Old 28th Jun 2014, 10:12 pm   #1
Neil Purling
Default 1 valve radio with Russian sub-minature valves
I wondered how many people have used these Russian 'pencil' valves. There are several types of course, but I bought 1J24B. Has anyone built anything with these ?
It could have been an old circuit adapted to using the sub-minature valves.
What I have managed to establish is my choice of component is happiest with 45V HT.
What's right for the filament supply? I have goodness knows how many NimH AA cells.
They seem about 1.2V at full charge. I can't remember what the filament current drain is off-hand, but I can easily wire more AA cells in parallel.
I was wondering whether the Electron-Coupled design can be re-designed to use the Russian valve at 45V HT with regeneration by varying the screen voltage.
I have done stuff with conventional 6.3V pentodes like the EF39, but nothing with low-voltage valves. The DF9* series can be a bit pricy. I got the ten Russian valves for the same price as one DF91.
Neil Purling is offline
Old 28th Jun 2014, 10:19 pm   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: 1 valve radio with Russian sub-minature valves
Michael Watterson over on VRAT has done a lot with these including replacing D series valves.
Just be warned he's very enthusiastic about the Russian Rod Pentodes
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 28th Jun 2014, 10:45 pm   #3
Neil Purling
Cobaltblue: I don't suppose that the person you named posts here too..........
VRAT won't allow you to even read the threads without registering. There's an interesting link to a circuit on another site, which you can't view for the same reason. I guess I would have a few questions for Mr Watterson.
Old 28th Jun 2014, 11:38 pm   #4
brunel
brunel's Avatar
They can all be read, without login in.
http://www.forum.radios-tv.co.uk/vie...entodes#p87618
brunel is offline
Old 29th Jun 2014, 8:32 am   #5
Cobaltblue
Cobaltblue's Avatar
He used to post here under the name Neon Indicator so it might be worth rooting out some of his old posts.
You should be able to see all but members only areas.
You can also contact Michael via RadioMuseum if you are member there.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 29th Jun 2014, 3:28 pm   #6
VT FUSE
Hello Neil,
a search on this forum would yield the secrets,try searching: Russian Military Subminiature "Pencil Tubes"
All the info there.
Best wishes.
VT FUSE is offline
Old 29th Jun 2014, 3:29 pm   #7
Neil Purling
I have sent an e-mail to Mr Watterson. He may have some interesting insights if I get a response.
