26th Dec 2017, 9:57 pm | #1 |
Beogram 1000 amp compatibility.
Hi all.
I'm finally thinking of expanding my B and O set up. Currently I'm running my Beogram 1000 through a very cheap electrovision pre amp. I have found a Beogram 2600 amp and tuner. Will this be good enough to do away with my preamp and cope with the tiny output signal from my Beogram 1000? Are these amps/ tuner ok and what should I be looking out for? Many thanks. Dave. |
26th Dec 2017, 10:12 pm | #2 |
Re: Beogram 1000 amp compatibility.
The Phono stage on the B&O 2600 has a RIAA equalised MM pre-amp in-built. This will be ideal to serve your Beogram 1000. No need for an external pre-amp.
Edward. |
26th Dec 2017, 10:29 pm | #3 |
I can't see why not as the 2600 has the usual magnetic cartridge input.
Spec here: https://www.beoworld.org/prod_details.asp?pid=395 No more to say. A. |
26th Dec 2017, 10:36 pm | #4 |
I like this idea as I get the tuner and tape player too. Many thanks.
Dave. |
26th Dec 2017, 11:14 pm | #5 |
27th Dec 2017, 11:24 am | #6 |
Remember that B&O designed their amps around 4 Ohm speakers, So you'll be a bit down on their advertised power if you have 8 Ohm ones. Shouldn't be too noticeable.
27th Dec 2017, 11:59 am | #7 |
I was going to also purchase some Beovox speakers of the same era. This means everything will be compatible and will be a nice little period set up. If I get the correct speakers I will achieve max performance. If anyone can suggest some nice B and O matching speakers? The amp is rated at 2x25 watt.
27th Dec 2017, 12:34 pm | #8 |
Now the proud owner of the Beocenter 2600. Will let you know when it arrives. The rabbit ear aerial needs a repair. Wires have broken free out of the two pin connector. Looks though there is option for a normal coax too though.
