22nd Jan 2022, 12:11 pm | #1 |
Desoutter Drill
G’day All,
My brother and I have gotten our hands on a drill that my grandfather owned, possibly acquired around the 1930’s. I’m located in Australia if that makes any difference. I’m trying to find more information about it and it’s potential value when it’s fully restored. At the moment I only have a photo of the plate on it, waiting for my brother to send more. Very limited other information, but I do know that he worked on aircraft during the Second World War. Would anyone be able to tell me anything about it based upon the plate in the photo? Thanks Michael |
22nd Jan 2022, 1:17 pm | #2 |
Re: Desoutter Drill
Another photo of the actual drill. The stand is not properly matched to the drill, it’s just a Black & Decker made in Australia.
22nd Jan 2022, 1:22 pm | #3 |
Re: Desoutter Drill
Hi Michael
Your drill is for 'normal' ac mains. It probably has a rubber-covered cable which is probably perished, and which will need replacing (the body MUST be earthed, so you'll need 3-core cable). Most people here run metal-bodied drills though a plug-in earth leakage breaker, so you don't end up holding something which just became live. You may find that the carbon brushes have had it (I have had a couple where they are missing altogether) and you may have to adapt some new ones to fit - carbon is soft and can be filed to shape. All this is a labour of love, since after all that the drill might be worth 30 quid on a good day - if you search UK ebay sold listings you'll find numerous similar 'Wolf' brand drills to compare. Hope that helps Mark (edit - it mentions an oil-filled gearbox, meaning this is a low-speed drill. This is useful for larger holes in steel - something modern drills (plug-in or battery) can be rather poor at, since they often don't have much torque at low speed.)
"The best dBs, come in 3s" - Woody Brown |
22nd Jan 2022, 1:26 pm | #4 |
Re: Desoutter Drill
Desoutter are still on the go, but overall, they are better known for their compressed-air driven tools.
22nd Jan 2022, 2:33 pm | #5 |
Re: Desoutter Drill
I didn't see your second pic - looks like someone may have broken off a rear 'D' handle to get it to fit the stand. If that's the case, leaving it attached to the stand may be the most useful thing you can do with it!
22nd Jan 2022, 3:11 pm | #6 |
Re: Desoutter Drill
Same family as the Desoutter aircraft people, but different company.
https://www.***********/photos/368442...mEJbXs-2mENrYF
Kevin |
22nd Jan 2022, 4:38 pm | #7 |
Re: Desoutter Drill
From memory, DeSoutter stopped making electric drills in the mid-1970's and concentrated on their air-powered ones. I remember a display ad in a newspaper advising customers that manufacture of their electric "little horses" would shortly cease, and if you wanted to buy one, there wasn't much time left.
22nd Jan 2022, 6:36 pm | #8 |
Re: Desoutter Drill
This appears to be the same model:-
It sold for $5 in NZ last year. https://live.lipscombeauctionhouse.c...electric-drill Cheers |
23rd Jan 2022, 12:53 pm | #9 |
Re: Desoutter Drill
Yeah, regrettably the value fully restored would be very close to the 'barn find' value...and both are these are pretty low. In the UK a few people have made old metal bodied drills into steampunk lamps, and they are quite the most top-heavy ridiculous looking things.
Were it to be restored i second Mark's comment about an earth leakage circuit breaker, preferably one that is 'en bloc' with the mains plug so that the drill can't be used without it. ---If you get even a trace of that volcanic ash on your car windscreen in Queensland, don't for christ's sake operate the wipers. Hose it all off then clean the wiper blades with a wet rag. Even a trace can damage the glass.-- Dave |
29th Jan 2022, 8:42 am | #10 |
Re: Desoutter Drill
Thanks for all the comments. Thankfully its value as a family history piece is worth something, because I’m pretty disappointed with its market value if I were to ever sell it ��. I would have thought an 80 year old working drill might be worth a bit more.
And don’t worry Dave, the closest that volcanic ash came to us was 42,000ft up. |
30th Jan 2022, 7:38 pm | #11 |
Re: Desoutter Drill
Those desoutter drills used to be very popular in a sheet metal factory I worked in (student job) in the mid 70's. They merrily spend hours repairing them and reckoned they were really good. I found them difficult to hold thanks to the shape but OK for drilling.
