Old 28th May 2018, 12:20 pm   #1
oscillophile
Default Trio CS-1830
Hi. I was reading this thread and I was wondering if someone can help me solve this problem that I have:-
https://www.vintage-radio.net/forum/...d.php?t=114750
I made this video where it shows the problem. Hope this will help to narrow down what's going on:-
https://youtu.be/uSpN-nM2llU
Thanks in advance.
oscillophile is offline
Old 17th Jul 2018, 3:17 pm   #2
1980s_john
Default Re: Trio CS-1830
I hope you got this sorted.
Your Youtube video shows a bright spot when scope is in X-Y mode. Try moving the spot using the two position knobs (left-right and up-down arrows). In other modes the timebase drives the X (horizontal) movement of the spot, as per the 'Trio CS-1830 Oscilloscope' thread you need to set the Norm/Auto switch to Auto to get a trace with no input applied.
Regards,
John
1980s_john is offline
