Old 22nd Oct 2011, 3:04 pm   #1
tonebloke
Default Cossor 494AC
So my second little project I have given myself is replacement of the tuning string.
How hard is this to do as again? I am completely new to this and don't want to strip parts that I don't have to and risk damage.
Thanks.
tonebloke is offline
Old 22nd Oct 2011, 4:03 pm   #2
Top Cap
Top Cap's Avatar
Default Re: Cossor 494AC
Quite an easy one by the looks of it. Don't forget to take up all slack and then put a small amount of tension on the spring when tying off.
Les
Note: Gang maximum means all vanes fully meshed.
Name:	cossor 494 drive cord.jpg
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline
Old 22nd Oct 2011, 4:19 pm   #3
tonebloke
thats great thanks i had guessed that was the route and it needed to be wound round but as i say new to this so was only a guess.
Thanks again
That's great thanks. I had guessed that was the route and it needed to be wound round but, as I say, new to this so was only a guess.
Thanks again.
Old 22nd Oct 2011, 6:32 pm   #4
HamishBoxer
HamishBoxer's Avatar
My, if only all dial cords were this easy!
HamishBoxer is offline
Old 22nd Oct 2011, 9:24 pm   #5
mister valve
mister valve's Avatar
I agree.... If only all Dial Cord Drives were as easy as this appears to be
You will always know when you're an 'expert' at Drive Cords, when you have successfully fitted a New Drive Cord to a 'Philips/Mullard' set with the pulley wheels attached to the Bakelite cabinet, but the Tuning spindle & Drive Drum are attached to the Chassis .
Remove the Chassis from the Cabinet and (you've guessed it), off comes the Dial Cord
If you live, the chassis was dead; if you're dead, the chassis was live !!!!
mister valve is offline
