5th Aug 2005, 8:47 am | #1 |
Grundig TK20 Information wanted.
HELP PLEASE!
I have a Grundig TK20 and the fact sheet with it states the following ¼" open reel analogue recorder ¼ track - ie stereo each direction Stereo DIN line input & output connections DIN microphone inputs and speaker outputs Auxiliary line inputs connections on rear. Separate input level controls for mic and line Replay volume, treble and bass controls 4 Speeds: 7.5 / 3.75 / 1.875 / 15/16 ips = 19 / 9.5 / 4.75 / 2.4 cm/second Maximum spool size: 7" Power requirements: 110 / 220 / 245V AC Have been informed that this is incorrect, I am currently selling it and would really appreciate if someone could clarify the correct spec please. Many thanks. |
5th Aug 2005, 3:35 pm | #2 |
Re: Grundig TK20 Information wanted.
Unfortunately not much is correct in the info stated above :
The TK20 (which is a TM20 with an output stage) is a single-speed (3 3/4 IPS), two-track tape recorder with maximum spool diameter 5 3/4 in. Power supply listed above is correct. EF86 - pre-amp ; ECC81 - two stage af amp; el95 - output ; em84 - indicator ; el95 - HF oscillator and a metal rectifier. I once owned one of these - nothing amazing - it ended up in landfill (after I removed the valves). James |
5th Aug 2005, 3:38 pm | #3 |
And here are two circuits for the machine! From the Tape recorder service manual :
I bought my machine for R20 which is about 1,8 POunds !!!! It was in excellent condition. But then again we do have Uncle Bob up North - sorry a bit OT |
5th Aug 2005, 6:56 pm | #4 |
Other specs taken from Hellyer's Tape Recording Servicing Manual which might be of use to you (and of interest to a buyer):
Power supply: AC Mains, 110-120 and 200-250 volts, 50 Hz, 45 watts consumption approx. Rewind time: 3.25 minutes Wow and flutter: less than 0.25% Frequency Response: 60-10,000 Hz Special features: three digit revolution counter; automatic stop, metal foil operated |
