3rd Jul 2014, 9:26 am | #21 |
Re: Ambassador 545
Hi Mike
All of this is a massive learning curve for me, thanks for your assistance too! Graham |
5th Jul 2014, 11:47 am | #23 |
Re: Ambassador 545
Hi All
Can I just check something with you regarding buying replacement capacitors, please? As an example, wiping off the gunge from an old capacitor, I can read "0.01 MFD 500VDC". If I am buying a replacement, looking at the Cricklewood website, I would be purchasing Part No.: CFH10NH http://www.cricklewoodelectronics.co...me.php?cat=151 Or do I need to be worried that my old capacitor states "500 VDC", the replacement "630V"? Once again, any advice would be appreciated. Thank you! |
5th Jul 2014, 12:42 pm | #24 |
Re: Ambassador 545
You should replace the old capacitors with new ones of the same or higher voltage ratings, so 630V is fine.
Gus. |
5th Jul 2014, 12:44 pm | #25 |
Re: Ambassador 545
Thank you!
5th Jul 2014, 5:33 pm | #26 |
Re: Ambassador 545
Cricklewood are a good company to deal with. I don't know about prices (they seem reasonable to me?) but they're quick and efficient and they carry the style and spec of components that are used in vintage sets. I've used them several times now, don't bother looking at Maplin etc etc.
5th Jul 2014, 6:54 pm | #27 |
Re: Ambassador 545
Hello,
Me again! May I pick your brains on something else, please? Just struggling to identify some capacitors, and for that matter, resistors. Looking at the system data, just can't quite manage my way around a particular area. Please could you help me with the attached photo? There are a couple of tan coloured, flat components with the legend "LE" or "LEM". How can I be sure of the Voltage required? (I am guessing they are capacitors). Also, the flat brown component in the centre, again, how do I ID the nf and voltage please? I can't read anything on the item. Finally, I think I am missing some capacitors, when referring to the service data. Are the small, stripy fella's resistors or capacitors, please!? Much obliged! |
5th Jul 2014, 7:30 pm | #28 |
Re: Ambassador 545
These flat tan coloured capacitors don't normally need to be replaced. The tubular wax-covered paper ones on the other hand are usually replaced as they absorb moisture and get leaky. Some people replace all of the tubular ones when restoring a set; some replace only the ones which can cause damage if they fail.
The small stripey things are resistors and the brown component will have some sort of code on it, perhaps coloured dots. Gus. |
5th Jul 2014, 8:11 pm | #29 |
Re: Ambassador 545
Thank you, Gus.
May I just check something else, please, guys? So sorry for being a pain. On the attached image, can you see the big, black circular object, pinned to the chassis toward the top of the image? Am I correct in assuming this is an Electrolytic Capacitor, similar to the Philips type, mentioned elsewhere on this website? Also, the brown, flat, object component bang in the middle (hidden by a pinky/orange wire), it either reads 10C or 100, is this a capacitor, please? Thanks once more! |
5th Jul 2014, 9:28 pm | #30 |
Re: Ambassador 545
The blackish thing under the clip does look like an electrolytic. The square black one looks like another silver mica type- probably OK.
5th Jul 2014, 10:32 pm | #31 |
Re: Ambassador 545
I'd undo the clip so as to release the cap, then remove that tape and read off the value of the cap. Someone has added the tape most probably because it was a loose fit replacement. Less likely is that the tape is insulating the can (negative connection) from the chassis. You'd need to refer to the circuit diagram to see if that cap is connected to earth (chassis) or not.
5th Jul 2014, 11:40 pm | #32 |
Re: Ambassador 545
Hi Graham
It looks as if this capacitor is insulated from the chassis and is C26 (8uF) on the ERT diagram. This is part of the AVC delay circuit decoupling. You should find that one lead of this capacitor (the negative end) goes off to the lampholder. If you replace this capacitor you will need to ensure that the replacement is also insulated from the Chassis and rated for at least 350V DC (450 would be better) If you cant get 8uF 10 uF will be fine. Cheers Mike T
6th Jul 2014, 5:50 am | #33 | |
Re: Ambassador 545
Hi Everyone
I am so grateful to you all, thanks for sharing your knowledge! Quote:
Part No.: 8A450 http://www.cricklewoodelectronics.co...me.php?cat=162 And how would I insulate it from the chassis? |
6th Jul 2014, 3:45 pm | #34 |
Re: Ambassador 545
That cap would be fine, but what is the voltage on the old one? it looks like it could be a radially leaded cap? (both leads at one end). If that's the case you may get an 8uF one with a lower voltage (if yours is lower than 450V) that is radial, and so make replacement a tad easier. Whatever, either way, a new electrolytic will be already insulated with a thin plastic sleeve, however I'd put a few wraps of insulating tape around it to stop the clip cutting through and making contact with the metal can. The other thing is, the diameter of the new cap may well be quite a bit less than the clip. If it's not much, just increase the thickness of the cap with tape, alternatively bend the clip so as to make it contact the new cap, or a combination of both. If the cap leads look like they may touch something, then put some sleeving on them to insulate them. You can use the old sleeving if there is any, it's fine.
6th Jul 2014, 7:08 pm | #35 |
Re: Ambassador 545
Thank you, Steve, great advice.
(The old capacitor is rated 450V and has a lead coming out of each end). I'll actually start replacing the old capacitors and resistors very shortly, but, looking well ahead, I am really worried about the 'power unit' - it looks badly corroded. Hope you all don't mind me picking your brains again! However, if my questions suddenly stop coming, you may as well take it I have blown myself up. Thank you all once more. |
6th Jul 2014, 7:27 pm | #36 |
Re: Ambassador 545
1) In that case, the 8uF 450V Cricklewood cap you identified is the one to go for.
2) Ok, give us a photo of what you perceive as being 'the power unit'. Circle around the 'unit' in a photo and we can take it from there. In general, components in vintage wireless sets - such as transformers, inductors, IF cans, speakers and valves - can often look grotty, but mostly they're in good serviceable condition. Conversely, others, like the wax paper and electrolytic capacitors you're changing are more often that not, duff. So, let's identify first of all what component(s) you're referring to and as I say, we can take it from there. |
7th Jul 2014, 2:58 pm | #37 |
Re: Ambassador 545
Hi Steve
Here is a picture of what I am taking to be the 'power unit' (should I call it a transformer??), it is the black unit, slap bang in the middle of the photo with wires coming out from it! Thanks for any advice you can offer, Graham |
7th Jul 2014, 5:35 pm | #38 |
Re: Ambassador 545
Yes that's the mains transformer. It takes mains voltage at 230V AC and transforms it down to various other, lower AC voltages that are needed by the set. I mean, those overheated resistors suggest a problem somewhere along the line with that set. And your mum told you about that smoke the last time it was used. The smoke could have been from the transformer, it could have been from elsewhere. Also, the transformer could have got very hot due to a fault elsewhere, and emitted smoke as a result, but still survived. If you have the necessary meter and data (resistance readings of the various transformer windings) then you could attempt to measure the transformer windings and see what it tells. Personally I think it may be easier for you to replace those caps etc and then fire it up. Ok, if the trannie is no good, then you've 'wasted' money on the parts. But, that's the easier route if you're unsure how to evaluate that trannie. But old transformers don't always look good, they're old gnarly things often!
7th Jul 2014, 6:49 pm | #39 |
Re: Ambassador 545
Thanks Steve,
I will proceed with the easier route, and, if things don't work out, I haven't spent a massive amount of money on parts yet. I am sorry to have to ask for help once more, but I need to replace three resisters that have over heated. On the system data, one is rated 220ohms, the other two, which are daisy-chained together, 440ohms each. I am once again presuming, (eek), that these are the replacements I need: http://www.cricklewoodelectronics.co...me.php?cat=509 However, no idea what the wattage refers to on the Cricklewood page, and if I cannot find a resistor with the exact ohms value as the overheated ones, do I go for higher or lower value resistors? Once again, thanks to anyone who can advise! |
7th Jul 2014, 7:21 pm | #40 |
Re: Ambassador 545
Personally, I wouldn't have thought that 14 Watt resistors were needed in a unit of this type. Old resistors are larger than their modern equivalents, and, whilst I'm not familiar with this model, I would have thought that 2 watt resistors would be adequate (correct me if I'm wrong). As to resistor values, 220 Ohms is a standard 'preferred value', but 440 ohms isn't, 470 ohms is the nearest available to this.
