Old 4th Apr 2018, 11:43 pm   #21
Bazz4CQJ
Bazz4CQJ's Avatar
Default Re: Discussion of subcircuits for homebrew valve testers
Originally Posted by Thatvalveguy View Post
Tube testing itself is not an accurate buisness, due to cathode interactions. most tubes that have been unused for some time will change their readings in the time following the first test, this is due to the composition of the barium surface layer changing.
I guess that it is quite common for some new (old stock) valves to "burn" in appreciably over the first few hours of use. I once burned in an ECC81 over ~24 hours on the 163 as I wanted to use it as a standardised valve. I was a bit surprised to see that one of the two triodes changed appreciably more than the other during that process, highlighting the fact that that way they were made gave rise to significant variations, even with two identical valves in the same envelope. I recently tested an Acorn valve (out of its WWII box) and the Ia on that cycled up and down (by a small but visible amount) for several hours before settling down.
When you start looking at the papers which were published (not the mention the papers that were never published), the enormous effort put into developing and refining valves in the last century is something we no longer appreciate. You could probably fill a modest library with that stuff.
B
Bazz4CQJ is offline
Old 5th Apr 2018, 8:53 pm   #22
Ed_Dinning
Hi Gents, the Philips Technical Library has many books on valve construction, use and applications. It is a great resource as well as having a great many details of valve aging processes and their foibles.
It does however take a lot of research through many volumes to find the gems of information.
Ed
Ed_Dinning is offline
Old 6th Apr 2018, 12:22 am   #23
Argus25
No Longer a Member
Hickock testers[/B]
The hickock units, well their bridge? approach is a nice idea. However it cannot be calibrated by a voltmeter.
Yes it can, except for just one adjustment, the sensitivity of the meter bridge, which is done with their method simply by applying an AC source (which is checked by an AC voltmeter) via a resistor to unbalance the bridge, or with my method using a current sink, which is itself calibrated by a voltmeter, so it could be included inside the unit.
The Hickok TV10 has excellent meter marking in uMhos and scale switching options and is better made than many supposed laboratory grade lab instruments I have seen, so you will be hard pressed to beat it, but it is a good challenge that is for sure.
The TV7 is not quite as good in this respect due to the meter and it was designed more to help technicians in finding serviceable parts. As were some of the domestic style Hickok testers with good/bad pass fail meters which are not laboratory instruments, not to be confused with a TV-10.
The Hickok tester with the additional metering is the TV2.
Argus25 is offline
Old 7th Apr 2018, 2:38 pm   #24
Thatvalveguy
Location: Nijmegen, Netherlands (You know from that bridge)
I never questioned the quality or the user friendliness of the Hickock units, just that their patented approach means that its not as straightforward as a pure DC tester.
Work was started on an electrical prototype for the grid regulator and current measurement unit, the functionality of the grid regulator already being verified in a different prototype.
The other protorype was unsatisfactory, in therms of leakage, power busses ran parallel to the grid current sense circuit, so to en order to avoid allot of problems with leakage a new prototype was needed.
When final electrical testing is complete the last step is to simulate a shorts from G2 to G1 to see if the circuit survives reverse polarity.
One goal was to get the entire bandpass filter, grid regulator oscillator and current sense circuit on one PCB, considering the limited space of a 100x160mm PCB SMD becomes ever more tempting.
The floating current measurement uses an 1k resistor that gives an burden voltage of 200mV full scale, i think i need to take a good look at the RC filter on the input, to avoid the µA meter being influenced by the grid signal applied by the transconductance measurement 1400Hz signal.
Heres some photo's of the first and second prototype, and mechanical prototype.
The mechanical proto has a 10 turn pot for setting the grid voltage, 10 turn pot for calibrating the Gm measurement. One display displays the grid voltage, the other displays either grid current or GM. the aluminium was botched slightly.
The switch switches the bandpass filter between CAL and measurement mode. Because experience shows that contacs become bad after some years all the measurement circuits will use Reed relays for the signals.
The BNC connector is for feeding the measurement signal into the module, this to avoid running long traces to the rear connector, Keeping all the delicate circuits on a module that produces nearly no heat makes sense from a stability standpoint, as styroflex capacitors have a temperature coefficient of around 100ppm
A friend of mine is prototyping a 0-400v flyback module that operates from a 24V rail, perhaps a good idea to see if i can get a PCB to experiment with.
Name:	mechanical proto.jpg
ID:	160637   Click image for larger version
Name:	mechanical proto 2.jpg
ID:	160638   Click image for larger version
ID:	160639   Click image for larger version
ID:	160640   Click image for larger version
Name:	Shunt rev 1.0.jpg
Thatvalveguy is offline
Old 7th Apr 2018, 3:44 pm   #25
Argus25
No Longer a Member
That is a very wise idea.
Another great option there are the small metal cased hermetically sealed miniature relays from Teledyne , sometimes in similar sized cases to TO-5 transistors. They also come in latching varieties and like reed relays are long term reliable and the have low capacitances and many are double changeover types. I used some once to do the band switching for a homebrew shortwave radio and they have never given any trouble, unlike rotary switch contacts exposed to air & dust.
Argus25 is offline
Old 8th Apr 2018, 1:24 pm   #26
Thatvalveguy
Today the current measurement was tested, it seems to work as intended, however the HCPL7800 seems to have quite a bit of output noise, so the ground side differential amplifier will need some RC filtering added like the datasheet suggested.
The most important test was to see if the circuit stayed stable once zeroed by the offset trim of the 411. which is the case, running for two hours the circuit has hardly drifted .1mV which equates to 0,0125µA reading.
The circuit itself, perhaps its wise to change the sense resistor from 1K to 2K to get a 100µA full scale reading, in this way the resolution is higher as most recieving tubes have less then 5µA of negative grid current.
The 411 needs a negative supply to operate, i was thinking of assigning two pins of the header for external 5V 50mA floating supplies for the opamp and insulation amplifier, the negative with respects to output that is required for the opamp could be generated by including a 3V3 zener in the shunt regulator. The 411 need a maximum of 3.6mA supply current, running the shunt at approx 10mA this shouldn't be an issue. The CCS transistor at the bottom should always make sure there is a standing current. if the negative fails, the opamp is going to drive the noninverting input of the 7800 with approximately 1.8V, so better to add a diode from the input to ground, as 1.8V is cutting it close to the 2V input overload figure in the data sheet.
Also the input RC filter will have its -3Db point changed from approx 1Khz to about 200Hz.
I looked at the Thermal characteristics for the TO126 package transistors, those will need cooling at 100V 10mA bias, also that setting itself is beyond the SOA capabilities of the MJE340/350 pair. The 2SA1837/2SC4793 combination seems much better when it comes to safe operating area, but these are tricky to source. For a lower power unit, say 0 to -50V one can simply take BD139/140 and they wont need to be cooled. The junction to free air characteristics of the plastic TO126 package is about 100C/W
Old 8th Apr 2018, 2:41 pm   #27
Argus25
No Longer a Member
You could just go for TO-220 cases and not bother with heat sinks, or easily attach one, like the MJE15030/31 complimentary transistor pair.There are also plenty of TIP series Darlingtons like TIP102/107 that would work if a Darlington was ok.
Argus25 is offline
Old 8th Apr 2018, 3:01 pm   #28
Thatvalveguy
Thanks, i didnt think about that pair, they share pinouts with the Toshiba devices previously mentioned, i bought 100 pairs of the Toshiba's before they went unavailable at my supplier.
Current gain seems a bit low, but they will work.
Here's the changed circuit for the current measurement. Hand drawn of course.
The 47K/22n input RC filter largely rejects, the applied grid signal. From an AC standpoint the 47K is parallel to the 2K resistor because of the RC filtering.
The trim circuit for the LF 411 is not drawn, its the standard data sheet Trim circuit, but with a 50K pot. I was thinking of using a 2.5V shunt reference in the shunt regulator to supply the LF411 with -2.5V. Those IC's have much better temperature coefficient then zener diodes, any drift in the V- rail of the op amp is going to influence the offset voltage. LM336 or LM385 seems like a good candidate.
The oscillator section will have to drive about a 10K load, peanuts for the NE5332 that will buffer the oscillator.
The floating +5V supply for this circuit will have to supply about 20mA.
More to follow!
Name:	2018-04-08 15.39.25.jpg
Old 1st Jul 2018, 2:59 pm   #29
Thatvalveguy
Its been a while since i got around to this project, here is a progress reports of sorts.
The G1 regulator in the form of a shunt regulator has been tested and works as its supposed to. Given that i am planning to do a lot in the analog domain, i thought it better to forego the digital control for the time being. This allows me the space on the 160x100mm boards to do a completely through hole single layer layout so i can etch it myself (and anyone else for that matter)
Given that the unit essentially consists of four or five adjustable power supplies, that need a signal to set their output voltage, and have a return voltage reading and current. My idea was thus to keep the digital sorcery out of the power supply boards and instead use a number of differential pairs to send and receive the analog signals, one could then simply control the entire unit with one card instead of a digital add on circuit for each of the cards. this also allows me to delete the +5V bus. Freeing up two pins on the connector.
The modules themselves will have connections for a ten turn control pot, however including the panel meters on the same front panel is a no-go. because the current panels are 8TE(~40mm) wide. which doesn't allow enough space for a 4 digit 13mm 7 segment display. Using wider panels is out of the question because i cannot etch a backpanel PCB large enough to accept more than 20TE. And having a PCB beyond 100x160mm made is extremely expensive in small volumes.
The interface card that interfaces the supplies with the test fixtures will feature the relay matrix and current sense circuitry needed to run through the different insulation measurements.
Pin connections as it stands.
8 pins (3 through 12 are reserved for the supply outputs) Allowing multiple anode, G2 or G1 regulators in one system. The filament supply board will feature a different H15 connector from the 31 Pin Din connector.
8 pins will be differential pairs, that feature a 2.5V positive offset, this because it simplifies grounding issues a lot. Full scale voltage levels will be 5V. as will the reference voltage.
3 Pins for ground,
Two for +-15V two for +-100V
two pins for external control of relays. this leaves two for adding other options later.
Ive decided to get to work on some of the fixture PCB's required, these are all based on the standard template that i have created in my CAD program. They are wired for specific footprints, or even types. there is the option of building a complete RC coupled amplifier on the double triode boards for measuring Hum and amplification in a real world circuit. Designing a new board for a specific type takes me about 20 minutes. The boards for the dual triodes can accept the entire ECC series and equivalents including the 88 because the sockets are wired manually.
they are designed to accept two identical tubes because i intend to re-use the design in another project. Two pins of the board feature the sense lines for the low voltage heater supply to compensate the voltage drop over the cables.
I've also had some made in china at about 40p each excluding shipping. the silkscreen is a bit messed up because i intended to place all components on the bottom side.
I've also built a +-15V supply card using two 7815 in TO-3. The connector is a H15 connector. the same i intend to use for the heater supply card.
Name:	+-15V reg card top.jpg
Name:	+-15V reg card bottom.jpg
Last but not least, i had a go at making a standard Backpanel this one will be used for testing and checking mechanical dimensions, the final version will feature 6 slots, spaced at 4TE appart, about as large as i can etch with my setup.
Old 2nd Jul 2018, 10:07 am   #30
Craig Sawyers
Craig Sawyers's Avatar
Looking good. Not sure if anyone has mentioned it before, but other valve testers, some homebrew, are;
The Roetest. You buy the circuit boards, custom transformer and CD-ROM http://www.roehrentest.de/index.html . Superbly specified - the rolls royce static tester and curve tracer.
The uTracer, already discussed and linked.
The Hagermann Vacutrace. This was available as a kit, then only as a complete unit, then discontinued. The manual is here along with schematics http://www.hagtech.com/pdf/vacutrace.pdf . It uses a standard transformer, and your own oscilloscope to display the curves.
There was the Sofia - again a superbly specified unit, which ran under DOS. Used boost converters under computer control to generate up to 700V at 250mA on anode and screen. +10 to -150V grid, heater 0-24V at 5A. Long discontinued, alas. Info here http://www.jacmusic.com/Tube-testers...ofia-Index.htm from a person who managed to get one. Rare as hen's teeth.
A new kid on the block is the etracer https://www.essues.com/etracer/index.php . Nice spec. Built and tested circuit board USD200 (nice!) but a mandatory purchase of his control software at USD400! This is not a viable pricing strategy. Wonder how many he sells.
Then there is the Bitmatic. A computerised box that interfaces with a Hikok Cardmatic valve tester to make it into a curve tracer. http://www.tubesontheweb.com/matic.htm USD2,695
And finally, one of the guys on Tekscopes (Dennis Tillman) has designed, and supplies a circuit card, for an add-on to any Tektronix curve tracer to make it into a valve curve tracer. You need a sacrificial valve tester for the heater supply, valve sockets and selection switches and voltage supplies to the circuit
Craig
Craig Sawyers is offline
Old 2nd Jul 2018, 5:51 pm   #31
Thatvalveguy
Ive been following the topic on the Etracer, it looks like a well thought out unit, however beyond the price point of many.
This unit, well ive decided on the DIN form factor because my major pain point with the Roetest was that Large backpanel PCB (Expensive and non customizable). this current setup can be expanded to Seven metered supplies( Assuming heating is DC and one leg is grounded ) for example the G1 regulator card will feature an internal oscillator that can be disabled if required. the Rout of the unit will be 10Kohm, so nothing is stopping anyone from using that card for say DC offset control and superimposing their own AC on that. each bus will have the outputs and rails paralleled between multiple connectors, however all the differential signals are connector specific. and will be connected to a header. or routed to one metering card specific Din socket.
Another card in the making is a simple noninverting amplifier card, featuring +-100V 50mA and a output swing and a BW in excess of 10Khz. with again differential sensing for the current. This one could be used to supply low voltage for supressor grids, or even fast positive pulses for pulse testing tubes.
The supplies HV and high current will get their own back panel with H15 connectors. i went for these because they have the voltage rating to go over 350VDC. the Din 41617 connectors where my choice because i got a bounch surplus for the price of Fish and chips. plus they are more robust in my experience. Din 41612 Connectors tend to have pieces of plastic break off and bend pins, if mishandled. DIN41617 conectors you can just bend them back into shape.
Old 2nd Jul 2018, 6:23 pm   #32
Dekatron's Avatar
I can really recommend you to have a good look at the design of the uTracer (www.dos4ever.com) if you haven't done so already. There are some nice points described in the design of the measurement area - especially the use of the PGA113 when it comes to calibration and programmable gain and also the use of Schottky diodes to protect the A/D-inputs of the PIC-processor (if you are going to use a PIC-processor this is a really important step as over/under-driving the A/D-inputs outside of the tolerances will wreak havoc on the PIC-processor and A/D-inputs and Vref-generator adding an offset to all measurements, just ask Microchip about this!).
The PGA113 requires interfacing to a microprocessor to work, but the simpler PGA103 doesn't but then you won't have the calibration part, just the programmable gain via some binary input pins - a nice ic anyway.
The eTracer describes the use of the AD8479 http://www.bartola.co.uk/valves/2013...tracer-part-3/ which is another nice component to use.
These are SMD-components but placed on adapter boards they are easily exchanged if they release their magic smoke for some reason.
Martin, Sweden
Dekatron is offline
Old 3rd Jul 2018, 7:35 am   #33
FrankB
In my tube collection I have several Military tube boxes with the notation:"Aged 100 hours" on them.
So they were burned in to stabilize the tube for critical circuits.
A co-worker years back told me when he replaced tubes in an electric organ with new ones, he would have to go back and re-tune it in a couple of weeks of use, where with used ones, they were stable once tunes.
FrankB is offline
