13th Aug 2018, 3:24 pm | #1 |
DAC90A (yes another one)
Well I’m not sure this really warrants a success story based on the criteria it’s definitely not unusual or challenging but may be mildly interesting, and I wanted to ask a couple of questions so posted here.
I’ve not deliberately avoided DAC90As but just not that interested because they are so plentiful but when trawling eBay as you do I spotted this cream one which looked complete, unmolested and grubby. It was advertised as collection only and nowhere near me and had received no bids so I messaged the seller and asked if it could be posted. They obliged I paid £47 and thankfully it arrived safely. On inspection it was all complete and original so the restoration (more an overdue service than a restoration and nothing like the quality others on here do) was straightforward. Even the bulbs were serviceable, so I changed componants where required which didn’t take too long, it took longer to clean the chassis and case. The set did have excessive mains hum so I suspected the smoothing caps, but searching this site I found out about the UL41 spare tag issue, I rewired this avoiding using the spare pin and was surprised at the improvement so much so I’ve not replaced the smoothing caps. So a couple of questions... kaylee20s post on DAC90A mods mentions changing C17 (trader sheet 1161) from 0.003uf to 390pf to improve the treble. Personally I don’t find the sound muffled but that may be just my ears but, if I wanted to change this what should the working voltage be? https://www.vintage-radio.net/forum/...ad.php?t=35784 The seller said that the grill was dented but in fact it is perfect but has a discolored section as can be seen on the photos (looks worse on the photo). It seems to have been over polished but I tried polishing the rest to make it the same but it’s no better. Has anyone had success painting these and if so what’s the best match paint for the gold/copper colour? John |
13th Aug 2018, 6:17 pm | #2 |
Re: DAC90A (yes another one)
I have a soft spot for these sets because one of them used to entertain us at boarding school in 1961.
I guess I will never know if it was a 90 or 90A, it could have been either, but I have solved that dilemma by buying one of each at the same auction. Just go for 1000v capacitors and stop worrying I found that Duraglit silvo wadding brought the cabinets up like new with practically no effort. Mine are both mottled brown bakelite though.
-- Graham. G3ZVT |
14th Aug 2018, 6:14 am | #3 |
This set has 2 tone correctors, the usual one on the output tx and C17. I only have the ceramic disc capacitors for small values which I think are 10V, I’ll experiment with these and get a higher voltage one if the change is going to be permanent.
John |
14th Aug 2018, 12:51 pm | #4 |
Yes, you'll need a say 250V rated cap for C17, but at least a 600V cap for C20 (why so high is all explained elsewhere on the forum).
But you could try a 10k pot in series with C20 to adjust its effect on frequency response. Measure the value that gives you the tone you want and replace with a 1 watt fixed resistor. Such a set up is sometimes used as a tone control; a bit crude for the purists, but it works. Just be aware of HT around that part of the cct while fiddling with it! Ian |
14th Aug 2018, 12:53 pm | #5 |
C17 sees less than 100V in normal use.
My own rule is, what happens in abnormal use? If the UBC41 failed then C17 could see full HT, so 250V is a sensible rating. (I actually used a 630V polystyrene from Farnell). Failure of C17 will cause no damage, though. So if you have a 63V, or 25V, capacitor - try it! It will hopefully last long enough to assess any improvement! |
14th Aug 2018, 11:51 pm | #6 |
Thanks for the comments everyone ... I’m happy with sound as it is but may change it just to see if I can tell the difference.
John |
15th Aug 2018, 12:08 am | #7 |
I think it sometimes helps to cut the bass if your speaker cone suspension is passed its best.
-- Graham. G3ZVT |
