Old 18th Sep 2022, 5:23 pm   #1
Scotch24A
Default RCA AR88 Comms Receiver. Audio output problems.
My AR 88 will not adequately power a 2.7 ohm speaker, but does give satisfactory
volume with headphones- does this mean the output transformer is blown or should I look elsewhere?
I have recently changed the c119 capacitor and moved the connection from chassis to terminal 3 of the output transformer but this has not made any difference.
Scotch24A
Scotch24A is offline
Old 18th Sep 2022, 5:34 pm   #2
Station X
Station X's Avatar
Default Re: RCA AR88 Comms Receiver. Audio output problems.
The easy way to find out is to conduct continuity tests on the output transformer windings.
If it's OK then take voltage readings from the output stage.
Graham. Forum Moderator
Station X is offline
Old 18th Sep 2022, 6:37 pm   #3
HamishBoxer
HamishBoxer's Avatar
Not convinced the transformer is at fault, do not normally fail like this.
HamishBoxer is offline
Old 18th Sep 2022, 6:44 pm   #4
ms660
ms660's Avatar
On some of the AR88's the loudspeaker is connected to the output transformer via a set of contacts on the headphone jack socket.
Lawrence.
ms660 is offline
Old 18th Sep 2022, 6:44 pm   #5
deliverance
A bad 6K6GT.
deliverance is online now
Old 18th Sep 2022, 6:45 pm   #6
Radio Wrangler
Radio Wrangler's Avatar
It is most often the primary which fails open circuit, and then you lose everything.
Primary suspect is therefore the speaker muting contacts on the headphone socket.
Radio Wrangler is offline
Old 18th Sep 2022, 6:46 pm   #7
Radio Wrangler
Almost perfect synchronism...
Old 19th Sep 2022, 9:49 am   #8
G6Tanuki
G6Tanuki's Avatar
What impedance speaker are you using? I've seen several AR88s where the output-impedance of the 'speaker' terminals was designed for 500/600-Ohm wired-network speakers; hooking a 3-Ohm speaker to one such wired will give very feeble audio.
[I was caught myself with this issue on a Collins TCS12 receiver I bought as a kid; eventuially I figured out what the issue was and replaced the output trANSFORMER WITH ONE DESIGNED FOR MORE-NORMAL SPEAKER IMPEDANCES]
G6Tanuki is offline
Old 19th Sep 2022, 5:03 pm   #9
Scotch24A
Thanks for all your suggestions.
Scotch24A
Old 20th Sep 2022, 8:43 am   #10
wd40addict
wd40addict's Avatar
I have the matching AR88 speaker. These days I use it with my RA17, but when it arrived it contained a 600/4R transformer (now bypassed).
wd40addict is offline
Old 28th Sep 2022, 9:29 pm   #11
Scotch24A
I’ve tried plugging in a “good “ 6y6gt with no improvement.
There is continuity across the output stage to T2(terminals 1,2-2,6-1,6). but not across terminals 3,4;although I can detect a resistance of 650 ohms across 3,4.
I haven’t found a problem with the headphone socket.
How do I check the voltage from the output stage and what do the results signify.?
Anything else to be considered.
Thanks
Scotch24A
Old 29th Sep 2022, 10:06 am   #12
ms660
ms660's Avatar
For "continuity" do a resistance measurement....less confusion.
The continuity function on most meters is only good up to a certain circuit resistance value, anything above that value won't indicate circuit continuity.
As far as I can make out from other commentators, the primary resistance of the original transformer was between 500 and 600 Ohms.
Lawrence.
ms660 is offline
Old 29th Sep 2022, 11:18 am   #13
HamishBoxer
Must say, I have never known an output transformer cause low sound in over 60 years. Has the headphone socket been cleaned, as they can tarnish and will cause problems?
Old 29th Sep 2022, 4:34 pm   #14
Scotch24A
Thanks everyone;so it’s possible that the output transformer is not at fault?
Scotch24A
Old 29th Sep 2022, 5:49 pm   #15
turretslug
turretslug's Avatar
Check that the noise limiter is switched out, just in case this circuit is in some way faulty. There are quite a few things that could cause low level audio, but this is a quick and easy step in the elimination sequence.
turretslug is offline
