Old 28th Dec 2017, 6:20 pm   #1
skamanuk
Default Hacker Gondolier sound problem
My Hacker Gondolier has developed an annoying background fault, The machine had had the two 47nf Coupling Caps changed when I got the player. It plays and sounds nice and clear however their is now a strange low level (for want of a better description ) bass pulse. The pulse is regular like someone turning the bass on and off, I have the service details purchased from the site already but need a bit of help tracking down the faulty component. Thanks
skamanuk is offline
Old 28th Dec 2017, 6:36 pm   #2
Edward Huggins
Default Re: Hacker Gondolier sound problem
Sounds like you may have not released the transit screws?
Edward.
Edward Huggins is offline
Old 28th Dec 2017, 6:48 pm   #3
skamanuk
That's exactly the sound I'm taking about wish I had thought of using that as example but sadly that's not causing the fault
skamanuk is offline
Old 28th Dec 2017, 10:18 pm   #4
leslie5555
Does it only do it when a record is playing?
leslie5555 is offline
Old 29th Dec 2017, 12:43 am   #5
skamanuk
Yes
skamanuk is offline
Old 29th Dec 2017, 10:54 am   #6
kirstyd
Cartridge fault perhaps or the arm too heavy. I had something similar once [not on a Hacker ] where the rubber suspension was touching the record
kirstyd is offline
Old 29th Dec 2017, 11:19 am   #7
Edward Huggins
When you re-assembled the unit after replacing the capacitors, do you think part of the autochanger mechanism might now be fouling the motorboard internal cut out? Give the autchanger deck plate a wriggle.
Edward.
