19th Nov 2011, 7:16 pm | #1 |
Scratches on Grundig buttons
Hi
I have just got hold of a Grundig Satelitt 2100 which has not been cherished like it should have been. The main problem is the black top buttons are scratched and showing the aluminium beneath which makes it look rather scruffy.I assume this is some sort of lacquer. Any idea of the best way to restore this without disassemble. I vaguely remember in my camera days that they used to sell a black lacquer stick for touching up camera bodies but I have not seen this for ages. Any ideas of the best way to go about this. Cheers Mike |
19th Nov 2011, 9:34 pm | #2 |
Re: Scratches on Grundig buttons
Depending on the depth of the scratch, how authentic you want it and how long you want it to last try an indelible felt marker, when done just rub gently with finger to blend it in.
I use a “sharpie” for minor scratches on black anodised aluminium as well. I used the same on some black anodised alli on my boat, it is still slightly black after exposure to sunlight and rain for 9 months. Mike |
19th Nov 2011, 10:55 pm | #3 |
I would normally use crackle,s method which is also very good for black vinyl coverings. It might also be worth considering the Edding 780 paint marker. Not sure if this will be too shiny though.
Al
I won't tell you how I discovered that. |
19th Nov 2011, 11:39 pm | #4 |
How about one of the little tubes of car touch-up paint that have a tiny brush in the top? Halfords sell them.
Barry |
19th Nov 2011, 11:42 pm | #5 |
Or even apply the paint via a needle to control the quantity applied.
Al
20th Nov 2011, 1:25 am | #6 |
Sound like your 2100 has the, earlier, 2000 painted aluminium style buttons? If so, IMHO, the best solution would be to remove, strip and re-paint
David |
20th Nov 2011, 1:02 pm | #7 |
Birchwood Casey make a product called Aluminium Black which is a black touch up paint for guns. I think there is a pen version too. I've not used it but have a titanium camera on which the previous owner said they had used it and it is a pretty good finish. It dries to quite a 'dark' black. I've used felt pens before on brass and titanium camera bodies with scratches and found they tend to dry with a purplish tint but it is okay on very small scratches.
20th Nov 2011, 5:59 pm | #8 |
Hi
Thanks for all your suggestions , I will probable try a few of these and see which works out best. Cheers MIke |
22nd Nov 2011, 2:20 pm | #9 | |
What I have found effective on fine scratches is a Turtle Wax product which I don't remember the name of. It looks like a lipstick and is basically a wax crayon (black in this case) which fills up minor imperfections. Mitch |
