18th May 2019, 2:43 pm | #1 |
Soundburger popping noise
I recently received a sound burger initial fault was no sound in the right channel but you could hear a slight noise when you switched it on and off over the coming weeks I slowly replaced the capacitors about halfway through the sound started to come through although slightly distorted it was better than no sound at all On completion I finally switch on and after a few seconds a popping noise started coming through the right channel which is affected by the volume
Having assumed I may have a faulty capacitor somewhere I have recently replaced all the capacitors with better quality ones but still have that same popping noise in the right channel The only two I’ve not changed are labelled as 332M Any information would be gratefully received |
18th May 2019, 11:08 pm | #2 |
Re: Soundburger popping noise
3n3, 3300pF probably.
19th May 2019, 1:30 am | #3 |
Yes, but less likely to be causing the noise than other things...
I'd suggest gently warming them, then the transistors in the stages before the volume control, then the resistors associated with the aforementioned transistors to try to pin it down a bit. |
