Old 12th Jan 2015, 4:31 pm   #1
akaigxfan
Default Akai X360D speed issue
Hello. I'm having some annoyance with the correct speed on the Akai X360, which with the small wheel wont give me 7 1/2 speed. it will sometimes when the build up is slow, sometimes failing to change at all from 3 3/4.
If it does change up and reach 7 1/2 it soon slows down again. Anyway I've been using the 15 ips adaptor sleeve and pinch wheel then 1 7/8 is 3 3/4 and 3 3/4 is 7 1/2 and it'll do what I'm wanting it to do, but then recording is not quite right.
I've since discovered that it will work correctly with the correct wheel on for a short while say 10-15 mins, then it slows again. and it's most strange as playing with the speed selector sometimes it will work sometimes not. Once it was at 7 1/2 and I switched it to 3 3/4 and it still played at 7 1/2.
Please help with things to try. Otherwise its a nice machine. I've fitted a new belt today.
akaigxfan is offline
Old 13th Jan 2015, 8:43 am   #2
Yarraman
Yarraman's Avatar
Default Re: Akai X360D speed issue
I'm not familiar with the X360, but slow or weak motor problems is usually caused by the "motor start" capacitor which is in series with the motor field winding. check the schematic, but It will need replacement.
Yarraman is offline
Old 17th Jan 2015, 4:49 pm   #3
akaigxfan
Yes, seems to be the case. Thank you. However the cap seems to be a dual value one as these so often are, which is not a problem as I have some of the correct value and size however there is a miriad of wires going to 5 tags. I think I'll put it on the back burner for a while, does anyone know where I could get one from?
Thanks.
Old 20th Jan 2015, 3:01 am   #4
Yarraman
Yarraman's Avatar
I should have called it a "Motor Run" Capacitor, but if you google it, I'm sure you'll find a supplier, otherwise use a high voltage polyester capacitor.
Yarraman is offline
Old 20th Jan 2015, 8:19 am   #5
akaigxfan
Thanks for that, I dont have the neccesary knowledge to know how to wire up a non exact type. This one has so many wires that's why it would need to be the same type as it would be straight forward.
Old 21st Jan 2015, 2:18 am   #6
Yarraman
Yarraman's Avatar
There is usually 2 or 3 "Motor Run Capacitors" in one Capsule on the Akai Models beside the motor. the 50 Hz (Cycles.Per.Second) or 60 Hz switch "switches in" one or the other or both, so not all of them are used at once. I think the value "switched in" for 50 Hz is 2 uF? 600Volt?
I don't think you will get an exact replacement?, that's why you will need the Schematic and some discrete motor run capacitors or maybe a Technician
Yarraman is offline
