9th Jul 2018, 1:37 pm | #1 |
Identfication required: Vintage Octal Adapter
Hi. Can someone please identify this octal adapter and what it would be used for? Thanks.
9th Jul 2018, 2:14 pm | #2 |
Re: Identfication required: Vintage Octal Adapter
Maybe if the two sockets go to pins 2 and 7 it's to access heater volts?
Otherwise someone will need actually to recognise it!
9th Jul 2018, 7:13 pm | #3 |
Have you checked which pins are connected to the two on the top?. Also check if any other pins on the octal end are shorted. Many jukebox and other amps used the speaker plug to short the centre tap of the HT transformer winding to earth to remove the HT to protect the o/p transformer if the speaker plug was removed.
9th Jul 2018, 9:00 pm | #4 |
I'd be tempted to unscrew the screws and have a look inside!
Andy |
9th Jul 2018, 9:11 pm | #5 |
Xtal socket?
Lawrence. |
9th Jul 2018, 9:18 pm | #6 |
Go for it with a continuity buzzer before you bother with opening it up.
It looks pristine. |
16th Jul 2018, 10:01 am | #7 |
It looks identical to some of the oddball sockets I got with a used Digital readout Chinese Tube Tester. The set of adaptor sockets came in a beautiful wood case.
