Old 17th May 2019, 10:58 pm   #21
SiriusHardware
Default Re: Sinclair Microvision from the NVCF
Originally Posted by Richard_FM View Post
I know Sinclair made some other test equipment, particularly a digital multimeter which used a case from one of their calculators.
That would be the PDM35, and they also sold the PFM200 Frequency meter made in the same 'Cambridge' calculator body as well. I have an 'acquired' example of the former and a from-new example of the frequency meter although that is in very heavily used condition now. I also have a digital storage unit in the same type of case as the SC110 scope and intended as an add-on for it, although that is Thandar branded and I'm not sure if that was ever a Sinclair product.
For a few years I worked as a field engineer, including on door entry systems, and as McMurdo pointed out, the side-entry tube used in the later generation of Sinclair mini CRT TVs was widely used in video type door entry phones which let the tenant see who was at the door. I also had a portable leather cased monochrome monitor - intended as a CCTV engineer's tool - which used the same type of side-entry CRT.
SiriusHardware is offline   Reply With Quote
Old 17th May 2019, 11:52 pm   #22
Richard_FM
Richard_FM's Avatar
Thanks for filling me in, I wasn't sure what Sinclair related test equipment was released.
I have a Sony FD-250B which was one of the last sideways CRT Watchmans. I picked it up at last November's Golbourne meet.
Oddly it has an AV connection but no input for an external aerial.
It produces a sharp picture, but is slightly out of line, which Studio 263 reckoned would be more trouble than it's worth to try to get right.
Beware of the trickster on the roof
Richard_FM is offline   Reply With Quote
Old 18th May 2019, 11:08 am   #23
turretslug
Thanks for that fascinating post- I'd wondered about what went on in these ground-breaking little boxes, it certainly broke the mould.
I'd also wondered about the tube commonality between it and those portable 'scopes that appeared in its wake and the thread at least implies what I had also supposed- whilst a tiny telly is a superficially appealing concept to us tech-heads, I did wonder how many people would actually spend a fair amount of money on something that produced a not-much-bigger-than-postage-stamp-size monochrome picture for a short time on expensive batteries, and with all the vagaries of portable analogue reception from directional signals on a less-than-optimum aerial arrangement.
This sort of thing is now definitely worth preserving as an illustration of what was necessary in the past, though- nowadays we're all accustomed to taking high-definition, bright, colour, moving images on flatscreen smartphones/media players for granted and for near-trivial money.
turretslug is offline   Reply With Quote
Old 18th May 2019, 3:36 pm   #24
merlinmaxwell
merlinmaxwell's Avatar
I was working at Sinclair on the Pandora display (which had the phosphor on the glass front) just before the Amstrad buyout and had loads of the flat screen TVs given to me by my line manager. Gave them all away in the end, the Fresnel magnifier to heighten the picture was particularly awful. I still have a Microvision (first version) TV somewhere.
merlinmaxwell is online now   Reply With Quote
Old 19th May 2019, 9:42 pm   #25
Andy Green
I remember playing with one of these in a shop in Edgeware Road back around 1978. Not a hope of buying one as a 17year old I recall I was interated what I could see what I could get on VHF (nothing in the middle of London!
Andy Green is offline   Reply With Quote
Old 20th May 2019, 1:09 pm   #26
beery
beery's Avatar
Hi Studio 263,
I enjoyed the write up.
Can I ask how you open the case? I have one which is lacking in height slightly.
I also have the later flat screen version and I would say that the battery life of the AA cells in the MTV1B is much longer than for the expensive polaroid battery of the later sets.
Andy
beery is offline   Reply With Quote
Old 20th May 2019, 2:33 pm   #27
AC/HL
AC/HL's Avatar
The old Polaroid instant cameras used these batteries in their film cassette, they just needed a bit of tin foil to "adjust" the contact positions. Plenty of life left after using the film, and they had quite a good storage life.
Bill, BVWS member
Old Yesterday, 11:13 am   #28
Studio263
Studio263's Avatar
There are two screws under the rod antenna, another one hidden under the foam in the battery compartment and one hidden under the stickers opposite the aerial underneath at the back. If you warm the sticker first it won't get ruined when you peel it off (maybe...).
You will have to remove the PCB from the casework bottom to reach the height control. You can wriggle it out once the plastic holder for the speaker has been removed, disengaging the shafts from the line and frame hold makes it easier. Make sure that the tube base wires don't short out on anything and that none come adrift, there are lots of volts up there and the ICs will be ruined if anything shorts.
Studio263 is offline   Reply With Quote
