2nd Jun 2016, 6:39 pm | #81 | |
Re: Hum when old BSR connected to new op-amp/speaker circuit
If I was to use a magnetic cart with low output Z and low output voltage I could use the same module but with low value resistors (to keep the input Z low thus matching the cart) but a combination of values that gives me high gain to boost the low output voltage from the cart. |
2nd Jun 2016, 6:44 pm | #82 | |
I doubt you'll need any gain here but I see no harm in putting a bit in and trimming the output with the output pot. just be mindful, your power supply voltage needs to be AT LEAST twice the predicted output voltage at the op amp output to avoid clipping the signal. I'd stick with unity gain meself. |
2nd Jun 2016, 6:57 pm | #83 |
I just got this cheap stereo ceramic cart from china for £1.50 that I want to use in this project now my the original TC8M cart has broken (will obviously have to adapt the head shell to accomodate it).
http://www.ebay.co.uk/itm/1721297674...%3AMEBIDX%3AIT I'm expecting the voltage output of this to be lower that the TC8M so perhaps I may need a little gain... but I'm presuming that this ceramic cart will have a high Z comparable to the TC8M. There's no data sheet with this cheap cart so I'm flying blind at the moment... any ideas what specs it might have? |
2nd Jun 2016, 7:04 pm | #84 |
output 200 -300mV tracking weight 5 gr
from another eBay seller. It looks exactly like the cartridges on all those ion etc cheap turntables. |
2nd Jun 2016, 7:10 pm | #85 |
You beat me to it - I've just found that info too....but no info on impedance.... should I just assume all ceramics/crystals are high impedence of about 1 Meg to be safe...
2nd Jun 2016, 7:10 pm | #86 | |
Yes you could boost the 5mV output of a magnetic to 500mV like this, but there's the issue of frequency correction. This is the RIAA stuff we talk about. Far better to either get a cheap n cheerful magnetic step up stage or theres a velleman kit that does the job too. Ok for low budget stuff. Oh and remember its horses for courses, a magnetic cartridge really needs a better arm to work. A starting standard would be something like the Good Ol' Garrard SP25 or one of its competitors. A. |
2nd Jun 2016, 7:11 pm | #87 |
2nd Jun 2016, 7:11 pm | #88 |
Those cheap cartridges I've found work very well, and can give good quality sound depending on what they are hooked up to.
I wouldn't think it was possible to damage a cartridge because of impedence mismatching - you could short the two cartridge connections together and it wouldn't damage it. I suggest you try your TC8M in another player to check if it still works - it would be unusual for it to have been working and suddenly fail. |
2nd Jun 2016, 8:00 pm | #89 |
Just given my three carts a quick test in my amp set up. The TC8H works nicely as it did yesterday. Inexplicably the TC8M also works today but at a lower max volume than the TC8H (as expected from the medium output from the M wrt H). My new stereo cart from china is great. It temporarily wedges snuggly into the metal case of the turnover cart holder . I've just wired up one of the channels and I get a good volume from it through my little amp and speakers. This is all without the impedance matching we've been talking about. What kind of improvement would I expect to see if I now matched the impedance with the unity gain pre-amp? Is this a sound quality improvement or a volume improvement?
NB: the volume is ok to listen to but the quality is distorted and there's definitely room for improvement (that I'm hoping the impedance matching will do this). Last edited by indigo.girl; 2nd Jun 2016 at 8:21 pm. |
2nd Jun 2016, 8:29 pm | #90 |
I've just swapped my tiny 6.5cm speakers that came with the kit with a big 9" speaker from inside a Philips 654A radiogram. The volume and sound quality is much better with this speaker.
2nd Jun 2016, 8:30 pm | #91 |
Impedance matching would probably get rid of the distortion. Also paralleling the 2 channels on the cartridge would improve the sound as at the moment you're only hearing one channel of the stereo pair, alternatively since your little amp is stereo you could remove your bridge on the input and wire in both channels.
I've managed to wedge one of those carts into an X3M bracket before, never tried it with a TC8 as I've not had a player with one of those for years. Another advantage of your new cartridge is that it won't damage stereo records the way a TC8 would. |
2nd Jun 2016, 8:34 pm | #92 |
Its difficult to say.
For sure matching the impedance is a good thing. I have a feeling that your little amp and speakers just ain't that good and you might not be getting the best out of things. You could try a pair of headphones and that would indicate if the amp itself is ok and its the speakers that are the issue. They'll sound pretty tinny anyway whatever you feed into them. The main thing about impedance matching so to speak, is that you don't lose the low frequency parts of a signal. This is very simplified. You also lose a bit of the signal but I doubt its that much in this instance. A. |
2nd Jun 2016, 8:36 pm | #93 |
Ah it would seem you've tried a better quality speaker.
Making progress then |
2nd Jun 2016, 8:50 pm | #94 |
Are you using the 430 K still with your tests?
2nd Jun 2016, 9:14 pm | #95 |
2nd Jun 2016, 9:19 pm | #96 |
What would be the optimal speakers to use with this 1W channel output amp but staying small in size like they had in the old dansettes. I'm thinking of mounting it all in a case. This 9 incher is way too big!
2nd Jun 2016, 10:09 pm | #97 |
Something salvaged from a scrap radio.
The biggest that you can fit easily in your chosen cabinet. Why not put everything back in the original gram cabinet and use the speaker in that? A. |
3rd Jun 2016, 12:12 am | #98 |
I have already suggested 5" and 6.5" diameter units. Alternatively 7" x 4"ellipticals. Edward
3rd Jun 2016, 6:56 am | #99 |
As per your question in post 89
Possibly nothing to gain and a waste of time and effort. What is the volume like with the new cart and better speaker? You need the speaker on its baffle or in its case to judge or mount the small speakers on a baffle you can't just can't leave them out in the open. For a test you could get a piece of cardboard an cut holes and mount them on that. |
3rd Jun 2016, 9:00 am | #100 |
Completely not sure where this thread is going....is this a learning experiment or is indigogirl trying to make some kind of record player out of an old BSR autochanger with a dubious mono cartridge, a low-spec stereo IC and 2 very small speakers? In the meantime, and somewhere in the background lurks, an old Sobell mono radiogram cabinet. All rather surreal. I mean what is to be the final desired outcome? Edward
