1st Jun 2016, 6:02 pm | #41 |
Re: Hum when old BSR connected to new op-amp/speaker circuit
Most basic tone controls simply reduce the treble content of the audio but with a decent speaker (Try the one in your gram) may not be needed. Do you have any pots and capacitors around to try?
1st Jun 2016, 6:34 pm | #42 |
Do note that that very rare and valuable BSR TC8H high-output cartridge you plan to use is liable to overload the input stage of your IC amplifier. It gives around 1.0V output. Also those little speakers are not going to give very good audio as their diameter is so small. Edward
1st Jun 2016, 6:41 pm | #43 |
Found the datasheet for the chip- its input resistance is 100K so I would think that increasing the pot(s) to 50K would be reasonable and would give a little more gain.
If you're feeling adventurous, you could change the circuit to the bridge output version in the data which would only need a single volume pot and connect the speakers in series between the two outputs as shown.
1st Jun 2016, 6:42 pm | #44 |
I actually find it incredible that any TC8H cartridge still works. I've never encountered one that worked, even back in the 80's. The TC8M seemed to last longer from my own experiences.
1st Jun 2016, 6:52 pm | #45 | |
1st Jun 2016, 7:01 pm | #46 | |
Interestingly, I'm not sure that this TC8M was the original cart in this deck because the pick up arm had 4 wires inside (with two unused) as if it once had a stereo cart (although surely not in this old 1950's radiogram).... |
1st Jun 2016, 7:05 pm | #47 |
They were all "wired" for stereo even if a mono cartridge was fitted.
1st Jun 2016, 7:09 pm | #48 |
Post#35?
Lawrence. |
1st Jun 2016, 7:20 pm | #49 | |
draw the circuit out and you will see where I'm coming from. Unfortunately, as has been pointed out, the amplifier chip has a maximum input Z of 100k which is plenty for any modern source but with a piezo cartridge you ideally would need around 1meg. There is a solution and its not difficult or costly. A. |
1st Jun 2016, 7:21 pm | #50 |
This looks great Andy - and at £4.99 its a bargain. I paid £12 for my kit. It says new old stock - so has this module design been around a while? Its pre-op amp I'm presuming, I can't see from the photo...
I'll soon be getting a stereo cart that I can use to replace the TC8M (I have one on order from china for a couple of quid). Do you know the impedance of the this module so I can match it with the cart when it arrives? And can I use my original speakers with this module or should I give up on these little things too? Where's a good place to source modules like these ones? I found mine at Maplins but they don't have much to choose from. Where's a good stockist that will help a newbie? |
1st Jun 2016, 7:22 pm | #51 |
1st Jun 2016, 7:25 pm | #52 |
Yes, it's the old impedance problem again.
Lawrence. |
1st Jun 2016, 7:26 pm | #53 |
1st Jun 2016, 7:27 pm | #54 |
Hi Indigo girl, i apologise as i deleted the post more or less straight away as possibly not relevant to the thread.
Its from bardwells, I'll repost the link here. I'd suggest you'll still need to get an impedance buffer for use with the cartridge but thats fairly easy and I can give you a socket and an op amp that will make one, or you just adapt one of the cheap opamp pre's from maplins. A few of the members of this forum have built amps using this module with a lot of success so you'll get plenty of advice based on experience if you do buy one. http://www.bardwells.co.uk/product/s...s-per-channel/ Andy. |
1st Jun 2016, 7:31 pm | #55 |
Ah, so are you and Andy saying the 430K resistor in series with the input channel is causing me problems? I'm getting a little confused as I thought the 430K I've added here increases the impedance of the IC circuit from 20K to about 500K hence matching the requirements of this Piezo cart? Can I wire it differently to increase the impedance without causing the 'attenutor' problem?
1st Jun 2016, 7:36 pm | #56 |
One for the transformer experts.
Is it possible or even practical to use a Step down transformer with a piezo cartridge. e.g. cartridge with Z=500k ohm into a 10:1 transformer gives an output Z=50k? and a tenth of the output voltage which may or may not be a bad thing? If this is OT on this thread mods please do as you see fit. A. |
1st Jun 2016, 7:52 pm | #57 |
Not really Indigo Girl.
Whatever you do, you get either an impedance mismatch to the cartridge or excessive attenuation. The only really practical way as I understand it, is to have a buffer stage in between. This is seen commonly in amplifiers, in valve amps you'll see perhaps a cathode follower to provide an impedance match and in transistor amps it would be what they call an emitter follower. Sometimes transformers are used too. In deed that is exactly what a loudspeaker output transformer on a valve amplifier does. Nowadays we have these wonderful little devices called op amps and they are very versatile. So good that they are found in the highest of fi and pro studio kit. The good news is that they are cheap and for the cost of one of these (pence in many cases) and half a dozen small resistors and capacitors you can make a unity gain impedance matching buffer, or a high gain quality amplifier and everything in between. You may guess that I'm a fan of op amps and you'd be right. The consolation here is that with that little amp and those miniscule speakers you'd probably not notice any fall off in the bass frequencies due to the mismatch, so I'd go back to the drawing board and simply reduce the value of the series resistor until you get the best compromise between volume and performance. It just might work. Oh and use a larger value pot on the input too. (if you have one) A. |
1st Jun 2016, 8:10 pm | #58 |
Thanks Peter - I'll have a go with some better speakers and see how it sounds. Although I'm a bit worried about using the high output TC8H with it now in case its too much for my op amp...
1st Jun 2016, 8:18 pm | #59 | |
That gives a total resistance across the cartridge of 440k, no problem with that, we can view that as a high impedance load across a high impedance cartridge. The 430k and 10k form a potential divider, the IC's input is taken from that potential divider, the ratio of the two resistances is 43:1, the voltage ratio between the input and output of that divider will also be 43:1, eg: 100 millivolts input to the divider will give 2.33 millivolts out (approx) and that's assuming the IC's input impedance is infinite, which it won't be, the IC's input impedance will reduce the output from the potential divider even further but probably by not a lot. Hope this helps to explain things. Lawrence. |
1st Jun 2016, 8:19 pm | #60 |
https://www.vintage-radio.net/forum/...d.php?t=113530
Thats the thread on the Module. By the way, your little power amplifier chip isn't an op amp although its likely that theres an op(erational) amp(lifier) inside the chip as part of the overall circuit. I think maybe we are bombarding you with info that may be just slightly ahead of your current skill set? I may have made the error of assuming you understand building blocks of theory like potential dividers etc? In which case apologies. But you are learning fast I think? A. |
