Old 25th Oct 2014, 9:29 am   #1
arjoll
arjoll's Avatar
Default FM aerial
This probably won't seem much to many here (especially the amateur radio guys) but I'm quite pleased with how it's looking so far!
Our analogue switch off was last April, and with the switch to digital our VHF aerial (for NZ channels 1, 3, 5, 7 and 11) became obsolete, as all digital TV is UHF only. I took the aerial down in May, and since then have been intending to modify it for band II FM. Reception of some stations in the house can be a little scratchy, and I've got enough RG6 around the place for FM feeds where required.
A technician friend pointed me at this article, written by an old colleague of his when he was working at BCL (now Kordia).
His aerial was in far better condition than mine - which after 11 years in an exposed position no far from the coast was missing half of one of the reflectors and had plenty of oxide around the joints. With a little effort I dismantled it completely, and found that some of the band III components were in pretty bad condition. Fortunately the band I bits (other than that reflector) weren't too bad.
The article mentions DAB, but really it's a no-starter here. There were trials in Wellington by Kordia (and it sounds like they're still going), but other trials were of HD Radio which is favoured by commercial broadcasters. There's no real push to any kind of digital radio, so I'm not planning for it.
So, to date I have cut down the folded dipole, director and reflector and mounted them on the original boom, which has been cut down to size. The original balun seems ok - I'd be interested in feedback here on any possible tests for it. The F connector seems to have kept the water out, even though the boot was perished and the coax has been out in the weather unterminated for over a year, the insulator and female portion of the connector on the balun appear in pristine condition.
If the weather is fine tomorrow I'll see if I can track down a new U bolt and mount it on a spare barge mount I have lying around. I'm mounting it vertically, but will mount it from the end of the boom so hopefully it won't affect performance too much.
I've attached three pics - the aerial in use and undamaged, in "storage" against the workshop (the bent reflector was from when I threw it down from the roof!), and the band II modification.
I know that many here have quite an attachment to the "405" VHF aerials still around the place, but they're not particularly rare here - very few have been taken down so far - and after 3 years of crystal clear 1080i on three channels and 576i on the rest, no co-channel interference from Wellington or Obelisk, no static I don't really have much nostalgia for analogue TV!
ID:	99185   Click image for larger version
ID:	99186   Click image for larger version
arjoll is online now
Old 25th Oct 2014, 10:04 am   #2
Nicklyons2
Nicklyons2's Avatar
Default Re: FM aerial
A neat job and it should, hopefully, work well. I've got an old Ch 10 VHF array, slightly pruned, to try & get passable DAB reception which I've yet to put up. I just think there's some satisfaction in recycling and re-using; the modern way seems to be to throw any amount of money at a job and buy new - but anyone can do that. Another point is that many new aerials have elements so thin they're nearly foil, at least the older ones do actually have some metal in them.
Nicklyons2 is offline
Old 25th Oct 2014, 10:17 am   #3
Nymrod121
Nymrod121's Avatar
I have detailed notes on the dimensions of the "Fuba UKA Stereo 8" (OEM = Hans Kolbe: Bad Salzdetfurth) if anyone is interested ...
Best wishes
Guy
Name:	UKA 8 post-refurb_02.jpg
"What a depressingly stupid machine." [Marvin: HHGTTG]
Nymrod121 is offline
Old 25th Oct 2014, 10:37 am   #4
Jonster
That should work well, looks like those aerials are well made, I am in NZ at the moment and those multi band arrays are still everywhere!
It's hard to get decent BII arrays in the UK now, I was going to order an Antiference 5 ele for the loft the other day only to find they have been discontinued! Might have to make something up myself.
Jonster is offline
Old 25th Oct 2014, 11:07 am   #5
Nicklyons2
Nicklyons2's Avatar
Jon, there may be one in my mate's barn; I'll try and remember to have a look next time I'm up there. PM if it's of any interest otherwise I'll forget and I'll lose this thread,
Nick
Old 25th Oct 2014, 1:51 pm   #6
I can't help thinking the
Originally Posted by Nymrod121 View Post
Fuba UKA Stereo 8
shown could do better higher up. Aerials are one of the last things that are easily built with good results and money savings.
Old 25th Oct 2014, 1:55 pm   #7
paulsherwin
paulsherwin's Avatar
Theres a big difference between loft and external aerials though. Loft aerials can be built from bits of wood and wire and will last indefinitely. Externals need to be highly weather (and bird) resistant.
paulsherwin is offline
Old 25th Oct 2014, 3:19 pm   #8
The (usually) larger diameter of the tube needed for an outside antenna does increase the bandwidth. I do remember seeing a UHF (400MHz or so) folded dipole with the element diameter of 40mm or so just for this reason.
One other difference is that is much harder to fall off a loft.
Old 26th Oct 2014, 7:37 am   #9
arjoll
arjoll's Avatar
Here it is, in situ. It works, and it works very well - good strong/clear signal on all the Hedgehope and Forest Hill stations, clear signal lock on Life FM from Mid Dome, a handful of Invercargill LPFM stations and - this one surprised me - Life FM and Cave FM from Gore. The site there is tucked in on the other side of a hill, so shouldn't really hit here at all. That's all on a basic Samsung Bluray home theatre system with an FM tuner as an afterthought.
Next step is to sort out distribution to FM tuners, so I'll lose a bit of signal in splitters, but I'm quite happy with how it's going.
Old 26th Oct 2014, 11:22 am   #10
Nymrod121
Nymrod121's Avatar
Originally Posted by merlinmaxwell View Post
I can't help thinking the Fuba UKA Stereo 8 shown could do better higher up.
I agree ... but as you'll see by the photo, it's the lack of a coaxial cable which is the real show-stopper
arjoll, that's a very good job - congratulations on getting such a worthwhile improvement for minimal outlay!
Best wishes
Guy
Old 1st Feb 2020, 11:50 pm   #11
Nymrod121
Nymrod121's Avatar
Best wishes
Guy
Here at long last (!) is a summary of dimensional information relating to the Fuba UKA Stereo 8, also some annotated photographs - all of which I hope will be of help to anyone interested in a restoration or perhaps a build-from-scratch project.
There are several gaps in the detail, most notably the precise dimensions of the plastic saddle clamps which in most cases will need to be replaced by metal equivalents. Also, the construction of the dipole connection box with 300:75 ohm balun is something that I still haven't got finished!
I hope it's of interest.
Best wishes
Guy
(PS - thanks to Bill - AC/HL - for reopening the thread for me )
Name:	Fuba UKA Stereo 8_dimensioning drawings_001.jpg
ID:	198185   Click image for larger version
Name:	Fuba UKA Stereo 8_dimensioning drawings_002.jpg
ID:	198186   Click image for larger version
Name:	Fuba UKA Stereo 8_dimensioning drawings_003.jpg
ID:	198187   Click image for larger version
Name:	Fuba UKA Stereo 8_dimensioning drawings_004.jpg
Old 2nd Feb 2020, 1:58 pm   #12
Nymrod121
Nymrod121's Avatar
Some pics of the home-made dipole I built for the intended 'clone' (which is obviously a long-term project!).
The connection box is a standard electrical item and the balun came out of a Maplin 'back of radio, 300 ohm balanced-to-75 ohm unbalanced' adaptor.
When substituted for the Hans Kolbe-original dipole, the overall performance of the antenna was not as good in terms of overall gain as compared by reference to 'before and after' signal levels on a meter-equipped tuner (I have no way of measuring directivity/E&H patterns).
Hope this is of interest/help.
Best wishes
Guy
ID:	198212   Click image for larger version
ID:	198213   Click image for larger version
ID:	198214   Click image for larger version
