22nd Jan 2020, 8:12 pm | #1 |
10MHZ to 4MHz with standard logic?
Can anyone suggest a nice simple circuit to divide a 10MHz clock down to 4MHz using as few standard logic ICs / gates as possible? I've been using microcontrollers for so long that I have almost lost the ability to think in standard logic nowadays.
The 4MHz output would ideally be a 50/50 square wave but it doesn't absolutely have to be - it can be short low pulses or short high pulses if that's the easiest way to go. Even I remember how to build an independent 4MHz oscillator using a few gates and a crystal, but the problem is that the 10MHz and 4Mhz oscillators need to have a synchronised relationship rather than be independently free running. |
22nd Jan 2020, 9:41 pm | #2 |
Re: 10MHZ to 4MHz with standard logic?
Make the 10MHz 20MHz by making pulses on each transition then divide by 5. Pulses created by an XOR gate with one input delayed a bit with an RC or a few gates in series (there will be 3 left over in a chip). Divide by 5 comes in most decade counters.
22nd Jan 2020, 9:48 pm | #3 |
Never thought of that, but is (2 * 10Mhz) = 20MHz input acceptable for typical TTL / CMOS counters running at 5V? (Sorry, I should have included the supply voltage in the original post).
The reason I ask is that supply volts appears to make quite a bit of difference to maximum operating frequency. |
22nd Jan 2020, 9:50 pm | #4 |
You may be able to do something with the 7490/7492/7493-style ICs - the Schottky-variants (74S) is quite fast.
22nd Jan 2020, 10:36 pm | #5 |
If you have a 4MHz pulse train you can turn that into a square wave by triggering a 1/8 microsecond monostable
Stuart The golden age is always yesterday - Asa Briggs |
22nd Jan 2020, 10:37 pm | #6 | |
*what audiophools do with valves! |
22nd Jan 2020, 10:47 pm | #7 |
After a little bit of cutting and pasting different elements from various diagrams found on the net into Paint (...I really must get a circuit drawing package) I have this, attached.
(Power connections and XOR gate pin numbers omitted for brevity) |
22nd Jan 2020, 11:01 pm | #8 |
Just use 74HC series logic. It's cheap, current and quite fast enough. Saves you having to get an audiophile in to listen to your dividers as you chip roll them :-0
22nd Jan 2020, 11:03 pm | #9 |
XORs give a zero when both inputs are the same as in your diagram, one should be at a static logic level. Mind you it may work if the chip has different "lengths" of logic inside.
22nd Jan 2020, 11:08 pm | #10 | |
Why not divide by 5 and then do the doubling? dave
Dave Teague |
22nd Jan 2020, 11:44 pm | #11 |
Re: The way I connected the XOR gates: DUH. Yes, of course.
Dave, the 4MHz output ideally needs to have a definite 'pulse shape', unlike the razor thin spikes which will be coming out of the doubler. |
22nd Jan 2020, 11:50 pm | #12 |
To get equal mark/space, finish with a divide by two.
23rd Jan 2020, 12:07 am | #13 |
Binary rate multiplier, such as the HFC4049B?
Al. |
23rd Jan 2020, 12:17 am | #14 |
Explain? As far as I know the 4049 is a hex inverter / level converter?
23rd Jan 2020, 2:26 pm | #15 |
I had a similar problem a few years ago and tackled it thus, although my frequencies were different:
Divide 10 MHz by 10 to give 1 MHz (used a 74HC4017 for this) Apply the 1 MHz as a reference sig to a HC4046 PLL running at 4 MHz. Put a divide-by-4 in the VCO to PD pins of the 4046. It's a bit long-winded but it worked without problems for years.
Andy G1HBE. Last edited by Andrew2; 23rd Jan 2020 at 2:33 pm. |
23rd Jan 2020, 3:20 pm | #16 | |
SN74167N is a Decade Rate Multiplier that provides an output pulse rate which is the clock-input pulse rate multiplied by 1/10 times the BCD input. For example, when the BCD input is 4, there will be 4 output pulses for every 10 input pulses. This would convert 10MHz to 4MHz. Inherent in this, and any other standard logic that I can think of, is that the 4 output pulses are not equally space. In this case, the logic simply blocks 6 out of every 10 clock pulses. If the OP wants a regular 4MHz clock a phase locked loop as suggested by Andy might be best. David |
23rd Jan 2020, 3:28 pm | #17 |
Here's another approach using a 74HC161 synchronous binary counter:-
Qa/Qb function as a divide by 3 counter. Count sequence: ...2-3-0-2-3-0.... However, Qc toggles at the 3-0 transition and inverts the 10MHz clock, effectively bringing the next rising edge forward half a cycle. This makes the '0' state half as long, and the division becomes 2.5, hence 4Mhz outputs on Qa and Qb. Qa has a mark:space of 2:3 and Qb 4:1, Qc is a 2Mhz squarewave. Cheers |
23rd Jan 2020, 3:54 pm | #18 |
Are there any timing constraints between the 10MHz and 4MHz clocks, eg do their rising (or falling) edges need to be coincident to within a few nS?
Stuart(h) |
23rd Jan 2020, 4:53 pm | #19 |
23rd Jan 2020, 7:09 pm | #20 | |
Obviously with the frequencies being disparate the leading edges of the pulses will not coincide every other pulse, as they would with simple divide-by-2. |
