13th Jan 2019, 4:54 pm | #1 |
HMV 2011 with BSR TC8H cartridge.
Hi, I have a BSR UA8. After reading threads on here I am going to fit the SC11M cartridge in it. What I wanted to know is if anybody has a way of keeping the TC8 turnover bit to keep it looking the same. Maybe glue or something, any ideas?
13th Jan 2019, 6:04 pm | #2 |
Re: Bsr tc8h
The other thing. Do I wire the SC11M in series or parallel?
13th Jan 2019, 7:17 pm | #3 |
Re: Bsr tc8h
There is a difference of about 750 mV in output level between those carts. Unless you use a preamp an SC11 won't be loud enough. Very common scenario with these old players. Sadly there's a dearth of high output crystal/ceramic carts. An x5H would be a good choice but when they turn up they're pricey. The preamp option is probably cheaper, then you can use any ceramic.
Regards, Ben. |
13th Jan 2019, 9:04 pm | #4 |
Re: Bsr tc8h
Does that mean I shouldn't bother changing it then Ben. It's on a push pull amp. what cartridge can I use for stereo records, or is it only the x5h. I thought the sc11m would be OK
13th Jan 2019, 9:27 pm | #5 |
Re: Bsr tc8h
If the player (make? model?) came to you with a TC8H then you'll need to fit something comparable in output, basically. As things stand the only drop-in replacement would be the x5H (mono, but stereo compatible). But do let us know what player this is.
In these situations I usually cover the hole at the end of the arm with a piece of similar coloured insulation tape or similar. Attempts to glue in the new cart to the existing turnover mounting may give you problems with tracking angle.
Regards, Ben. |
13th Jan 2019, 9:34 pm | #6 |
Re: Bsr tc8h
I put a record player up on here that needed work but no takers as it had a bar monarch deck thought I would just check it has a x3h in it would that be any good see photo
13th Jan 2019, 9:41 pm | #7 |
Re: Bsr tc8h
That X3H would be a good replacement and is stereo compatible.
13th Jan 2019, 9:47 pm | #8 |
Re: Bsr tc8h
Thank I'm now glad I didn't get any takers for the record player I may just swap the cartridges over so the tc8 goes on the monarch deck
13th Jan 2019, 10:42 pm | #9 |
Re: Bsr tc8h
I'm not quite sure about where this thread is going? What type of record player does this relate to? If it's, as you say, to drive a push-pull amp, then the extremely rare BSR TC8H or a BSR X5H, will not be needed. You need a medium output stereo-compatible cartridge and still (just) available.
Edward. |
14th Jan 2019, 1:42 pm | #10 |
Re: BSR TC8H cartridge
Sorry just realised that the cartridge is a tc8m brown one sorry for that Ben I was just looking at photos on internet
14th Jan 2019, 1:47 pm | #11 |
How about telling us what the player is? Many makes and models had BSR decks.
14th Jan 2019, 2:13 pm | #12 |
Oh sorry I thought I did put it in post it's a hmv 2011 which I believe is a push pull amp. I haven't taken the old cartridge out because I'm not sure what records to play on it. My first thought was about putting a plate at the end of arm so I could maybe attach the flip bit to it so it looks original. But then it got on to changing cartridge then without thinking I put H instead of m
14th Jan 2019, 2:23 pm | #13 |
Re: HMV 2011 with BSR TC8H cartridge.
If you do a search on here there's a whole description with pictures I believe of a modification that someone did with fixing a more modern cartridge into an old BSR TC8 bracket, probably exactly what you want to do. I can't remember who it was or when it was, but it was perhaps within the last several years. I haven't done a 'search' myself, but I'm sure you can use the 'search' button at the top of the page to find it. Someone else may even remember the thread and point it out, or even the original poster may read this thread and link to it.
14th Jan 2019, 2:29 pm | #14 |
Yeah that's what I thought but couldn't remember
14th Jan 2019, 2:40 pm | #15 |
The cartridge specified in the service sheet for this player is a TC8M. The audio has a triode pre-amp followed by a triode phase splitter followed by two pentodes in push-pull.
14th Jan 2019, 3:47 pm | #16 |
OK thanks Graham does that mean I replace with sc 11M cartridge
18th Jan 2019, 7:48 pm | #17 |
I'm sorry for being a nuisance I have wired the new sc11m connected the cables as in photo, it all works OK but trying to find out how much loss in volume it should be. The volume knob rotates 3/4 of a turn from 0 to full. If I play the radio at about 1/4 turn to get the same volume on a record it's about 1/2 a turn.
Mark |
18th Jan 2019, 11:04 pm | #18 |
That's just about right. The new cartridge will not have as much output as the original.
Edward. |
