Reply
Old 19th Oct 2023, 11:28 pm   #41
ScottishColin
Default Re: Commodore PET 4032 apparent 6520 failure
Here's a video showing one method of wiring up a reset switch:
https://youtu.be/SoRSKqf_R-E?si=y88OEfMVqFYoIol3
And here's a button holder for either a single button or two reset and monitor):
http://tech.guitarsite.de/petcbm_buttonh.html
So it seems there's a couple of choices for the reset switch but I'm still not sure about the Diag (monitor) switch.
Colin.
ScottishColin is offline   Reply With Quote
Old 20th Oct 2023, 1:44 pm   #42
SiriusHardware
Adrian's method is the 'elegant' method of using the switch to manually trigger the power-on reset circuit by shorting its timing capacitor (which in this board looks to be C50, rather than C68 as I guessed earlier).
For the reset switch only, I would get a pair of male-female JST connectors (see attached image) and solder the wire ends of one part to the C50 pads on the underside of the PET PCB and the ends of the other part to the reset switch. If you need to take the main PCB out for any reason you can just disconnect the reset switch by pulling the two connectors apart.
SiriusHardware is offline   Reply With Quote
Old 21st Oct 2023, 11:50 am   #43
ScottishColin
What do you think about using test hook clips as an even more removable solution?
Colin.
Old 21st Oct 2023, 12:09 pm   #44
SiriusHardware
Perfectly OK as long as you are always diligent about putting them back in the right place whenever you have had them disconnected, and you make sure they can only connect to the points you connect them to and nothing else close by.
It's certainly the path of least disturbance to the original structure, and very easily removable if you decide it offends your sense of originality.
Reply
