Old 1st Apr 2020, 6:22 pm   #21
SiriusHardware
Default Re: How do I get this wheel off my radio tuner
Originally Posted by Outrun_uk View Post
Never knew the wiper puller tool existed!
There is another common variation on those which also marketed as a car battery terminal puller, example here:-
https://www.amazon.co.uk/dp/B07GB126RM
While that one would also have potential uses for pulling flywheels etc off, it has a rather broad end which would probably put pressure on the flywheel rather than on the shaft. But it could find uses elsewhere in our hobby.
SiriusHardware is online now
Old 2nd Apr 2020, 11:08 am   #22
Emibell
Originally Posted by vinrads View Post
Nope ! I still don't get it why removing the flywheel would give you better access , removing the shaft as well maybe. Mick.
I want to see the underside of the pcb and possibly re-solder a joint but I don’t want to totally dismantle the amp.
At the moment the wheel is stopping the back plate moving backwards. If I remove it the back plate will move a little further back as the hole the shaft runs through is a bit oversize. That will allow a little more access. If I wanted to get the back plate off completely there is no way without removing the wheel.
Emibell is offline
Old 3rd Apr 2020, 1:54 pm   #23
vinrads
Ah! now I understand thank's for clarifying it , did you manage to remove the flywheel yet? Mick.
vinrads is offline
