Old 4th Jun 2007, 1:37 pm   #1
Mike Phelan
Mike Phelan's Avatar
Default Replacing perished grommets on tuning gangs
The usual construction is that the grommet is fixed into a hole on the chassis, or other bracketry, and has a metal sleeve so the screw can be tightened up without squashing the grommet too hard.
These become perished and eventually rock-hard, so their function of avoiding microphony no longer works.
Most available grommets do not have thin enough walls to allow them to go into the annular gap between the spacer tube and chassis hole.
I have have tried using sleeving with rubber washers, O-rings and all sorts of similar things, but with limited success, until I settled on this:
If you select a grommet that is a tight fit in the metal sleeve, and cut it in two, the inner edges will squeeze into the hole far enough to hold the sleeve in position, as in the last picture.
A simple idea, but it does work.
Mike.
Mike Phelan is offline
Old 4th Jun 2007, 3:34 pm   #2
Hermit6345
Hermit6345's Avatar
Default Re: Replacing perished grommets on tuning gangs
That is an excellent tip Mike, it so happens I am doing one at the present and was puzzling about how I was going to do it. Now I know!
Thanks,
Ian.
Hermit6345 is offline
Old 4th Jun 2007, 3:35 pm   #3
newlite4
newlite4's Avatar
Good tip this Mike. I have had no end of trouble with this fixing method. Modern grommets just dont seem to match the dimensions of the originals.
Neil
newlite4 is offline
Old 4th Jun 2007, 4:37 pm   #4
howard
howard's Avatar
Thanks Mike,
Good idea, I'll try that next time I acquire a TR82 with its tuning capacitor flopping around inside (won't be long !) cos modern ones do tend to be smaller and I usually have to add an extra washer to make up the difference in size.
Howard
howard is offline
Old 4th Jun 2007, 6:30 pm   #5
Robert Darwent
Robert Darwent's Avatar
...a TR82 with its tuning capacitor flopping around inside... - Howard
Yes I've got a couple of TR82's like that as well Howard
That's a really good idea Mike, thanks for posting it. Will definitely give it a try!
Robert G0UHF
www.wavesintheair.co.uk
Robert Darwent is offline
Old 4th Jun 2007, 10:34 pm   #6
Phil G4SPZ
Phil G4SPZ's Avatar
Yes, Mike, a good tip, thanks. I've got a Marconi set that needs the treatment so I'll bear your idea in mind. I also have a Garrard gram deck on which the motor mounting rubber grommets have gone hard, and that might be a candidate for similar treatment.
Phil
Phil
Phil G4SPZ is offline
Old 5th Jun 2007, 12:54 am   #7
Tim
Tim's Avatar
I bought a pack of small grommets a couple of years ago from RS or Rapid(can't remember which. ) They are an EXACT match for Roberts R200, Bush TR82 etc.
Tim is offline
Old 5th Jun 2007, 10:48 am   #8
Courtney Louise
Courtney Louise's Avatar
this idea would prolly work for turntable motor mounting grommets too
Andi
33, 45, 78, around and around they go...
Courtney Louise is offline
Old 5th Jun 2007, 12:09 pm   #9
Brian R Pateman
Brian R Pateman's Avatar
Nice one Mike - definitely one for the archive!
Brian
Brian R Pateman is offline
Old 6th Jun 2007, 8:24 am   #10
Mike Phelan
I was actually thinking of that, Brian!
Mike.
Old 6th Jun 2007, 4:12 pm   #11
Aerodyne
Aerodyne's Avatar
So far I've had no problems replacing grommets but I guess my stock is old. Perhaps metrication can be blamed for the differences between old stock and new! Neat idea, though, Mike. I'll store it away in the cavernous space between my ears.
-Tony
Aerodyne is offline
Old 6th Jun 2007, 4:28 pm   #12
Darren-UK
I've also used the same method as Mike, with good results. Modern grommets appear to be somewhat harder than the originals and I used to wonder if this would have any effect on microphonics.....but it doesn't. Saying that, I don't know just how hard of soft the rubber of the 50 or so years old original grommets were when new.
As Andi suggested, this method does indeed work ok on turntable motor mountings.
Darren-UK is offline
Old 6th Jun 2007, 9:03 pm   #13
Sideband
Sideband's Avatar
That's worth trying Mike! In the past I have used grommets with suitably cut washing machine hose washers and also tap washers to make up the difference.
Rich.
Sideband is offline
Old 7th Jun 2007, 12:40 pm   #14
Nickthedentist
Nickthedentist's Avatar
Not OT, I hope...
Are (synthetic) rubber grommets easily available these days? Most I've seen recently are PVC, which although fine for protecting wires where they pass through chassis etc., are too stiff for this kind of thing.
N
Nickthedentist is online now
Old 8th Jun 2007, 10:38 am   #15
Courtney Louise
Good question Nick and one I would like to know the answer too as I have an old battery record player here that the motor needs re grommeting....
Andi
Old 11th Jun 2007, 6:17 pm   #16
telstar
Hi. I might try that idea myself. I have a Philips 290U radio that has perished grommets under the tuning capacitor - it is not easy to work in that compact radio.
Mike
telstar is offline
