1st Mar 2018, 6:59 pm | #141 |
Re: Dansette Bermuda MK II ??
Thanks. I will let you know - probably tomorrow.
1st Mar 2018, 7:07 pm | #142 |
The suspense is killing me!
2nd Mar 2018, 12:10 pm | #143 | |
2nd Mar 2018, 12:34 pm | #144 | ||
The other end of the other capacitor connects to the blue wire that goes to the wiper of the tone control. All the above can be seen from the photo's you have posted. Lawrence. |
2nd Mar 2018, 12:34 pm | #145 |
Where does the other end of what you're calling C5 go to?
EDIT. Crossed with Lawrence.
2nd Mar 2018, 12:35 pm | #146 |
Unfortunately my soldering iron has stopped working and will have to replace before continuing.
2nd Mar 2018, 1:21 pm | #147 | |
2nd Mar 2018, 1:24 pm | #148 |
Some advice please. Should I replace the soldering iron with a the gun held type that I currently have or go for the straight type for ease of use.
Thanks Martin |
2nd Mar 2018, 1:51 pm | #149 |
It's a matter of personal preference. I prefer a conventional straight iron.
2nd Mar 2018, 4:48 pm | #150 |
Managed to get to the local country store and get a soldering iron.
I have disconnected both capacitors and reconnected the 100k resistor. The voltage readings are: Pin 2 19.40 Pin 3 18.80 and Pin 9 1.21 |
2nd Mar 2018, 5:12 pm | #151 |
Without altering or reconnecting anything can you post a couple of new photo's, one showing the component side of the board and one showing the track side of the board?
Lawrence. |
2nd Mar 2018, 5:16 pm | #152 |
Something still not right there.
Are you absolutely sure there's now nothing connected to pin 9 apart from the 100k resistor?
2nd Mar 2018, 5:38 pm | #153 |
The two capacitors and the 100K resistor are the only components connected to Pin 9.
Photo's attached as requested. |
2nd Mar 2018, 5:48 pm | #154 |
It may be an illusion, but it looks like there's a wire bridging the tracks to pins 8 and 9?
The lead to a capacitor?
2nd Mar 2018, 5:56 pm | #155 |
That is probably where the 100K is connected and the end comes through the board. It not bridged but the tracks are close to each other due to solder. I will clean this up tomorrow to make sure there is more distance between them.
2nd Mar 2018, 6:01 pm | #156 |
Put a meter on ohms range (power off) across the two tracks. You'll soon see if they're bridging.
A bridge here would explain the low voltage on pin 9.
2nd Mar 2018, 7:15 pm | #157 |
no reading
2nd Mar 2018, 7:40 pm | #158 |
We've been here before. Does "no reading" mean short circuit or open circuit?
2nd Mar 2018, 8:30 pm | #159 |
There is continuity
2nd Mar 2018, 8:31 pm | #160 |
That's your problem then. Either the wire from R3 100k or a solder bridge.
