9th Jan 2018, 11:48 am | #1 |
Unusual Switch Panel
Just wondering if there's anyone that knows what this item might be? It looks to be perhaps 1950's (a guess) but I'm not sure if it's related to early radio or computing or what. It's approx 180mm x 115mm with no identifying marks. It's well built so it might be have military connections. Thanks in advance for your help.
9th Jan 2018, 3:22 pm | #2 |
Re: Unusual Switch Panel
Four twelves and a multiplier of three, most odd. I want to know too.
9th Jan 2018, 6:06 pm | #3 |
My first thought was that it was 12 numbers, each between 0 and 29999. But I don't recognise what it was for.
9th Jan 2018, 6:21 pm | #4 |
It does have an early 50s computing look to it, but that's just a guess.
9th Jan 2018, 6:41 pm | #5 |
I recall vaguely-similar-looking things being found 'under the cover' on old electromechanical punched-card machines.
[pre-computer there were a vast range of punch-card machines designed to perform a whole slew of different tasks - sorting, collating, searching, simple arithmetic and logic]. |
9th Jan 2018, 9:52 pm | #6 |
Given that each set of "switches" has only one set of terminals I wonder what is inside it? possibly resistors?
My only thought was some kind of early "programmable controller", if say it was wired back to a set of rotary switches then worked like this. Switch A, controls the bank marked 0,1,2. another switch controlled the other banks, so if say you select 0 on switch 1 and 4 on switch 2 then you'd get different resistance values than if you selected say 2 on switch 1 and 1 on switch 2. maybe the different values made the machine do different things depending on what was selected. I've seen some really weird stuff from back in the day before microchips, it was very clever stuff but you had to wonder about the mind of the inventors, still they do say that genius is only 1 step away from madness. |
11th Jan 2018, 11:46 am | #7 |
Hi
Thanks for the suggestions so far. I've checked as best I can and there does not appear to be any other components inside, just the switches. I seem to remember it came to me in a box with some aircraft parts dating back to 1940's but I'm sure it cannot be related to that. |
11th Jan 2018, 12:03 pm | #8 |
It looks like there are only three PCB tracks associated with the 0-1-2 column and ten tracks associated with the 0 to 9 columns. It would be interesting to know how these are connected to the switches, if indeed they are simple switches.
11th Jan 2018, 1:34 pm | #9 |
Just a wild guess, all 0's, 1's, 2's, etc in each column are connected together, slider connection at the back of the panel, sliders are ground/chassis
Lawrence. |
11th Jan 2018, 1:58 pm | #10 |
If I've worked it out correctly, the number of combinations is (10^48)*(3^12).
I don't think there's enough connections to represent all these conditions. Perhaps the board is designed to be viewed visually and the electrical connections serve a secondary function?
11th Jan 2018, 10:05 pm | #11 |
The brass terminal studs are similar to those used on telecom
apparatus here.
Steve Dow VE7ASO |
11th Jan 2018, 10:55 pm | #12 |
Hi, unfortunately I can't help with what it is or was used for but as the letters only go up to 'M' I would guess that there may be a similar panel with the letters 'N' to 'Z'.
Just a thought, presuming a full set of letters of the alphabet might the switches have been used to create some kind of "secret" code perhaps to be sent over telegraph wires/equipment, with decoding at the far end? (Maybe I watch too many spy films ) Regards Andrew |
11th Jan 2018, 11:25 pm | #13 |
I too have seen too many spy filums. My first thought was the same as yours, this is Board 1, and Board 2 is missing in action. The sheer amount of crusted verdigris suggests a marine environment, and the lack of any other identification marks could be significant. It does look like a small part of a basic encryption system..Probably peacetime, it doesn't look complex enough for wartime unless it was used in a non-critical (or closed circuit) role.
12th Jan 2018, 9:15 am | #14 |
Thanks again
I did send the same photographs at the end of last year to be checked by Bletchley Park and they came back last week with a "not known" reply. He did think it might be early computing related so suggested the National Museum of Computing - which I have not tried yet, or to post on one of the Vintage Electronics forums. If I get a chance at the weekend I'll see if I can dismantle the panel without causing any damage and I'll take some pics of the internal construction. |
12th Jan 2018, 10:35 am | #15 |
I had a similar thought Andi but there's not a full set. The 'I' is missing so presumably the 'O' would be missing also, confusion with '1' and '0', or am I over thinking it and there is a much simpler explanation?
Dave G1AGK. My perception is my reality! Last edited by davidw; 12th Jan 2018 at 10:36 am. Reason: spelling. |
12th Jan 2018, 12:13 pm | #16 |
Didn't spot the lack of letter 'I'
I now think it might be a control panel for a backlit desk mounted or wall mounted map grid, a more sophisticated modus operandi than the well known fighter command table where little wooden models or blocks were poked around with sticks. The multiple columns of letters might operate lamps of different colours behind the milk-glass grid. Could be continental which might explain why it hasn't been identified yet. |
12th Jan 2018, 1:37 pm | #17 |
The letter "switches" appear to move over a plain background with no electrical contacts visible. If the background moved with the switch it would intrude into adjacent switch windows.
I wonder if the electrical connections are to backlight the panel itself? Some tests with an ohmmeter whilst moving the switches could prove interesting. From the picture it's very difficult to see where the PCB tracks go to. They all seem to head for the top of the board.
12th Jan 2018, 1:40 pm | #18 |
The nature of the switches suggests it isn't meant to be operated very often, they look a bit fiddly. It looks more like a vintage version of DIP switches.
Kevin |
12th Jan 2018, 1:49 pm | #19 |
Possibly for programmable machine tools?
PMM |
12th Jan 2018, 2:03 pm | #20 |
Train Describer?
