22nd Nov 2022, 11:18 pm | #1 |
Vidor Radio model 396A
Hi from Australia, I recently purchased a Vidor 396A from EBAY. When the case is opened and the chasis removed there are two springs on the left side screwed to the case. It seems when the lid is closed the hinge shorts these two springs. Can someone advise what the springs are for. There are two wires leading from the springs to the chasis. Radioneil
22nd Nov 2022, 11:29 pm | #2 |
Re: Vidor Radio model 396A
Hi Radioneil.
Can't remember this exact model but it usually caused the set oscillate (Howl) when the lid is closed to remind you that it's still switched on. Cheers Mike T
23rd Nov 2022, 12:55 am | #3 |
Hi Radionell
If it’s any help I repaired one of these sets a few years ago. Write up here: https://www.vintage-radio.com/recent...or-cn396a.html I think there is a brief mention of the squealer, and how it works.
23rd Nov 2022, 11:53 pm | #4 |
Hi Tim and Cobaltblue, many thanks for your help. Radioneil
14th Dec 2022, 11:59 pm | #5 |
Vidor 396A
Good Morning all, I have now got it working. The problem I have is that I can't turn the volume right down. Just wondering if any one has had a similar problem. radioneil
15th Dec 2022, 12:57 am | #6 |
Re: Vidor 396A
I have one.
It's the same, sound is low at minimum setting but still quite audible, it's a good feature when running on battery power as it saves you leaving it switched on! |
15th Dec 2022, 7:19 am | #7 |
Re: Vidor 396A
Thank you G.Castle, It makes sense now. radioneil
