Old 16th Sep 2018, 11:10 am   #1
Kentode
Kentode's Avatar
Default What's this? A quiz.
I bought this three weeks ago for 50p! I had my suspicions but had to wait until today to have a closer look.
Someone may know exactly what it is, but if not I'll post a further picture which will give the game away.
Made of plastic although the pictures make it look like metal.
Have fun!
ID:	169368   Click image for larger version
ID:	169369   Click image for larger version
Regards, Ken.
BVWS member
Kentode is offline
Old 16th Sep 2018, 1:45 pm   #2
Outrun_uk
Default Re: What's this? A quiz.
Air Ioniser (probably miles off!) ?
Kev
Outrun_uk is offline
Old 16th Sep 2018, 2:41 pm   #3
Kentode
Kentode's Avatar
Correct, you are miles off!
Regards, Ken.
BVWS member
Kentode is offline
Old 16th Sep 2018, 2:47 pm   #4
elanman99
elanman99's Avatar
Looks like a 3 pole 4 way switch amongst other things.
Air sensor of some sort, maybe temperature or humidity.
Ian
elanman99 is offline
Old 16th Sep 2018, 5:06 pm   #5
Kentode
Kentode's Avatar
Ian, you're out there with Kev!
Two more pictures and l should point out that there should be a mains cable going in.
ID:	169405   Click image for larger version
Regards, Ken.
BVWS member
Kentode is offline
Old 16th Sep 2018, 5:29 pm   #6
Radio Wrangler
Radio Wrangler's Avatar
A tourist memento, a miniature replica of the tombstone of the phantom twiddler. The real one is in storage, unused. We just haven't caught him yet.
Radio Wrangler is offline
Old 16th Sep 2018, 5:33 pm   #7
turretslug
turretslug's Avatar
It's not one of those "piezo punkah" thingies is it?- that waved plastic strips around with an AC mains supply as a quiet and supposedly long-lasting alternative to circulating fans?
turretslug is offline
Old 16th Sep 2018, 5:35 pm   #8
Dave Moll
Dave Moll's Avatar
It's not some sort of voltage dropper, is it?
Dave Moll is offline
Old 16th Sep 2018, 6:00 pm   #9
Heatercathodeshort
Heatercathodeshort's Avatar
A toaster?
Heatercathodeshort is offline
Old 16th Sep 2018, 6:17 pm   #10
terrykc
With a plastic body?
terrykc is offline
Old 16th Sep 2018, 6:33 pm   #11
ColinTheAmpMan1
ColinTheAmpMan1's Avatar
It's the famed "wigwam to wind the sun up."
Colin.
ColinTheAmpMan1 is offline
Old 16th Sep 2018, 6:49 pm   #12
PJL
An aerial?
PJL is offline
Old 16th Sep 2018, 7:07 pm   #13
John10b
You did say a “Mains lead” is connected to it, if so, could you state its rating?
John
John10b is offline
Old 16th Sep 2018, 7:45 pm   #14
MotorBikeLes
It looks very much like one of the burner assemblies from my oil fired Rayburn, but plastic rather than heat resistant steel precludes that.
I vaguely recall my mother telling me (70 years ago) that it was a "wim-wam" that was used for sun winding purposes.
Les.
MotorBikeLes is offline
Old 16th Sep 2018, 8:18 pm   #15
Kentode
Kentode's Avatar
...and the winner is... DAVE MOLL!
It was in a box of cine projector bits and when I peered through the slats l could see a thin sheet of mica ( or asbestos!) wound with a fine wire.
As you pull out the square shaft you can see the approximate voltage.
If it is a mica sheet I'll wire it up and test it, but if it's asbestos I'll take further advice with regard to use or disposal.
Thanks to all who entered the quiz.
Regards, Ken.
BVWS member
Kentode is offline
Old 16th Sep 2018, 8:43 pm   #16
John10b
Well done Dave .
John
John10b is offline
Old 16th Sep 2018, 9:02 pm   #17
Radio Wrangler
I'd still like to stuff the phantom twiddler into it.........
Old 16th Sep 2018, 9:15 pm   #18
Kentode
Kentode's Avatar
Now I've got to research "the wigwam that winds the sun up"!
An advertising slogan?
Regards, Ken.
BVWS member
Kentode is offline
Old 16th Sep 2018, 9:45 pm   #19
Heatercathodeshort
They did make a Bakelite panel fire with pencil elements. J.
Old 17th Sep 2018, 6:32 pm   #20
Restoration73
Restoration73's Avatar
Many of the early GB (Gaumont British, later Rank) Equipments 16mm film projectors
used a 120v lamp, and an external dropper was required. I think the early projectors
were actually Bell & Howell made in the USA.
Restoration73 is offline
