Old 12th Aug 2014, 10:04 pm   #1
Outrun_uk
Default Ikea LED light / Microscope modification
Hi all,
While shopping at Ikea on Sunday I spotted their JANSJÖ clip on work lamps. As I've been hunting for a better lighting solution for my microscope I thought they would be worth a try (priced at £10 each).
100% impressed with them, nice even light distribution, the clamps are strong and the goosenecks hold their position well. Power supply wall plug is a bit chunky but not a big issue.
Cheers,
Kev
ID:	96108   Click image for larger version
Outrun_uk is offline
Old 12th Aug 2014, 10:39 pm   #2
gingpeakin
Default Re: Ikea LED light / Microscope modification
I use these as well. Watch out as some are daylight (5000k) and some are 'warm' (2700k). I prefer the warm ones but they're equally bright and as useful for spotlighting close work. I also have a stereo microscope for small stuff and they're ideal for it.
Ging
gingpeakin is online now
Old 12th Aug 2014, 10:51 pm   #3
Radio Wrangler
Radio Wrangler's Avatar
I think I'm going to have to get some!
My scope illuminator uses a filament bulb and a big variable resistor. The bulb housing runs hot enough to burn you skin if you brush it.
I have a fibre-optic illuminator and it uses a 200W sealed halogen unit. this thing turns the contacts in the bulb holder to powder!
Radio Wrangler is offline
Old 13th Aug 2014, 9:33 am   #4
threeseven
threeseven's Avatar
Should you not have an Ikea nearby, or like me, would prefer not to visit one (!), they are also available on ebay. There are also other alternatives on the same theme. Use clip on led work lamp as the search term.
BVWS member
threeseven is offline
Old 13th Aug 2014, 11:23 am   #5
newlite4
newlite4's Avatar
I have lost count of the number of times I have been burnt by my Habitat halogen bench lamp. It is difficult to get the light to where you want it without getting too close to the lamp housing. Also, the lampholder connections fail due to the excess heat which is a nuisance. These LED bench lamps would appear to be a solution to these problems.
Neil
preserving the recent past, for the distant future.
newlite4 is online now
Old 13th Aug 2014, 11:46 am   #6
paulsherwin
paulsherwin's Avatar
Useful for sewing machines too.
paulsherwin is offline
Old 18th Aug 2014, 12:38 pm   #7
Herald1360
Herald1360's Avatar
But maybe be wary of ac powered LEDs on rotating machinery- strobe effects. Halogen or GLS filament thermal inertia limits flicker.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 18th Aug 2014, 11:57 pm   #8
MrElectronicman
MrElectronicman's Avatar
I have several of these, but they are desk types with a base. Really great for a spot light on the work bench.
MrElectronicman is offline
Old 19th Aug 2014, 7:24 am   #9
mole42uk
mole42uk's Avatar
I use these as work lights - on the lathe, drill press, grinder and polisher. I think the LED supply must be a high frequency SMPS because I haven't seen any strobe effects.
Richard
Index:
mole42uk is online now
Old 7th Sep 2014, 2:13 pm   #10
camtechman
camtechman's Avatar
Just bought me a pair of these lights and was 'amused' that the plug that connects the light to the psu is a DIN Speaker Plug (1 round pin & 1 flat one) !!
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 7th Sep 2014, 3:54 pm   #11
Herald1360
Herald1360's Avatar
I guess it's a very cheap polarised connector with reasonable current handling. ISTR our outdoor Christmas lights psu uses a screw ring locked version.
....__________
Old 7th Sep 2014, 4:10 pm   #12
That's because (sarky mode on) they don't sound good so are used for other stuff now (sarky mode off), I have some halogen light that also use the DIN 'speaker connector.
Old 7th Sep 2014, 10:26 pm   #13
MrElectronicman
Still on the subject, most of my Ikea LED's have developed switch problems, they are either Rocker type or Push-Push, and the light flickers until you switch it off and then on again. Changing the switch cures the problem
Mine also have two types of plugs, a regular DC coaxial power plug, and the 2 pin DIN type of plug
