Old 11th Oct 2023, 9:55 am   #1
Moonferret
Default National Semiconductor - NIBL
Hi Folks!
There seems to be a lot of interest here for National Semiconductor's SC/MP processor and NIBL language. I recently picked up a NS IMP-16 computer that came with a preliminary version of NIBL, dated 11-5-76 (Guessing US date format) It appears to be in NS' RLM format and was probably generated by the SC/MP cross assembler on the IMP-16. Sadly, I don't have the source or the cross assembler but I figured this might be of interest to somebody here.
Dave
Moonferret is offline   Reply With Quote
Old 11th Oct 2023, 12:32 pm   #2
Phil__G
Default Re: National Semiconductor - NIBL
Hi Moonferret, that is a puzzle, its 8k where NIBL is 4k, and unfortunately the image seems to be corrupted, maybe the dreaded 'bit-rot' or maybe it isnt what it says on the tin, it starts out with 160 hex HALTs, there are a lot of blank 00 areas though I can see a few keywords, some of which arent NIBL as we know it... 'PLIST', 'CLEAR', etc. Not sure what it is, will have a better look later. What type of chip is it, a 2764??
Ta for posting though, its all interesting stuff!
Phil__G is offline   Reply With Quote
Old 11th Oct 2023, 12:48 pm   #3
Moonferret
It's a direct read from the paper tape and it does seem correct. However, it is in RLM format so it's going to need a little work to decode to a plain binary file. The additional keywords are interesting though.
Dave
Old 11th Oct 2023, 4:09 pm   #4
Silvester
Odd format (lots of leading zeros and fields of code) but I have been able to extract something which looks very similar to NIBL on my Elektor SC/MP. The .dis text file is from my own disassembler, .bin file is raw data (page 0).
Silvester is offline   Reply With Quote
Old 12th Oct 2023, 5:17 pm   #5
Realtime
Is there a definition of RLM format? I've read it means Relocatable Load Module but can't find any detail of how it's constructed (or is it more about how it's represented on paper tape)?
Realtime is online now   Reply With Quote
Old 12th Oct 2023, 8:06 pm   #6
Silvester
FWIW the format of the file appears to be repeated sections of:
<NUL> <STX> <length> <checksum> <data> <CR> <LF>
Strip all leading NUL's (0x00) until STX (0x02) encountered
<length> byte bits 5-0 is size of <data> section (b7/b6 include extra info)
<checksum> byte is sum of bytes in <data> modulo 256
The data section starts with two bytes: high/low for file (address?) position followed by code (usually 28 bytes per full line)
The length byte appears to set bit 6 for normal lines, bit 7 and 6 set for termination/EOF.
Old 12th Oct 2023, 8:34 pm   #7
Moonferret
The RLM format is described in chapter 6.4 of the IMP-16 programming manual here...
http://www.bitsavers.org/components/...pgmg_Nov73.pdf
Looks like it was originally intended for data stored on punched cards and later adapted for paper tape.
Dave
Old 12th Oct 2023, 8:38 pm   #8
Phil__G
Sorry I had assumed a .bin file was a literal binary from a ROM chip, hence my comments
At 0170 theres a 'start of text' character (02) followed by two 16-bit (record length?) then some SC/MP code - 08 (usual throw-away opcode at zero) C4 10 36 etc... which is indeed NIBL code. Its hard to read manually with all the CR/LF and nulls but it does look like NIBL-P.
Taking the first record, the length (if it is that) 5E D7 00 00 is a peculiar number, whether you take it as big or little endian - you'd expact something magic like 32, 64, 4096 etc.
Peculiar and intriguing...
Old 14th Oct 2023, 11:11 pm   #9
Michael Haardt
Moonferret: I could recover the source from changing the earliest version I had. Would you mind if I include the image from the papertape in my NIBL collection and if it is ok, give credit to who?
It looks like the variable layout was quite different in this version, there are some bugs and the random number generator worked differently.
Michael Haardt is online now   Reply With Quote
Old 14th Oct 2023, 11:28 pm   #10
Phil__G
Have you decoded the RLM Michael?
Old 14th Oct 2023, 11:37 pm   #11
Michael Haardt
No, but Silvester did so a few posts ago. I used that binary.
Old 23rd Oct 2023, 8:30 am   #12
Michael Haardt
I updated nibl.tar.gz at
http://www.moria.de/tech/scmp/software/
to include the restored source for the pre-release. If you are curious what exactly has been changed, now a diff of the source can answer that.
