12th May 2019, 11:32 am | #1 |
OC1615 as AF115, AF116, AF117 replacement
Just a note that there are some OC1615's available that have a similar specification to the tin whiskered AF11* and they seem to work fine as direct replacements and are cheap. They have metal can screening but are narrow and tall with a different pinout (underside view clockwise from tab e, b, c, can).
12th May 2019, 10:03 pm | #2 |
Re: OC1615 as AF115, AF116, AF117 replacement
Alltransistors reckons lower Ft (35MHz rather than 75MHz) amongst other details......
13th May 2019, 12:40 am | #3 |
I won the pack of 10 × OC1615 that was on eBay when you posted, so I will have a few to spare at £1 + postage if anyone wants
- Julian It's good here |
13th May 2019, 9:28 am | #4 |
They are used in continental sets as FM mixer/oscillators. In the set I put them in, the 472KHz IF was still exactly peaked and showed plenty of gain. Not sure I trust the specifications for Ge transistors as apparently all AF11* and AF12* are identical?
13th May 2019, 7:14 pm | #5 |
There have been various discussions about equality or otherwise of the AF11x and 12x devices. I think the outcome was that they may have had some selected characteristics in early batches but later on, they were all "good" enough so it was just a labelling exercise to keep them in line with the earlier recommendations as to which to use where.
Quite possibly those OC1615s have rather better Ft than the minimum spec for the OC615 (the only data I could find). If they work, just use them........
