Old 31st Aug 2023, 8:21 am   #121
ChrisOddy
Default Re: An Enhanced MK14 (MK14E)
Not sure how useful these spare gates are as they are not inverters but buffers ?
ChrisOddy is offline   Reply With Quote
Old 31st Aug 2023, 11:03 am   #122
ortek_service
ortek_service's Avatar
I'd just read they were inverters, from the previous post saying they were.
So may not be quite as useful if only buffers, but maybe no harm in having some zero-cost track / pad options, in case their extra delay / buffering may turn out to be useful to have somewhere.
ortek_service is offline   Reply With Quote
Old 17th Sep 2023, 9:19 am   #123
ChrisOddy
I've just finished building the MK14E VDU board and the picture is looking good, graphics and characters, invert etc working and no jail bars !
Unfortunately I have spotted a problem, the first byte of screen RAM is being written to, $0F which is the default data bus 'value' given that there are pullups on D0-3? Looks like my low risk bit of gate swapping has upset something ! This must be a NENIN timing issue which has been mentioned on the forum before.
Chris
Old 17th Sep 2023, 9:37 am   #124
Realtime
Chris, does your MK14 have a pull-up on nWDS (it's not a standard fit)? I found I had to add a 1K pull up as part of the solution to memory corruption on RealView. Between bus cycles nWDS floats and can result in an unwanted write. Worth a try. I think it was an over site on the part of Science Of Cambridge. Nat Semi reference designs of the day include pull ups on nRDS and nWDS.
Good news that it's working other than that. The on-board character generator is a nice solution to the obsolete DM8678.
Realtime is online now   Reply With Quote
Old 17th Sep 2023, 10:01 am   #125
ChrisOddy
Yes I have 4K7 pullups on NRDS and NWDS on the main MK14E board. I did also wonder about adding pullups on the remaining data bus lines as well, it would at least make them look nicer on a scope !
I'm in the process of reverting my original (replica) VDU as it has several breadboards attached and a host of mods as it was my prototype MK14E VDU.
I should then be able to compare NENIN etc between the two.
I had a look at the circuit and the gate swapping, as far as I can see it should not have made any difference to any delays ?
Old 17th Sep 2023, 8:42 pm   #126
ChrisOddy
Found the problem, it was down to the 4011 NAND gate that drives the NENIN transistor. On my original board I had used an RCA device and by chance picked a Toshiba for the new board and that significantly affects the RC delay ?
Really the whole thing is a bit iffy being dependant on gate delays and then an RC, NENIN could end up anywhere !
Anyway looks like the MK14E VDU is finished so next to see if I can get NIBL-E running and writing to the VDU.
Old 18th Sep 2023, 10:37 am   #127
ChrisOddy
I've been having a further look at the workings of the VDU.
The address buffers are enabled for 32uS for each line during a frame, NENIN is raised ~30uS prior to that to gain control of the bus. I assume this gives time for the CPU to respond by raising NENOUT but of course the VDU ignores that and carries on anyway !
The additional 30uS delay is provided by clock Q2 from the 4040 and is combined with the 32uS enable signal by the 4011 driving the NENIN transistor. However a small glitch occurs between the two, momentarily lowering NENIN, hence the RC to extend the Q2 clock. In fact on my original replica board there is still a very small glitch (~300nS) which I assume the CPU doesn't quite respond to ?
When I used the Toshiba 4011 it must be loading the RC more than a 'proper' RCA device and the glitch extends to nearly 800nS enough for the CPU to take the bus back. Tweaking the value of the C removes the glitch.
I'm still wondering what on earth the 74L86 and double 74LS04 buffers are achieving, the additional delays (50nS and 20nS respectively) are so small as to make little or no difference ? I might have a go at removing them and see . . .
Chris
Old 18th Sep 2023, 10:54 am   #128
SiriusHardware
Sounds like you are intent on taking Occam's Razor to the original design to see just how much it can be pared down. We may never know why the original designer (possibly Nick Toop?) did it the way he did and the approach may have very much depended on availability and knowing Sinclair, cost, of parts.
I suppose the delay following the assertion of NENIN is meant to be long enough to accommodate the longest possible time it will take the SC/MP to get off the bus, so in theory it isn't necessary to look at NENOUT to confirm that it is safe to venture onto the buses, although it would have been tidier and more efficient.
That's interesting to hear about the choice of 4011 being quite critical, though.
SiriusHardware is offline   Reply With Quote
Old 18th Sep 2023, 10:43 pm   #129
ortek_service
Chris
I recall many years ago (Keith Armstrong?) telling us on his EMC courses , that IC manufacturers often did 'die-shrinks', where they re-made original logic IC's etc. using more-modern sub-micron semiconductor processes that (as well as meaning that got more on a wafer, so cost each would be less) meant their performance was also often different.
- Usually 'better' / faster, but the higher slew-rate could then cause EMC problems where the older more-sluggish ones hadn't. But there may be no changes to package markings or the datasheets (if they only state min. speeds and didn't have a maximum).
So maybe the more-modern Toshiba one is responding much quicker to input changes / glitches, although it may also have different / faster propagation delay specifications than the original RCA ones.
Although I do recall even back in the 80's, that some makes of 4000/4500 were required (eg Mullard), as other makes didn't work.
I encountered this trying to use a (cheaper) Motorola MC14534 in place of a Mullard HEF4534 5digit counter in an Everyday Electronics Digital Capacitance project. But when I actually got a 'scope to it, I found they were feeding a rather bad clock waveform to it, so added another buffer gate to square it up, and that seemed to help make it work better so I suspect they too had a rather-marginal 'bad design' and were running things at / beyond the edge of the IC's specifications.
Old 19th Sep 2023, 10:33 am   #130
ortek_service
Chris
It might also be that there is some variation on the exact input voltage, between 1/3 and 2/3 of supply, at which the gates switch between low & high.
My CMOS Pocketbook gives a single 60ns @5V (25ns @10V) propagation delay for 4011's with 16 manufacturers of it listed.
A 4050 Non-Inverting buffer is listed as basically being the same: 60ns @5V (30ns @10V). With a 4069 Inverter as 50ns @5V (25ns @10V)
So all propagation delays quite-short, compared to the 800ns glitch.
Old 19th Sep 2023, 4:14 pm   #131
Mark1960
I try to avoid CD4000 cmos in 5v systems. The propagation times from your cmos pocketbook are quoting only typical times. Max propagation time is more than double the typical time. Also the propagation time does not include the transition time and is only measured at 50% of the supply level, rather than the 1/3, 2/3 logic level input thresholds. Transition time is similar to propagation time so can make a significant difference. RC delays on the input could also cause a problem due to slow input transition time, causing both the input transistors to turn on.
Trying to rely on gate delays when you want a signal delayed is a bad idea, the minimum delay can vary a lot between devices and with temperature. RC delay into schmitt trigger inputs is probably a better method.
Mark1960 is offline   Reply With Quote
Old 13th Nov 2023, 4:49 pm   #132
Phil__G
I was just putting my Retrofest stuff away and looking at the MK14 keypad had a thought - is it time to change Term & Abort to Data & Address?
No?
Ok
Phil__G is offline   Reply With Quote
Old 13th Nov 2023, 6:26 pm   #133
SiriusHardware
It would be good to travel back in time and remonstrate with whoever decided upon those command key legends originally, but they probably made sense for whatever it was that the National Introkit's add-on keypad was originally designed for. (The Introkit's keypad has the same Go, Mem, Abort, Term command keys of course).
As I understand it the aim of the MK14E is to offer an MK14 which:
-Does away with the exotic RAM and PROM memories and replaces them with more mainstream devices so that anyone who wants to can build a functional replica for a much more reasonable price.
-Provides quite a bit of extra memory onboard, which at one time would have had to be added offboard, and allows the memory to be configured in either maxed-out or in a legacy compatible array, with certain of the 'images' retained.
-Makes all the main bus signals available on the rear edge connector (much as the Issue VI did).
-Etc, etc, so it is basically an MK14 'Gti'
-...But is still recognisably an MK14 and immediately usable by anyone who remembers how to use one. So, I'm afraid for the purposes of familiarity and nostalgia, those non-intuitive command keys have to stay.
Old 17th Nov 2023, 11:31 am   #134
ChrisOddy
I've made a start on a QWERTY keyboard for the MK14E.
Bear in mind that this is not supposed to replace the standard keypad but is laid out to simplify reading the matrix and generating ASCII codes e.g. for NIBL.
With a 4x10 matrix its pretty limited what you can do. By the time you take out the 10 numeric and 26 alpha keys, Space and CR there are only 2 left.
I've included two shift keys (left and right) in parallel that leaves one key which could be used for as an additional 'shift' or 'function' key I think like the ZX80/81 ? (currently shown as 'spare')
Chris
Old 17th Nov 2023, 11:51 am   #135
SiriusHardware
I think a lot of the 'extra' characters can just be shifted 'standard' keys just as they are on PC keyboards. ' " ' = shifted '2', ' ^ ' = shifted 6, ' & '=shifted 7, ' ( ' = shifted 9, ' ) ' = shifted 0, and so on. When the presumed lookup tables to convert physical key matrix positions to characters are being developed it would be useful to retain as many of these traditional symbol / shifted symbol pairings as possible so that keytops from off the shelf PC keyboard sets can be used.
Old 17th Nov 2023, 3:54 pm   #136
Mark1960
Adding shift or function keys might mean you need to add diodes to each keyswitch, if more than one key is pressed you might not be able to detect which combination of keys is pressed.
The keyboard input on the MK14 is read using a hex tristate buffer, if the two unused buffers were used you could have a 10x6 matrix. Extend the keypad edge connector by two contacts at one end to stay compatible with existing keypads.
Old 17th Nov 2023, 4:26 pm   #137
Phil__G
Maybe use the same layout as the RC2014 Universal Micro Keyboard, which is also 40 keys?
Old 26th Jan 2024, 7:04 pm   #138
ChrisOddy
I have completed testing of the MK14E and am now content that everything is working correctly. It will run the various games programs that have appeared lately (thanks Ian !), NIBL-E and works with Fast Loaders.
Full details of the project can be found here: https://theoddys.com/acorn/replica_b...14e/mk14e.html
I have a few sets of boards (Mainboard, Backplane, VDU and Expansion Board) available to forum members for £20 and also a QWERTY Keyboard for £5 (UK postage included).
I can also offer a limited number of 8154's at a special price for forum members if purchased with a MK14E - Plastic INS8154N for £15 and Ceramic INS8154D for £20 all Brand New Old Stock.
I also have a couple of early model fully built MK14E's which are working, they just need a CPU and (optional) 8154 fitting. One is an Issue 1 which does not have the Fast Loader connector, the second is an Issue 1.1 which does have the Fast Loader. Both boards have had a couple of diodes and a resistor wired on the back of the PCB to correct an error otherwise they are identical to the current Issue 1.2. I've added some photos of these two boards for those interested, the Issue 1 is missing some logic chips but they will be fitted - £75 ?
Chris
Name:	MK14E Mainboard Issue 1.jpg
ID:	291661   Click image for larger version
Name:	MK14E Mainboard Issue 1 Rear.jpg
ID:	291662   Click image for larger version
Name:	MK14E Mainboard Issue 1.1.jpg
ID:	291663   Click image for larger version
Name:	MK14E Mainboard Issue 1.1 Rear.jpg
Old 27th Jan 2024, 12:16 pm   #139
Timbucus
Chris,
That is great news - I would be happy to take the built 1.1 (too many PCB projects at the moment in teh queue), an 8154 in plastic, a board set (don't really need the computer one though) and a keyboard off you.
I may be struggling with 3D orientation but, how does the backplane allow the VDU (I make a Lukasec repro) to be fitted as it ends up with the connections reversed doesn't it?
Tim
Timbucus is offline   Reply With Quote
Old 27th Jan 2024, 12:28 pm   #140
ChrisOddy
Hi Tim
The MK14E VDU PCB has the same connector and pin allocations as the original MK14 VDU and that lines up with the edgeconnector on an original Mk14. (I wonder why Sinclair switched to a DIN41612 for the VDU rather than an edgeconnector to match the MK14 ?)
Chris
