26th Sep 2006, 5:46 pm | #1 |
Bush DAC70 Dial
I know this maybe a long shot,but does anyone have a dial for a Dac70 that has not melted,or a scan of one that i can print and use,can miracles happen? Barrie.
26th Sep 2006, 7:07 pm | #2 |
Re: Bush DAC70 Dial
This archive thread may be of help ........ https://www.vintage-radio.net/forum/...hp/t-9868.html
27th Sep 2006, 10:28 am | #3 |
Re: Bush DAC70 Dial
many thanks Darren-uk .regards Barrie.
28th Sep 2006, 6:03 pm | #4 |
Re: Bush DAC70 Dial
I have an entire scrap set with a good dial if interested
28th Sep 2006, 11:59 pm | #5 |
Bush DAC70 dial
many thanks for help with dial scans from Ray and Dave,only assembly left and to find a space on the shelves.Barrie
25th Jan 2007, 11:08 pm | #6 |
Re: Bush DAC70 Dial
Hello folks. I'm new to the Forum so forgive me if I'm not strictly following the rules. My problem is a dial for my Bush DAC70. It is distorted by heat. Has anyone got a scan of the dial or a dial itself to help my restoration?
Many thanks. Hedley |
25th Jan 2007, 11:34 pm | #7 |
Re: Bush DAC70 Dial
Hi, If nobody offers an original part, PM me your email address and I'll send you a scan
David |
26th Jan 2007, 1:02 pm | #8 |
Re: Bush DAC70 Dial
And don't forget to replace the pygmy bulb with the smaller one for microwave oven cavity fitting or sewing machines, or it'll only melt again!
John. |
26th Aug 2007, 4:00 pm | #9 |
Re: Bush DAC70 Dial
Hi there, I suppose it's a bit predictable really, but I also have a DAC70 which works great but has a burned tuning dial. I was wondering if anyone had a scanned copy of a good one they could let me have so that I can get the radio looking as good as it sounds.
Thanks, Richard |
27th Aug 2007, 4:59 pm | #10 |
Re: Bush DAC70 Dial
Hi Richard,this is the scan i used for my set,hope it helps.
regards Barrie |
27th Aug 2007, 5:14 pm | #11 | |
Re: Bush DAC70 Dial
Using a smaller bulb as suggested by John will make dial damage less likely, as will increasing the size of the dropper resistor feeding the bulb (it is very bright with the original resistor). Some people have tried a diode in series with the bulb, which reduces heat dissipation but does tend to produce visible flicker. Paul |
28th Aug 2007, 5:39 pm | #12 |
Re: Bush DAC70 Dial
Thanks very much for the scan Barrie, it's fantastic and will finally enable me to get my DAC70 looking as great as it sounds. Cheers and thanks again, Richard.
