Old 9th Mar 2019, 7:50 pm   #1
Deltatango
Deltatango's Avatar
Question Sharp XL-HP500 help
I wonder if anyone can give me some help with an old Sharp XL-500 which has blown its output amplifier again.
It uses a STK402-071 module which blew the original part, this was changed along with power supply and other electrolytic capacitors as some of its small ones had puffed up, I thought it best to change the power supply caps to ensure even + and - rail charge up.
Just hope now if anyone has ideas on this problem
Many thanks from Davidt
Name:	Sharp XL-HP500-a.jpg
ID:	179651   Click image for larger version
Name:	Sharp XL-HP500-b.jpg
Deltatango is offline
Old 9th Mar 2019, 9:41 pm   #2
tri-comp
Default Re: Sharp XL-HP500 help
Davidt,
Did you replace ALL electrolytic cap's around the chip ?
They are:
C901, C902, C909, C910, C913, C914, C915, C916, & C925.
And then there's the obvious:
Did you check your speakers ?
A shorted out tweeter or two will put a heavy load on the IC when the volume is turned up.
Shorted speaker cables will also make the life difficult for an output-IC.
The less obvious:
Due to insufficient mechanical cooling of the chip,
Sharp installed a volume-level dependent blower circuit to cool the IC when under high volume load.
Technics did the same in some of their receivers and the motor faulted.
Possibly because a parallel electrolytic cap. across the motor became defective.
The Sharp-circuit, even if a lot simpler, works in the same fashion.
Here the parallel-cap. is of course C930.
Rgds,
/Torben
tri-comp is offline
Old 21st Mar 2019, 12:57 am   #3
Deltatango
Deltatango's Avatar
Sorry for my late response but those capacitors were changed with its original fault as some had puffed up plus diodes and transistors in that area.
Got a better spec sheet detail on that range of IC and it shows a curious shift in supply voltage +/- 50v maximum, +/- 44v with 6 ohm load, then recommended voltage of +/- 30v for 6 ohm load. Well this unit has a 37v +/- supply line, I found some engineers who made the comment that they got fed up at times if these IC's popped a bit often (playing loudly) so changed it for the next module IC up.
I intend to get that cooling fan more involved on a constant level setting it to spin at some speed that cools without making too much noise but allowing it to speed up if required.
Many thanks so far from davidt
