighten rear cover?
I have a Roberts transistor table top set, model RM30, that has the old-style case back. The problem is that the material (which seems to be a sort of lightweight chipboard rather than the usual layered paper) has become warped.
Is there any way of straightening this? Bending it is impossible, it's quite solid and would probably snap. I'm wondering if steaming it would help, or whether getting it wet might cause more damage.
Thanks in advance.
rgds
LAurence
g7mzh Laurence is offline
Old 14th Jan 2012, 10:59 pm   #2
G8VAT Wolfman
Default Re: How to straighten rear cover?
Don't know this particular model but it if the pulp was compressed with resin, just warming it might soften it enough to press.
If it is quite thick then it's gonna need a really good steaming possibly under pressure before attempting any sort of pressing.
Just a single dampening shouldn't do any harm but watch for any inking/printing or labels that might suffer.
G8VAT Wolfman is offline
Old 15th Jan 2012, 11:24 am   #3
brenellic2000
If it is 'fibre board', ie: compressed 'oiled hardboard' or glued wooden fibres (chip/MDF), then any introduction of moisture will expand the wood fibres and it is unlikely they will ever contract again except under very high pressure.
The safest method is to warm it on a flat plate over a radiator and keep it compressed under a heavy weight over 2 or 3 days. You may have to try agian....
Barry
brenellic2000 is offline
Old 19th Jan 2012, 9:36 pm   #4
g7mzh Laurence
Thanks; a quick burst with a heat gun and a heavy transformer seemed to have some effect, but providing extended periods of heat safely isn't really practical. I didn't fancy putting it in the oven!
In the meantime, I'll replace it with a suitable-cut piece of hardboard. It's a solid state set, so heat won't be a problem.
rgds
Laurence
