2nd Nov 2022, 7:06 pm | #41 | |
Re: Goodbye to the Fax machine.
They use 150 volts, so can give you a surprise if you touch the pair in damp conditions!
2nd Nov 2022, 7:35 pm | #42 | |
B |
3rd Nov 2022, 4:25 pm | #43 |
It's probably about service level guarantees. It may well be possible to work round some or all future interconnecting difficulties, but they have to assume that many people will just plug and play and complain if it doesn't work as expected. We're used to unthinking backwards compatibility, but that may not always be possible going forward.
3rd Nov 2022, 11:02 pm | #44 | |
3rd Nov 2022, 11:47 pm | #45 |
The fax machine was one of Tim Hunkin & Rex Garrod's machines in their original series. They show details of the handshaking around 21min into the video.
https://www.youtube.com/watch?v=yuUyt9RG7pk
Kevin |
4th Nov 2022, 1:27 am | #46 |
Pictures sent to earth from an early Russian moon landing were transmitted back to earth and received by Jodrell Bank. Someone who had worked in the newspaper industry recognised them as being in an early type of fax format, and not having a fax machine themselves, they borrowed one from the Daily Express, which then had a world scoop by publishing the pictures before the Russians.
https://www.skymania.com/wp/daily-ex...-moon-landing/ Last edited by emeritus; 4th Nov 2022 at 1:34 am. Reason: typos |
4th Nov 2022, 3:17 am | #47 | |
Back in the day, faxes could be sent via analogue mobile phones just like a voice call. Then GSM digital mobile phones replaced the analogue ones. GSM introduced compression. Analogue voice is digitised, compressed, sent over the network and converted back to analogue at the other end. This prevented faxes from being sent as voice calls. You may have noticed, if you've listened to music on hold on a mobile phone, that it doesn't sound very musical. A bit garbled or distorted. That's because the compression was optimised for speech. It also stops faxes getting through. There was a method for sending faxes over GSM mobile networks. You needed a PC with a GSM fax modem attached, or a phone with one built-in, and a data cable and PC Data Suite software. I actually did this around the year 2000. Faxes were sent / received from the PC in entirely digital form. They travelled digitally over the GSM network, with a flag indicating they were faxes or data, not speech. At the other end, if the destination number was a landline, the mobile network converted the data into analogue audio and passed it onto the landline network where it reached the recipient's fax machine. If the recipient was another GSM mobile, they would also need a PC cable and data suite software to receive it. Or a few mobile phones had a built-in fax decoder. I had the Nokia 9000 Communicator which was like a mobile paperless fax machine. You could also send and receive email and browse the Web, as well as make phone calls, all from a brick-sized device. It seemed amazing at the time. Of course it quickly became outdated. Now that traditional copper phone lines are switching to VoIP it may not be possible to just plug in a fax machine and expect it to work. A solution like the GSM case above could be implemented, where faxes are sent as uncompressed or lossless data over the internet and converted back to analogue tones at the receiving end. But the extra expense of additional equipment / adaptors could be the final nail in the coffin for the old fax machine. |
4th Nov 2022, 9:15 am | #48 | |
4th Nov 2022, 10:04 am | #49 |
The history of the Fax is intriguing, in the 1920s there was the Fultograph, which you hooked to the output stage of your radio, it used paper dosed with potassium iodide and starch.
The BBC transmitted some Fultograph pictures as an experiment. Fultograph was also used in some of the early WWII submarine detection systems on board destroyers.
4th Nov 2022, 10:20 am | #50 |
A slight skew of the topic but I remember testing out the DiskFax when it was first developed, instead of paper you inserted a floppy disk dialled the remote DiskFax and the data on the disk was sent and duplicated on the floppy disk in the receiving machine see http://www.computinghistory.org.uk/det/15814/DiskFax/ never caught on though!
4th Nov 2022, 11:53 am | #51 | |
The telephone had a sticker on it to remind us to send at the cheaper afternoon rate if at all possible. The phone also doubled as our office phone from the switchboard. Digressing slightly, in this situation, where only one person could sit at his desk and use the phone (by turning around), six of us sharing it, and it often tied up sending or receiving a sheet, I think back on how concise work briefs to us were, and the instructions to and from outside suppliers the same. Once handsets appeared on every desk, and telephone time became cheaper, the constant queries, the “I forgot to tell you that...” and the “Can you just...” became the norm. The first plain paper fax machine of the type more familiar arrived in the office in 1983. |
4th Nov 2022, 2:01 pm | #52 |
Most of the comments I was going to make, particularly about the viability of using a fax over a DACSed line or over VoIP have been covered by other posters.
Many early Group 3 machines, even the humble BT CF9, had a "Voice contact" button to indicate on the LCD display of the distant machine to "Lift Handset". In this way (with a little discipline from both operators) one could conduct a mixed FAX & voice session without redialling. The feature was removed from most later models. As for Nick's mention of the Telecopier, Panasonic called some of their models "Telefacsimile Transceivers" But the best FAX anecdote was when I went to a large Police station to service some. I noticed a machine that was sending/receiving documents that included mug-shots, the machines had a good "halftone" feature but that wasn't in use, so all the photos came out as silhouettes (yes, I know). I suggested it might be worth the extra page transmission time and use halftome.
-- Graham. G3ZVT Last edited by Graham G3ZVT; 4th Nov 2022 at 2:25 pm. |
4th Nov 2022, 3:38 pm | #53 |
I had forgotten one aspect of the Telecopier. We had to phone first and make voice contact. We would say what speed we were using and then one operator would cue the other. On hearing the signal you pushed the button and the drum started spinning.
4th Nov 2022, 5:04 pm | #54 |
I'm going to have to get out the circuits book, IIRC that 'connect' button on the telecopier was on the mains side of the power supply and effectively turned the thing on. That would then energise a relay which disconnected the telephone and connected the unit to the line. Alas my machine is missing the line interface module (possibly removed to prevent it being connected to a telephone line back when the GPO had a monopoly on such things)and I've yet to build a replacement.
The 2-speed feature was provided in a somewhat odd way. There are 2 motors. One drives the drum and is contolled by a custom MOS ic (yes, at that time!), the other moves the carriage and is a simple mains synchronous motor. Electrically the speed switch simply reverses that motor. On top of the motor is a complex gearbox, with a gear on a floating bracket. When the motor turns one way, the output spindle turns at the slow speed. When the motor turns the other way the output spindle turns at the fast soeed in the same direction as before. |
4th Nov 2022, 11:17 pm | #55 | |
5th Nov 2022, 7:22 pm | #56 |
I seem to recall the Home Office DTels. running tests using MuFax over Fire Brigade VHF radio systems. Maps and plans of destinations could be sent to fire appliances whilst they were on route. I think it all worked well - until....
The system was tried in an Arabian state, where results were disastrous. The heat had dried out the impregnated paper, causing no results. I don't recall whether the system was ever used widely in the UK. Chris R |
5th Nov 2022, 8:38 pm | #57 |
My friend who was in the fire service until the late eighties, certainly talked about such a system being introduced on their appliances. I may have it wrong and it was text only but it certainly sounds like this.
5th Nov 2022, 8:45 pm | #58 | |
I love the smell of Shellack in the morning. |
5th Nov 2022, 9:08 pm | #59 | |
Rather more than a decade ago now so I don't remember the details, it was reported that there was a new development in Braille. An MP was keen to see an example, and asked if a sample could be faxed to him. |
6th Nov 2022, 11:00 pm | #60 | |
