Old 13th Sep 2018, 9:57 pm   #1
GSBX1220
Default Telephone style microphone ID req
Hi folks
I have a telephone style microphone that is in fantastic condition. I found it in a box of bits in the loft. I think it's a Pye unit. Does anyone know what type of microphone insert it has in it? It also has a 6pin connector on it.
ID:	169283   Click image for larger version
Richard
GSBX1220 is offline
Old 13th Sep 2018, 10:23 pm   #2
Jon_G4MDC
Jon_G4MDC's Avatar
Default Re: Telephone style microphone ID req
That looks like Pye Whitehall or very close.
Both inserts by A.P.Besson most likely.
The Red/White striped one in the Mic is almost certainly same as Westminster AM series, Green White is more or less same as Telephone Earpiece ex a GPO Telling-Bone handset.
If you want to use that Mic insert for FM, use it as it is, or if a bit harsh sounding then put 100n across it.
Worked for me.
PS. The plug is not original... but expect you knew that already
Jon_G4MDC is offline
Old 13th Sep 2018, 10:23 pm   #3
Well, that's a NATO stock number on the back- might lead somewhere.
Poke it with a DMM and see if it's resistive. If it is, it'll be dynamic, if it's open circuit, probably crystal. Either way it should click when prodded.
Can you look at it with a 'scope?
Herald1360 is offline
Old 13th Sep 2018, 10:42 pm   #4
GSBX1220
Hi
Yes, I did poke it with a meter & it is resistive. 47 ohms. There is also an electrolytic capacitor in series with it For some reason.
Richard
GSBX1220 is offline
Old 13th Sep 2018, 10:42 pm   #5
Jon_G4MDC
Jon_G4MDC's Avatar
Just spotted it has a curious electrolytic added - for sure not original.
Probably means it has been modified to work with something that sends a polarising Voltage to an electret + preamp.
No Pye Whitehall ever needed that - goes well with the Jap mic connector though.
Old 14th Sep 2018, 6:02 am   #6
G3VKM_Roger
G3VKM_Roger's Avatar
My notes on this type of insert say Red with White Flash: 300 Ohm microphone, presumably dynamic. Green with White Flash: 300 Ohm earpiece.
Roger
G3VKM_Roger is offline
Old 14th Sep 2018, 8:27 am   #7
ex seismic
The style and inserts are standard Larkspur although they were green not black. The plug of course isn't military.
ex seismic is offline
Old 14th Sep 2018, 12:04 pm   #8
Resistive 47R sounds about right for nominal 300R impedance.....
Old 14th Sep 2018, 2:40 pm   #9
CambridgeWorks
CambridgeWorks's Avatar
Pye PMR mics often had a plain aluminium colour insert with impedance of 2400 ohms.
FM had 3 tiny holes, AM more larger holes like in your red/white example.
However, just to confuse, early fm also had several of the larger holes as well. They were sought after for amateur use rather than the 3 hole ones. Maybe someone remembers their part number?
I think AM had "M4BZ2400" printed on the back.
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is offline
Old 14th Sep 2018, 2:44 pm   #10
russell_w_b
russell_w_b's Avatar
D.C. blocker? It'll be a 'rocking-armature' unit (higher Z than the receiver rocking-armature unit) and stands to be polarised beyond use if there's a constant direct current through it.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 14th Sep 2018, 2:57 pm   #11
russell_w_b
You may find this useful:-
Regds,
Russell W. B.
G4YLI.
Old 14th Sep 2018, 10:28 pm   #12
Biggles
I may be wrong but I think the Marconi RC690 might have used that combination of plugs and handsets in Police vehicles. The Whitehalls used a square multi pin affair (Jones plug?) which went into the back of the control head. As far as I remember I think the Whitehall may have had a balanced mic input circuit.
Alan.
Biggles is offline
Old 15th Sep 2018, 2:37 pm   #13
The handset itself looks very similar to the ones used with the HF RACAL TRA931 (Syncal30) and the TRA967 low-band VHF manpack (though the plug is obviously non-standard).
Note that the wiring of the audio-gear on these RACALs, though using a 'Clansman audio' type plug, is different to the Clansman wiring. Guess who found this out the hard way?
Old 15th Sep 2018, 7:17 pm   #14
russell_w_b
It's the same handset as used on the former MOULD radio transceivers too.
Regds,
Russell W. B.
G4YLI.
Old 15th Sep 2018, 10:59 pm   #15
Sparky67
Sparky67's Avatar
I think the handsets used on the Police / Fire RC690s (etc) were similar but with a PREH-type plug, which was fully shielded (no plastic bit sticking out at the end). Also think the Westminster-series mic plugs were the same...? Some earlier sets (Whitehall, Vanguard, Cambridge etc) used the larger 6-pin Painton plug. Same audio inserts though. Didn't the Mould Pegasus use an Amphenol handset connector, similar to the Clansman-type? If the connector on the handset in the photo has a screw-up securing ring, rather than a bayonet type, it looks like it would mate with the socket type on an amateur-type radio.
Martin
Sparky67 is offline
Old 16th Sep 2018, 8:41 am   #16
russell_w_b
As I recall, yes. But the handset in the O/P picture is fitted with what looks like a plug for an amateur transceiver or CB radio. Been modded, maybe?
Regds,
Russell W. B.
G4YLI.
Old 16th Sep 2018, 9:16 am   #17
Sparky67
Sparky67's Avatar
It’s certainly a possibility... It could also have been used with an amateur / commercial HF radio adopted for use by the military perhaps. The RAF used a number of re-badged different Icom HF radios. Or somethin else completely different! Just due to numbers it’s likely to be a (modified) ex-Police or Fire Service handset, they used thousands of these S G Brown (later Racal Acoustics) handsets. Unless the OP has more info I guess we will never really know...!
Martin
G4NCE
Sparky67 is offline
Old 17th Sep 2018, 8:09 am   #18
G8BBZ
G8BBZ's Avatar
This looks like the handset used with the Ptarmigan communications system. The handset is a little larger than the similar tactical handset used with the Larkspur range of systems and many others. The inserts are the standard dynamic type manufactured originally by STC. Red/White is the transmitter (microphone) and Green/White is the receiver (earphone) There is also a Red/Black which is a carbon mic. The dynamic inserts are nominally 300ohm impedance. These handsets were manufactured by Racal Acoustics, who bought S.G.Brown, the original manufacturers. The plug is not original.
Peter G8BBZ
G8BBZ is offline
Old 17th Sep 2018, 9:29 pm   #19
GSBX1220
Hi
The connector is the 6pin type found on some amateur gear. The microphone seems to be wired in a balanced configuration with the white and green wires being individually shielded.
I have since first posting this, I have re terminated the plug and used it on 2M SSB. I was told it sounds rather toppy and lacks lower frequencies.
Richard
GSBX1220 is offline
Old 17th Sep 2018, 11:11 pm   #20
A mike designed for professional communications work is unlikely to have much output outside the 300-3000Hz range. Putting signal energy into low audio frequencies doesn't improve intelligibility and just wastes transmitter power. If you want the audio to sound good, use a suitable mike.
