28th Jan 2019, 2:48 pm | #1 |
What was this for? Indicator Type74
No pictures, this item was dismantled 50 years ago....
About 1965 I bought an "Indicator type 74" from New Cross Radio in Manchester. It cost 25shillings. The unit was a very well made grey plated steel chassis and case. The oil filled "mains" transformer input was 180volt 400c/s. A VCR139A/ECR30 (N.B.electrostatic deflection)tube and a few valves including an 807 which appeared to drive a rather crude scanning coil around the tube. This coil was on a c-shaped laminated iron former about half way along the tube but was not close fitting. I have puzzled ever since as to what this unit was made for . It seemed far too heavy to be fitted in an aircraft , the most likely source of 400c/s power. Has anyone any ideas or even seen one,New Cross had a pile of them,maybe you also bought one? Bill |
28th Jan 2019, 3:30 pm | #2 |
Re: What was this for? Indicator Type74
This would appear to have been used with various ground-based radar sets including the 'Light Warning Radar'. I don't have the relevant Air Publications, they may be available at TNA Kew, I can find some references if you want to dig deeper.
Andy |
1st Feb 2019, 11:44 am | #3 |
Thanks Andy. It was the unusual E/M deflection coil with an E/S deflection tube that I found a bit odd. Are there other more common instances of this? Vaguely related to this, I have an NOS CV262/9MD6 radar tube which is magnetic deflection. If this was for a PPI display, I think the scanning coils would be motor driven, rotating round the tube neck?
Bill |
1st Feb 2019, 12:22 pm | #4 |
Some early PPI displays did use a motor-driven coil assembly on the CRT; later ones used static coils and electromagnetic sine/cosine synchros - a kind of three-phase transformer with variable coupling - that took their information from similar devices attached to the PPI scanner.
1st Feb 2019, 12:55 pm | #5 |
Wartime airborne radars such as H2S Mks I to III used an electrostatically scanned CRT (typically a VCR517) with the PPI signals derived from a sine-cosine resolver (Magslip) mounted on the scanner assembly, rotating with the aerial 'mirror'.
Magnetically scanned tubes came in post-war with H2S MkIV fitted to the Avro Lincoln. A 'slow-burn' project of mine is to assemble a complete H2S MkIIB system. Andy |
1st Feb 2019, 12:59 pm | #6 |
Just to be clear, a sine-cosine resolver is not a three-phase device. It has a two-phase output with the two phases 90 degrees apart.
Andy |
1st Feb 2019, 1:38 pm | #7 |
I had a quick look on the VMARS site without finding anything from the Index Search but they seem to have items not necessarily listed. As a specialist Military Group it's worth asking. They were very helpful to me last year and a member even took the trouble to visit the archive in person and dig some info out for me!
Dave W |
